B Probability of arranging identical objects
  • B
  • Thread starter Thread starter MeesaWorldWide
The discussion focuses on calculating the probability of arranging the letters in a word with identical objects, specifically the letters N, U, A, V, and T. The total arrangements of the 7 letters are calculated as 1260, while the arrangements with N at both ends yield two scenarios based on whether the N's are distinguished or not. If the N's are treated as identical, the probability of having N at each end is 60/1260, equating to approximately 0.048. Conversely, if they are distinguished, the probability increases to 120/1260, or about 0.095. The conversation emphasizes the importance of consistent counting rules when dealing with identical letters in probability calculations.
MeesaWorldWide
TL;DR Summary
If all the letters of the word NUNAVUT are randomly rearranged, what is the probability that there will be an N at each end?
Total ways to arrange the 7 letters: 7! / (2! x 2!) = 1260
Ways to have an N at each end: N _ _ _ _ _ N
There are 5 other letters in the middle, and two of them repeat (U), so the middle 5 are found by 5! / 2! = 60
Now, here is where I am unsure what to do. Since the N's are identical, do we distinguish between them? If we switched both the N's, there is still an N at either end, but would that be considered a separate case? If so, we do 60 x 2 = 120.
Then the probability of an N being at each end is 120 / 1260 = 0.095
If not, then the probability is simply 60 / 1260 = 0.048
Any insight here would be appreciated. 0.095 seems a bit high to me, but not treating N _ _ _ _ _ N and N _ _ _ _ _ N as different cases also makes sense...
Likes Agent Smith
The word has letters
N N
U U
A
V
T
It is not clear two N and two U are distinguished or not in our count. If we distinguish two N and two U, for an exaple by capital and lower case
N n U u A V T
I think the rule to count the cases should be shared for the investigation.
As for N n U u A V T rule, number of all the cases : 7!
N is at one edge and n is at another edge : 5! x 2
So the probality is 1/21
There's no need for counting in this case. The probability that the first letter is N is ##\frac 2 7##. And, the probability that the last letter is N, given the first letter is N, is ##\frac 1 6##. The probability of both is the product of these, hence ##\frac 1 {21}##.
Likes Agent Smith, Klystron and anuttarasammyak
PS note that calculation applies to any two chosen positions for the N's. The probability that the first two letters are both N is the same, by the same calculation. Likewise the first and third letters; or the third and sixth etc.
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
