Probability of cosine of angle between two directions in collision
In summary, the Feynman lectures on physics Vol I chapter 39 discusses collisions between gas molecules. Feynman explains that in order to talk about the likelihood of molecules going in a certain direction, they must be compared in terms of per unit "something." This "something" is the area on a sphere centered at the collision point. Feynman then goes on to explain that all equal areas on the sphere will have an equal probability of containing molecules, leading to the conclusion that the cosine of the angle between any two directions is equally likely to be anything from -1 to 1. This is due to the fact that the differential area of a sphere is calculated using sin θ dθ, which is equivalent to the differential of
albertrichardf
165
The question refers to the Feynman lectures on physics Vol I chapter 39. He discusses collisions between gas molecules. Here is a relevant extract:
They are equally likely to go in all directions, but how do we say that? There is of course no likelihood that they will go in any specific direction, because a specific direction is too exact, so we have to talk about per unit “something.” The idea is that any area on a sphere centered at a collision point will have just as many molecules going through it as go through any other equal area on the sphere. So the result of the collisions will be to distribute the directions so that equal areas on a sphere will have equal probabilities.
Incidentally, if we just want to discuss the original direction and some other direction an angle ø from it, it is an interesting property that the differential area of a sphere of unit radius is sin ø dø times 2π. And sin ø dø is the same as the differential of - cos ø. So what it means is that the cosine of the angle ø between any two directions is equally likely to be anything from -1 to 1.
My question is how does he conclude that cos ø could be anything from 1 to -1 based on the idea that equal areas have an equal number of molecules passing through? I can't see that at all. The first paragraph just compares areas, but when he talks about cos ø he puts forth only one area: That between the two directions. So how does he go from 2 areas to one only?
Here is the link to the chapter: http://www.feynmanlectures.caltech.edu/I_39.html It is in section four.
Thanks for any answers
There is an original direction, vertically upward in his Fig. 32-1, and a new direction specified by the polar angle θ. He calculates a differential annular segment with area 2π sinθ dθ (that includes all azimuthal angles as these are equally probable by symmetry). All such annular segments will have equal probabilities to contain molecules, that is, equal numbers of molecules going through it as through any other annulus. Now it's just a mathematical fact that d(-cosθ) = sinθ dθ so any value of cosθ is equally likely to contain molecules. (It's a bit confusing that he is using ∅ in the paragraph and θ in the figure).
Likes albertrichardf
Oh alright. So essentially the cos theta comes from the coordinate system rather than the angle forming the area. Thanks for the explanation.
I'm not sure what you mean by this.
Can you please explain why you say any value of cosθ is equally likely to contain molecules (Feynman said this by saying cosθ is equally likely to be anything from -1 to +1). You mentioned that d(-cosθ) = sinθ dθ, but I don't see why this means cosθ is equally likely to be anything from -1 to +1.
Related to Probability of cosine of angle between two directions in collision
1. What is the probability of the cosine of the angle between two directions in a collision?
The probability of the cosine of the angle between two directions in a collision depends on various factors such as the properties of the objects involved, their velocities, and the angle of collision. It can be calculated using mathematical equations and simulations.
2. How does the angle of collision affect the probability of the cosine?
The angle of collision directly affects the probability of the cosine. As the angle between the two directions increases, the probability of the cosine decreases. This is because a smaller angle of collision results in a larger cosine value, which has a higher probability of occurring.
3. Can the probability of the cosine be negative?
Yes, the probability of the cosine can be negative. This can happen when the angle of collision is greater than 90 degrees, which results in a negative cosine value. However, in most cases, the angle of collision is limited to 0 to 90 degrees, resulting in a positive probability of the cosine.
4. How can the probability of the cosine be used in collision analysis?
The probability of the cosine is a useful tool in collision analysis as it can help predict the likelihood of a certain angle of collision occurring. This information can be used to design safer structures and prevent collisions with potentially damaging angles.
5. Are there any real-life applications of the probability of the cosine in collisions?
Yes, the probability of the cosine is used in various real-life applications, such as in traffic accident analysis, spacecraft collision avoidance, and sports equipment design. It is also used in physics and engineering to study the dynamics of collisions between objects.
  • Mechanics
