Probability of getting 2 pairs
  • Thread starter cse63146
  • Tags
    Probability
In summary, if you draw 1,2,3,4, then there are 4! ways to permute it. If you draw 1,1,2,2 there aren't 4! different arrangements of that.
cse63146
452
You are dealt 4 cards (each card is numbered from 0 - 9). Each card is independed of the other card. What is the probability of getting 2 pairs?
P(2 pair) = *4C2P(1st = 2nd)P(3rd ≠ 2nd = 1st) P(4th = 3rd ≠ 2nd = 1st) = (6)(0.1)(0.9)(0.1)=0.054
Is this correct?
You need to tell us what deck the cards are being dealt from. It doesn't look like a regular deck, so it is kind of hard.
It's not really a deck per say.
You are dealt a card from a stack of 10 cards (0-9), record the number, return the card back to the deck,shuffle, and draw again. Do this until you recorded 4 numbers.
The probability of getting any number is 0.1.
That is not at all what you said in your first post.
One way to get two pair (which does NOT include "four of a kind") is to get the first two the same (the first card can be anything, then the probability the second card matches is .1), the third card different from the first two (probability .9) and the fourth card matching that (probability .1).
But the order does not matter so multiply by 4!.
P(2 pairs) = 4!(0.1)2(0.9). That makes sense. Thank you.
Just one more question.
Would the probability of getting 1 pair be:
4C2P(second card matches 1st)P(3rd card is different from 1st and 2nd)P(4th different from 3rd)
P(pair) = 4C2(0.1)(0.9)(0.8)?
4! isn't right. If you draw 1,2,3,4, then there are 4! ways to permute it. If you draw 1,1,2,2 there aren't 4! different arrangements of that.
So would a combination fit more than a permutation (ie 4 Choose 2)?
Sort of. Except now there's a subtle overcounting going on. If you pick 1 first, and then the other number 2, you are going to recount those cases when you pick 2 first and then the other number to be 1. Why don't you try counting how may different ways there are to pick two pairs and then divide by the total number of ways to pick 4 cards?
That would mean I'm counting the pairs twice. So it would be:
(ie 4 Choose 2)/2 = 3 ways of choosing?
Yes. Like I said, it's maybe more clear if you count the number of ways to choose two pair. First pick 2 numbers from the 10. Then multiply by the number of ways to distribute the first number, so C(10,2)*C(4,2), right? Then divide by the total number of ways to choose,10^4. Also if you start getting really confused, try and check by simplifying the problem. Suppose you have only 2 numbers in the deck. Now there's only 16 possible ways to choose and you can write them all down. See if your calculation also works in that case.
I figured it out. Thank you all for your help.
Related to Probability of getting 2 pairs
What is the probability of getting 2 pairs in a deck of cards?
The probability of getting 2 pairs in a deck of cards is approximately 4.75%. This means that out of every 100 hands, 4 or 5 of them will have 2 pairs.
How do you calculate the probability of getting 2 pairs?
To calculate the probability of getting 2 pairs, you need to first determine the number of ways you can get 2 pairs out of a deck of cards. This can be done by first choosing the two card values for the pairs (13 choose 2 = 78), and then choosing the suits for each pair (4 choose 2 = 6). The total number of ways to get 2 pairs is 78 * 6 = 468. Then, divide this number by the total number of possible 5-card hands (52 choose 5 = 2,598,960) to get the probability of 2 pairs.
What are the odds of getting 2 pairs in poker?
The odds of getting 2 pairs in poker are approximately 20 to 1 against. This means that for every 21 hands dealt, you can expect to see 2 pairs in one of them.
What other card combinations have the same probability as getting 2 pairs?
Other card combinations that have the same probability as getting 2 pairs include one pair and three of a kind. This is because they both have a probability of approximately 4.75% in a deck of cards.
Is it possible to get 2 pairs in a game of Texas Hold'em?
Yes, it is possible to get 2 pairs in a game of Texas Hold'em. In fact, it is a fairly common hand in this popular poker game. However, the probability of getting 2 pairs may vary depending on the number of players at the table and the specific cards that are dealt.
