Probability of Blue Ball from 10-Ball Urn
  • Thread starter needhelp83
  • Tags
    Probability
In summary, the conversation discusses the probabilities of drawing a blue ball from an urn with 10 balls (5 blue and 5 green) and how Michael's action of drawing a ball affects these probabilities. The initial probability is 0.5 for both blue and green, and Michael's action does not bias the answer in favor of either color. The probability of drawing a blue ball after knowing that Michael drew a blue or green ball is still 0.5.
needhelp83
199
Stuck on this question:
Suppose you know that there is an urn with 10 balls inside: 5 blue and 5 green. You believe each ball is equally likely to be drawn from the urn. Michael takes out one of the balls at random but doesn't show you which one. What probability should you assign to pulling out a blue ball from urn?
What probability would you assign before Michael takes out one of the balls?
To add to Dick's post: Does Michael's action add any new information that would let you change that initial assignment?
Alright, so the initial probability for Michael is .5 because it is either blue or green. Now Michael's action makes you believe probability of pulling out red ball is 4/9
A red ball? The urn contains only blue and green balls.
Dude! You missed that this is a magic show.
I apologize, I meant blue
How can Michael's action possibly bias the answer in favor of green?
Michael will draw a blue ball or green ball with equal probabilities, 1/2. Suppose you know he draws a blue ball. What is the probability the next ball will be blue? Now suppose you know he draws a green ball. Once again, what is the probability the next ball will be blue?
You don't know what Michael drew, but there is a way to combine those probabilities.
FAQ: Probability of Blue Ball from 10-Ball Urn
1. What is the probability of selecting a blue ball from a 10-ball urn?
The probability of selecting a blue ball from a 10-ball urn depends on the number of blue balls and the total number of balls in the urn. If there are 2 blue balls and 10 total balls, the probability would be 2/10 or 0.2.
2. What factors affect the probability of selecting a blue ball from a 10-ball urn?
The two main factors that affect the probability are the number of blue balls and the total number of balls in the urn. Other factors such as the distribution of colors and whether the balls are replaced after each selection can also impact the probability.
3. How can you calculate the probability of selecting a blue ball from a 10-ball urn?
To calculate the probability, you would divide the number of blue balls in the urn by the total number of balls. For example, if there are 3 blue balls and 10 total balls, the probability would be 3/10 or 0.3.
4. What is the difference between theoretical and experimental probability?
Theoretical probability is based on mathematical calculations and assumes that all outcomes are equally likely. Experimental probability is based on actual trials or experiments and may differ from the theoretical probability due to chance or other factors.
5. Can the probability of selecting a blue ball from a 10-ball urn ever be greater than 1?
No, the probability cannot be greater than 1. A probability of 1 means that the event is certain to occur, while a probability of 0 means that the event will not occur. A probability between 0 and 1 represents the likelihood of the event occurring.
