Probability of 1 Letter E in 4 Randomly Selected Letters from 'ENCYCLOPAEDIA
  • Thread starter Thread starter Darkmisc
    Probability
The discussion centers on calculating the probability of selecting one letter E from four randomly chosen letters in the word "ENCYCLOPAEDIA." Initial calculations suggested a probability of 0.46, while the correct answer was indicated as 2/33. Participants noted that accounting for repeated letters is crucial, and different methods, including direct probabilities and labeling duplicates, yielded consistent results. The conclusion emphasizes that the probability of obtaining one E is higher than that of getting no E's or two E's, reinforcing the need for accurate calculations. Overall, the conversation highlights the importance of considering letter repetition in probability assessments.
Darkmisc
Four letters are randomly selected from the word ENCYCLOPAEDIA. Find the probability that one letter E will occur in the selection of 4 letters.
[SUP]2[/SUP]C[SUB]1[/SUB] x [SUP]11[/SUP]C[SUB]3[/SUB]/[SUP]13[/SUP]C[SUB]4[/SUB] = 0.46
My calculation was
2C1 x 11C3/13C4 = 0.46
However, the answer is 2/33. I think the repeated letters might need to be accounted for. I divided the E term in the numerator by 2. I also divided the term for the remaining 11 letters by 4. I divided the denominator by 8 (2!x2!x2!), but this just canceled out the 2x4 in the numerator.
Thanks
I agree with your answer. I did it using direct probabilies. First, the probability of getting an ##E## as the first letter, followed by three letters that are not ##E## is:
$$P(EXXX) = \frac 2{13} \cdot \frac{11}{12} \cdot \frac{10}{11} \cdot \frac{9}{10} = \frac 3 {26}$$
Then we have the same probability for ##XEXX## etc. So, the total probability of precisely one ##E## is ##\frac{12}{26} = 0.46##.
Your method worked because you effectively labelled the duplicate letters ##E_1, E_2## and looked for either ##E_1## or ##E_2##. And the same with the other duplicate letters.
So, we have three ways to calculate and, happily, they all give the same answer.
PS you can see that ##2/33## can't be right, because you have only three options: no E's, one E ort two E's. The last of these looks the least likely, so you'd expect quite a high probability of either no E's or one E.
You could, as an exercise, calculate those probabilities as well: no E's and two E's. And check it all adds up to 1.
