B Probability of firing exactly one shot in each annular zone
  • B
  • Thread starter Thread starter WMDhamnekar
    Probability
The discussion revolves around calculating the probability of firing exactly one shot in each of three concentric zones of a circular target. Initial calculations suggest that the probability for one specific arrangement of shots is 5/432. However, since there are multiple permutations of how the shots can land in the different zones, the total probability is adjusted by multiplying by 3! (the number of permutations), resulting in 5/72. The key point is recognizing that the initial calculation only accounts for one specific arrangement, while the correct answer considers all possible arrangements. This highlights the importance of accounting for permutations in probability calculations.
WMDhamnekar
MHB
TL;DR Summary
Suppose a circular target is divided into three zones bounded by concentric circles of radius 1/3, 1/2, and 1, as illustrated in the following diagram.
If three shots are fired at random at the target, what is the probability that exactly one shot lands in each zone?
My attempt to answer this question: With the radii in the ratio ## 1: \frac12: \frac13 ##, the area of the corresponding circles will be in the ratio of ##1: \frac14: \frac19 ##. The areas of the three rings will be in the ratio of ## \frac34 : \frac{5}{36}: \frac19 ##
So, if three shots are fired at random at the target, the probability that exactly one shots lands in each zone is equal to ## \frac34 \times \frac{5}{36} \times \frac19 = \frac{5}{432}## But author said the answer is ##\frac{5}{432}\times 3! = \frac{5}{72}## How is that?
Would any member of physics forum provide me a satisfactory explanation?
WMDhamnekar said:
Summary: Suppose a circular target is divided into three zones bounded by concentric circles of radius 1/3, 1/2, and 1, as illustrated in the following diagram.
You've calculated the probability that the first shot lands in the outer area, the second lands in the middle area and the third lands in the inner area. That is not the only way you can have one in each area.
  • Wow
Likes Dale and WMDhamnekar
Using above comment, there are 6 possible permutations, giving the correct answer. Assuming no misses.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
19K
14K
25K
