Probability involving Gaussian random sequences
The delta function nature of the autocorrelation function can also give you some insight and ideas for approaching this problem. In summary, to solve this problem, you need to use the relationship between PSD and autocorrelation function, and consider the properties of a white process.
ashah99
60
Please see below.
PSD, autocorrelation function
How do I approach the following problem while only knowing the PSD of a Gaussian random sequence (i.e. I don't know the exact distribution of $V_k$)? Or am I missing something obvious?
Problem statement:
Thoughts:
I know with the PSD given, the autocorrelation function are delta functions due to a white process, such that it takes a value of 20 at k = 0 and value of 8 at k = +1 and -1. Any ideas?
To approach this problem, you need to use the fact that the PSD of a Gaussian random sequence is the Fourier transform of its autocorrelation function. Thus, you can use the given PSD to calculate the autocorrelation function, and then use this to solve for the distribution of $V_k$.
FAQ: Probability involving Gaussian random sequences
What is a Gaussian random sequence?
A Gaussian random sequence is a sequence of numbers that follow a normal distribution, also known as a Gaussian distribution. This means that the values in the sequence are more likely to be found near the mean, with fewer values further away from the mean.
How is probability calculated for Gaussian random sequences?
The probability of a value occurring in a Gaussian random sequence is calculated using the standard normal distribution formula. This involves finding the area under the curve of the normal distribution, which represents the probability of a value falling within a certain range.
What is the difference between a Gaussian random sequence and a regular random sequence?
A Gaussian random sequence follows a specific distribution, while a regular random sequence can follow any distribution. Additionally, Gaussian random sequences have a mean and standard deviation that can be used to calculate probabilities, while regular random sequences do not necessarily have these parameters.
How is the mean and standard deviation of a Gaussian random sequence determined?
The mean and standard deviation of a Gaussian random sequence can be determined by taking a large number of samples from the sequence and calculating their mean and standard deviation. This is known as the sample mean and sample standard deviation, and they are used as estimates for the true mean and standard deviation of the sequence.
What are some real-world applications of probability involving Gaussian random sequences?
Gaussian random sequences are commonly used in fields such as finance, engineering, and physics to model and analyze data. Some specific applications include predicting stock prices, simulating weather patterns, and analyzing experimental data in scientific research.
