- 1,992
- 969
- Homework Statement
- With the high school distance learning, I'm helping my daughter with her 9th grade math problems (probability):
A lock has a 4 "digit" code without repetition. The possible digits are the numbers 0-9, and the letters A,B,C,D,E and F. The question is what is the probability of a code which has only one numeric digit (0-9).
- Relevant Equations
- Joint Probabilities. Conditional Probability.
The lessons show using Permutations and Combinations for other problems in this section, but we were having difficulty what to choose to put in those formulas. I used this approach:
We have 10 numeric and 6 alphabetic = 16 total possible.
Let's look at the first digit numeric, and the next 3 alpha:
$$ P(First Digit Numeric) = \frac{10}{16} $$ and
## P(Next Digits Alpha) = \frac{6}{15} ## and ## \frac{5}{14} ## and ## \frac{4}{13} ##
Since all four of these have to occur, we multiply them to get ## \frac{1200}{43680} ## which reduces to ## \frac{5}{182} ##
I go through the probabilities for (2nd digit numeric) and then 3rd and 4th, with the same probability for each situation. So we can multiply by 4 to get: ## \frac{20}{182} = \frac{10}{91} ##
This was one of the choices in the multiple choice, but the autograder marked it wrong. I looked it over several times, but come up with the same thing. Then I even programmed a little simulation, and after over 1 million random samples, get nearly the same result. I've known these online homeworks to have mistakes, sometimes, but I wanted to run by here before emailing the teacher.
