Probability of all runners finishing within 100 minutes
  • Thread starter Addez123
  • Tags
    Probability
In summary: So the final answer is (50/3)^8 = 390625/6561.In summary, the chance of everyone finishing the race within 125 minutes can be calculated using the function Fx(100)^8, which is equal to (50/3)^8. However, in order to accurately calculate this probability, the value of the integration constant C must be properly determined by taking into account the fact that the density function is zero below 95 minutes. Once this is done, the correct value for C is 0 and the final probability is (50/3)^8 = 390625/6561.
Addez123
199
The time it takes for a runner to make a lap is a stocastic variable X (in minutes) with density function
$$fx(x) = (125 - x)/450, 95 \leq x \leq 125 $$
Their times are independent of eachother.
What's the probability that all 8 runners finish within 100 minutes?
$$Fx(x) = \int fx(x) dx $$
$$Fx(x) = 125/450 * x - x^2/900$$
The chance of everyone finishing should be
$$Fx(100)^8 = (100 * 125/450 - 100^2/900)^8 = (50/3)^8$$
What am I doing wrong?
It seems you have just taken an arbitrary primitive function for Fx. You need to give a better argument for the value of the integration constant that you have put to zero.
Likes Addez123
There's no legit reasoning to get a constant.
The density function goes to zero at 125, it doesn't mean everyone have made the lap within 125 minutes.
Just like the density function starts at 30/450 = 0.06 doesn't mean 6% makes it under 95 minutes. The density function outside these bounderies could be anything, its not defined anywhere.
This is simply false. You need to think more about what the requirements on the cdf are.
Of course not, the pdf is the pdf and the cdf is the cdf.
This is also false by the way. The pdf is defined to be non-zero only for ##95 < x <125##. Obviously, this means that everybody makes it within 125 minutes because the probability of any given runner not making it within 125 minutes is zero.
Your calculation of Fx(x) is wrong. The density function, fx(x) is zero for x<95. Therefore, your calculation of Fx(x) must start at x=95. (The integral of fx(x) from 95 to 125 is 1, as it must be.)
  • Wow
Likes Addez123
It's true that the density function sums up to 1 over that integral. Idk why I thought it didn't.
But given that, now I'm trying to find C.
You get different answer depending on your approach.
Fx(125) = 1 => C = -625/36
Fx(95) = 0 => C = -589/36
Shouldn't it give the same value if indeed what was missing was a constant?
I should have been more clear. The probability of x between 95 and 125 is 1, so Fx(125)-Fx(95) = 1.
You want Prob( x<100 ) = Fx(100)-Fx(95). Then raise that to the eighth power.
Yes that's correct answer. But I still don't understand how I can get different values for C?
You are not calculating Fx correctly. You are not taking into account that fx is zero below 95. If you do it correctly, the constant from Fx(95) =0 is C=0 and the constant from Fx(125)= 1 is also C=0.
FAQ: Probability of all runners finishing within 100 minutes
What does "Probability of all runners finishing within 100 minutes" mean?
The probability of all runners finishing within 100 minutes refers to the likelihood that every runner in a race will complete the race within 100 minutes.
How is the probability of all runners finishing within 100 minutes calculated?
The probability of all runners finishing within 100 minutes is calculated by dividing the number of possible outcomes where all runners finish within 100 minutes by the total number of possible outcomes for the race.
What factors can affect the probability of all runners finishing within 100 minutes?
The main factors that can affect the probability of all runners finishing within 100 minutes include the distance of the race, the skill level of the runners, and external factors such as weather conditions.
Is it possible for the probability of all runners finishing within 100 minutes to be 100%?
Yes, it is possible for the probability of all runners finishing within 100 minutes to be 100%, but this would require all runners to have an equal level of skill and for there to be no external factors that could affect their performance.
How can the probability of all runners finishing within 100 minutes be used in a race?
The probability of all runners finishing within 100 minutes can be used by race organizers to determine the difficulty of the race and to make adjustments to the race course or rules to increase the chances of all runners finishing within 100 minutes.
