Probability for a binomially distributed variable X
In summary, the problem asks us to calculate the probability of a binomially distributed random variable being within one standard deviation of its mean. Using the equations for the mean and variance of a binomial distribution, we can find the numerical values for the range within one standard deviation. To find the probability, we must use the cumulative function, which is the sum of the probabilities of all values within the range. The notation for the probability mass function for a binomial distribution is ##b(k;n,p)##, and the cumulative function is written as ##F(X) = P(X \leq x) = \sum_{k=0}^{\lfloor x \rfloor}b(k; n,p)##.
TheSodesa
224
Let ##X \sim Bin(n, p)## where ##n=20## and ##p=0.1##. Calculate ##P(|X-\mu| \leq \sigma)##.
Give your answer up to three decimal places.
For a binomially distributed random variable, using moment generating functions we have:
\begin{equation}
\mu= E(X) = np
\end{equation}
\begin{equation}
\sigma^{2} = Var(X) = np(1-p)
\end{equation}
The probability density function is
\begin{equation}
f(x) = {n \choose x} p^{x}(1-p)^{n-x}
\end{equation}
Now the asked probability looked a lot like Tsebyshev's inequality, but that just gave me a zero, and the electronic return system complained about it. It also gave me a hint:
First solve ##|X - \mu| \leq \sigma## and then calculate
[tex]
P(|X - \mu| \leq \sigma) = P(X=x_1 \text{ OR } X = x_2 ...)
[/tex]
I started out by solving for ##X##:
\begin{align*}
|X-\mu| \leq \sigma\\
\iff\\
-\sigma \leq X-\mu \leq \sigma\\
\iff\\
\mu-\sigma \leq X \leq \mu + \sigma\\
\iff\\
np - \sqrt{np(1-p)} \leq X \leq np + \sqrt{np(1-p)}\\
\iff\\
\stackrel{\approx 0.658}{2 - \sqrt{2(0.9)}} \leq X \leq \stackrel{\approx 3.342}{2 + \sqrt{2(0.9)}}\\
\end{align*}
Alright. Now I have some numerical values. But now what? I don't know what ##x_1##, ##x_2## etc. are in the hint. Are they referring to ##X=1##, ##X=2## and so on?
\begin{equation}
\mu= E(X) = np
\end{equation}
\begin{equation}
\end{equation}
\begin{equation}
\end{equation}
First solve ##|X_\mu| \leq \sigma## and then calculate
[tex]
[/tex]
\begin{align*}
\iff\\
\iff\\
\iff\\
\iff\\
\end{align*}
If you are asking what I think you are the answer is yes. What values of can X take that satisfy that last inequality? What is their probability?
Well, for a discrete variable ##X##, the point probabilities are given by the distribution function ##f(x)##. If I wanted to find the probability of a certain interval, I would have to calculate the cumulative function in the interval ##0 < X \leq 4##. Or should it be ##0 < X \leq 3##? According the my course handout, for a binomially distributed variable the cumulative function
\begin{equation}
F(X) = P(X \leq x) = \sum_{t=0}^{\lfloor x \rfloor}b(t; n,p)
\end{equation}
I do not know what the small ##b## is in the definition, and the handout doesn't say how to calculate these values. It simply says to look them up in a table or a computer program.
The floor function ##{\lfloor x \rfloor}## is supposedly the largest whole number ##\leq x##, so I guess my cumulative function would be
[tex]F(X) = P(1 \leq X \leq 3) = \sum_{t=0}^{\lfloor x \rfloor}b(t; n,p)[/tex]
Alright, so I just summed the probabilities ##f(1)##, ##f(2)## and ##f(3)## together, which apparently gave me the right answer. I'm still a bit baffled (might have something to do with the fact that it's almost 4am here), but I'm going to have to let this one go for now.
Thanks for the assistance.
\begin{equation}
\end{equation}
The notation ##b(k)## or ##b(k;n,p)## is used for the probability mass function (NOT density function!):
$$b(k;n,p) = {n \choose k} p^k (1-p)^{n-k}$$.
So the formula in the handout is just ##\sum_k P(X=k) ##, where the sum is over all non-negative integers ##0 \leq k \leq x##.
Your sum ##F(X) = P(1 \leq X \leq 3)## is incorrect (if you meant to write ##F(3)## instead of ##F(X)##). Can you see why?
I guess I should have written ##F(1 \leq X \leq 3)## instead? ##F(3)## would imply ##P(X\leq 3)##, if I've understood the notation correctly. I have to say it is kind of annoying they switch symbols for the mass functions between distributions. Can't they just stick to ##f##? :confused:
They should NOT use ##f## routinely for the probability mass function of a discrete random variable; it should be used primarily for the probability density function of a continuous random variable. However, ##F## is often used for the distribution function for both types. (Older sources routinely called this the cumulative distribution, but nowadays the adjective "cumulative" is being dropped more and more often.)
It would be much more annoying if they used the same symbol ##f## for different mass/density functions, but perhaps with subscripts and other modifiers. It often more convenient use something like ##b(k)## for the binomial probability ##P(X_{\text{binomial}}=k)##, something like ##po(k)## for ##P(X_{\text{poisson}}= k),## etc. This adds to communication clarity----as long as the source (books, notes, or whatever) makes sure to first define the terms before using them. If they do use the notation without definition or explanation then that, indeed, would be annoying.
Back when I was teaching this material I tried to use symbols like ##f(x)## etc, for density functions of continuous random variables (except when using ##\phi(z)## for the density function of the standard normal variable ##Z \sim N(0,1)##, and things like ##p(k)## for the probability mass function of a discrete random variable. Unfortunately that left something like ##F(x)## or ##F(k)## for both.
One final remark about notation: do not use ##X## as an argument of ##F## or ##f##, because it will hardly ever mean what you think it does. It is important to distinguish between the random variable ##X## (upper case) and its possible values ##x## (lower case). If ##F## is the (cumulative) distribution of ##X##, then for any distribution at all the quantity ##F(X)## is a continuous random variable with density uniform on ##(0,1)##, so unless you mean that you should not write it.
Got it.
Related to Probability for a binomially distributed variable X
1. What is a binomially distributed variable?
A binomially distributed variable is a discrete random variable that represents the number of successful outcomes in a series of independent trials. It is characterized by two parameters: the number of trials (n) and the probability of success in each trial (p).
2. How is probability calculated for a binomially distributed variable X?
The probability of a specific number of successes (k) in a binomial distribution is calculated using the formula P(X=k) = (n choose k) * p^k * (1-p)^(n-k), where n is the number of trials, p is the probability of success, and (n choose k) is the binomial coefficient.
3. Can the probability of success change in a binomial distribution?
No, the probability of success in a binomial distribution remains constant throughout all trials. This is one of the key assumptions of a binomial distribution.
4. What is the relationship between the mean and variance of a binomially distributed variable?
The mean of a binomial distribution is equal to n * p, and the variance is equal to n * p * (1-p). As the number of trials increases, the mean and variance also increase proportionally.
5. How is a binomial distribution different from a normal distribution?
A binomial distribution is a discrete distribution, while a normal distribution is a continuous distribution. Additionally, the shape of a binomial distribution is typically skewed, while a normal distribution is symmetrical. Finally, a binomial distribution is based on a fixed number of trials, while a normal distribution is based on a continuous range of values.
