keyzan
- 32
- 9
- Homework Statement
- 1.Determine the probability of finding the particle in the right half of the hole at ##t=0##.
- Relevant Equations
- ##|\psi \rangle = \frac{1}{\sqrt{2}}[|1\rangle + |2\rangle]##
Hi guys it's me again. I need help with this exercise which reads: a particle of mass m, placed in an infinite rectangular one-dimensional potential well that confines it in the segment between ##x = -\frac{a}{2} and x=\frac{a}{2}##, is at instant ##t=0## in the state:
Where kets 1 and 2 are normalized and represent the ground and first excited state.
My solution:
1) I first project the state into the coordinate representation:
##\psi(x) = \langle x|\psi \rangle = \frac{1}{\sqrt{2}}[\langle x|1\rangle + \langle x|2\rangle]##
I replace ##\psi_1(x)## and ##\psi_2(x)## in the formula, knowing that:
##\psi_1(x) = \sqrt{\frac {2}{a}} cos(\frac{\pi x}{a})##
##\psi_2(x) = \sqrt{\frac {2}{a}} sin(\frac{2\pi x}{a})##
I obtain:
##\psi(x) = \frac{1}{\sqrt{2}}[\sqrt{\frac {2}{a}} cos(\frac{\pi x}{a}) + \sqrt{\frac {2}{a}} sin(\frac{2\pi x}{a})]##
2) At this point to obtain the required probability I must integrate the framework module of ##\psi(x)##. But ##\psi(x)## it's real. As a result I have:
##P_r = \int_0^{\frac{a}{2}} (\frac{1}{\sqrt{2}}[\sqrt{\frac {2}{a}} cos(\frac{\pi x}{a}) + \sqrt{\frac {2}{a}} sin(\frac{2\pi x}{a})])^2 dx##
I think the calculations I made are right. I get as a result: ##P_r = \frac{3\pi a^2 + 4a^2}{24\pi}##
3) Now if i calculate the Prob for the left side of the potential hole i obtain: ##P_l = \frac{3\pi a^2 - 4a^2}{24\pi}##
The sum has to be equal to 1, but: ##P_{tot} = P_r + P_l= \frac{3\pi a^2 + 4a^2}{24\pi} + \frac{3\pi a^2 - 4a^2}{24\pi} = \frac {3a^2}{24}##
Either I did something wrong or my reasoning is wrong. Or I need to enter a normalization constant in ##\psi(x)## equal to the inverse root of this constant?
My solution:
I obtain:
