Probability of getting the smallest value of cards
The discussion revolves around calculating the probability of drawing the card numbered '2' as the smallest value from a set of four cards (1, 2, 3, 4) in a game where a random number of cards (n) is drawn without replacement. Participants explore various cases for n (1 to 4) and calculate probabilities, but find discrepancies in their results compared to the expected answer of 5/24. Key points include the need to average the probabilities across all possible values of n, as each has an equal chance of being selected. The confusion arises from misinterpreting the question and the calculations related to conditional probabilities. Ultimately, the correct approach involves understanding the average probability concept and ensuring that the smallest value condition is met in each scenario.
songoku
Martin plays game with 4 cards numbered 1, 2, 3 and 4. In each round, a random sample of n cards is taken without replacement (1≤ n ≤ 4). Find the probability of getting 2 as the smallest values
Probability
There are 3 cases of getting 2 as smallest values:
(1) Taking one card (n = 1) → Probability = 1/4
(2) Taking two cards (n = 2) → Probability = 1/4 x 2/3 x 2! = 1/3
(3) Taking three cards (n = 3) → Probability = 1/4 x 1/3 x 1/2 x 3! = 1/4
Total probability = 1/4 + 1/3 + 1/4 = 5/6
But the solution is 5/24.
I don't know where my mistake is but maybe I misinterpret the question. I also don't understand how many rounds the game will take (the question says "in each round")
Thanks
You should multiply each probability by 1/4 because each probability of the sum is actually ##P(A_kB)=P(A_k)P(B/A_k)## where
##A_k##={ the event to draw k cards},
##B##={the event to get 2 as the smallest value}
and ##P(A_k)=1/4##.
and the probability of what is asked is $$P(B)=\sum_kP(A_k)P(B/A_k)$$
Also I am a bit in doubt on how you calculate ##P(B/A_k)## (though their final values seem correct to me but I calculated them in another way) if you can expand on that please.
Likes songoku
songoku said:
Homework Statement:: Martin plays game with 4 cards numbered 1, 2, 3 and 4. In each round, a random sample of n cards is taken without replacement (1≤ n ≤ 4). Find the probability of getting 2 as the smallest values
Relevant Equations:: Probability
Thanks
I suspect the assumption is that you choose ##n## uniformly from the set ##\{1,2,3,4 \}##. Then the probability is the average of the ones you calculated (including the case where ##n = 4##).
This is what @Delta2 has calculated.
Likes songoku and Delta2
BTW I think the problem asks for P(B) in one round of the game.
Likes songoku
and ##P(A_k)=1/4##.
I think I understand.
I can understand why I need to multiply my answer by 1/4 (since I need to consider the possibility of drawing 1, 2, 3 or 4 cards in one round) but sorry I don't understand the logic related to average probability. From calculation perspective, the result will be the same but when doing other practice questions, I never think of finding average probability, always probability only.
Is there any way to explain about average probability intuitively? And also is there any way to know whether we need to calculate average probability or not? Maybe my last question can be rephrased as: how can I know I need to calculate average probability in this case
Thanks
The average probability is just when you get when you have several options all with different probabilities. I would have thought the concept is self explanatory.
Likes songoku
Thank you very much for the help and explanation Delta2 and PeroK
Likes Delta2
Hi Guys. I can’t get the official answer (5/24). As far as I can tell, what I’ve done is equivalent to @Delta’s Post #2 method/formula. It’s frustrating – a consequence of old age presumably.
Can anyone point out/hint where I’ve gone wrong? Thanks.
______
Probability that n=1 is ¼ (since there are 4 equal-possibility outcomes for n (1,2,3 or 4)).
n=1. One card chosen.
Probability of the card being the ‘2’ = ¼.
Overall probability that n=1 and the ‘2’ is chosen = ¼ x ¼ = 1/16.
______
Probability that n=2 is ¼.
n=2. Two cards chosen.
Probability of one of the cards being the ‘2’ = ½ (because the six possible pairs are 12, 13, 14, 23, 24 and 34, and the ‘2’ is present in three of the six possibilities).
Probability that n=2 and the ‘2’ is chosen = ¼ x ½ = 1/8.
______
Probability that n=3 is ¼.
n=3. Three cards chosen.
Probability of one of the cards being the ‘2’ = 3/4 (because the four possible triplets are 123, 124, 134 and 234, and the ‘2’ is present in three of the four possibilities).
Probability that n=3 and the ‘2’ is chosen = ¼ x 3/4 = 3/16.
______
Probability that n=4 is ¼.
n =4. Four cards chosen.
Probability of one of the cards being the ‘2’ = 1.
Probability that n=4 and the ‘2’ is chosen = ¼ x 1 = ¼.
______
Total probability that ‘2’ is chosen = 1/16 + 1/8 + 3/16 + ¼ = 10/16 = 5/8. But his is three times too big.
AAGH. (Sound of distress. Not an acronym.)
______
Okay
Steve4Physics said:
______
______
Out of the six possibilities, 2 is the lowest in two cases. That gives ##\frac 1 4 \times \frac 1 3 = \frac 1 {12}##.
Again, out of the four possibilities, 2 is the lowest only once. So ##\frac 1 4 \times \frac 1 4 = \frac 1 {16}##
Steve4Physics said:
______
2 can never be the lowest in this case.
Steve4Physics said:
______
Likes Steve4Physics
PeroK said:
Okay
Thankyou @PeroK! I had a mental convolution.. My brain completely changed the problem into calculating the probability that a '2' was drawn - not that '2' needed to be the smallest in the draw. I need to go and lie down. Thanks again.
  • · Replies 29 ·
