Probability mass function of a hash table?
In summary, a hash table is a storage structure that uses a hash function to calculate the storage address for a record key. In case of collisions, a secondary hashing scheme is used with a sequence of independent hash functions to evenly distribute the keys across the table. If a record insertion requires multiple probes, it is said to require j probes. The probability mass function of the random variable X, representing the number of probes for a new record insertion, can be found by using the fraction a (a < 1) of the table that is filled. The mean and variance can also be calculated. The original conversation also includes a request for help with determining the values and probability for X, as well as a mention of being stuck and the textbook being
KataKoniK
1,347
A hash table is a storage structure that calculates the storage address from a record key, k where f1(k) returns the storage address. Sometimes the hash function returns the same address for several keys (called collision). To fix this problem, a scheme called secondary hashing uses a sequence of independent hash functions f1, f2, etc. each which attempts to spread the key uniformly across the table. If f1(k) produces a collision, then f2(k) is tried and so forth. If a record insertion requires the services of hash function f1... fj to sucessfully find space for a new reocrd, it is said that we require j probes. Suppose the fraction a, (a < 1) of the table is filled when we make an attempt to store a new record. Let X be the random variable standing for the number of probes necessary to insert the new record.
What is the probability mass function of X. Find its mean and variance.
Does anyone here have a clue what values to use for X? And what the probability will be? I am clueless on what to do here. Any help would be great thanks.
Any idea? Really stuck here. Textbook is not of any help.
The probability mass function (PMF) of X can be defined as P(X=x) = (1-a)a^(x-1), where x is the number of probes required to insert the new record and a is the fraction of the table that is filled.
To find the mean and variance, we can use the formula for the PMF of a geometric distribution, which is 1/p, where p is the probability of success. In this case, p = (1-a).
Therefore, the mean (or expected value) of X is E[X] = 1/p = 1/(1-a).
The variance of X is Var[X] = (1-p)/p^2 = (1-(1-a))/(1-a)^2 = a/(1-a)^2.
As for the values to use for X, it will depend on the specific scenario and the values of a and the number of hash functions being used. Generally, as a increases, the number of probes needed will also increase. And as the number of hash functions increases, the probability of needing more probes will decrease.
FAQ: Probability mass function of a hash table?
1. What is a probability mass function of a hash table?
A probability mass function of a hash table is a mathematical representation that assigns probabilities to each possible outcome or value in a hash table. It is used to calculate the likelihood of a particular outcome or value occurring in a hash table.
2. How is a probability mass function calculated for a hash table?
A probability mass function for a hash table is calculated by dividing the number of occurrences of a particular outcome or value by the total number of outcomes or values in the hash table. This gives the probability of that outcome or value occurring in the hash table.
3. What is the purpose of a probability mass function in a hash table?
The purpose of a probability mass function in a hash table is to provide a way to quantitatively analyze the likelihood of different outcomes or values occurring in the hash table. It can also be used to compare different hash tables and determine which one is more efficient or evenly distributed.
4. How does the distribution of values in a hash table affect its probability mass function?
The distribution of values in a hash table can greatly affect its probability mass function. If the values are evenly distributed, the probability mass function will show a relatively flat distribution. However, if the values are not evenly distributed, the probability mass function will show a skewed distribution, with some values being more likely to occur than others.
5. Can a probability mass function be used to predict the occurrence of a specific value in a hash table?
No, a probability mass function cannot be used to predict the occurrence of a specific value in a hash table. It only provides a probability for each possible outcome or value in the hash table, but it does not guarantee that any specific value will occur.
