MHB Probability of Drawing Same-Colored Balls from a Box
The probability of drawing two balls of the same color from a box containing 2 red, 4 white, and 4 green balls is calculated by considering each color's probabilities. For red, the probability is (2/10) * (1/9). For white and green, the probabilities are both (4/10) * (3/9). Summing these probabilities gives the total probability of drawing two balls of the same color. The final result reflects the combined likelihood of drawing two red, two white, or two green balls in succession without replacement.
rymatson406
A box contains 2 red, 4 white, and 4 green two balls are drawn in succession without replacement. What is the probability that both balls are the same color?
Mathematics news on Phys.org
The probability is the sum of the probabilities:
  • 1. ball red and 2. ball red
  • 1. ball white and 2. ball white
  • 1. ball green and 2. ball green
The probability "1. ball red and 2. ball red":
The probability to pick a red ball from the box which contains $10$ balls, where $2$ of them are red, is $\displaystyle{\frac{2}{10}}$.
Now there are $9$ balls left in the box and $1$ of them is red.
So the probability for the second ball to be red is $\displaystyle{\frac{1}{9}}$.
Therefore the probability "1. ball red and 2. ball red" is equal to $$\frac{2}{10} \cdot \frac{1}{9}$$Do the same for the two other cases, and you get:
$$\frac{2}{10} \cdot \frac{1}{9}+\frac{4}{10} \cdot \frac{3}{9}+\frac{4}{10} \cdot \frac{3}{9}$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
