Probability of hitting a bull's eye
In summary, the conversation discusses a practice problem for the FE exam that involves calculating the probability of hitting a bull's-eye in three shots. The solution is given, but the individual wants to solve it differently. They try to find the probability of three scenarios and end up with an incorrect answer. It is then explained that assigning weightings to each possible outcome is necessary in order to get the correct answer. The conversation ends with a suggestion to use a faster and more efficient method on the exam.
JJBladester
I'm studying for the FE exam and it's been a while since I've done some of the more basic math.
One of the practice problems for the math section states:
"A marksman can hit a bull's-eye from 100 m with three out of every four shots. What is the probability that he will hit a bull's-eye with at least one of his next three shots?"
I don't know of any.
The solution has been given but I want to solve it differently. The book's solution states:
P(miss) = 1- P(hit) = 1 - 3/4 = 1/4
P(at least one) = 1 - P(none) = 1- ((P(miss) X P(miss) X P(miss)) = 1- (1/4)(1/4)(1/4) = 63/64
I want to solve the problem by calculating and then summing the three probabilities:
P{at least 1 hit in 3 shots} = P{1 hit in 3 shots} + P{2 hits in 3 shots} + P{3 hits in 3 shots}
So my problem is how to find the probability of these three scenarios. I tried mapping out what different combinations there could be and found 8. See below (1 = hit, 0 = miss, column = attempt #).
0 0 0
0 0 1
0 1 0
0 1 1
1 0 0
1 0 1
1 1 0
1 1 1
I thought the answer would be:
P{1 hit in 3 shots} + P{2 hits in 3 shots} + P{3 hits in 3 shots} = 3/8 + 2/8 + 1/8 = 3/4
... but it's not. How do I factor the P(hit) = 3/4 into the above equation?
You need to assign the relative probabilities weightings to each of those 3 shot possible outcomes.
IE
0 0 0 would be (1/4)*(1/4)*(1/4)
0 0 1 would be (1/4)*(1/4)*(3/4)
etc
so you would end up with (1/4)*(1/4)*(3/4) * 3 + (1/4)*(3/4)*(3/4) * 3 + (3/4)(3/4)(3/4) = 63/64
Likes 1 person
Also, how do you get, using your method, P(2 hits in 3 shots) = 2/8 ?
What matters in my question is that is clearly shows that you do not attempt even the simplest double-check on your work, and that will cause you grief in ALL problems. From your table, there are 7 ways out of 8 that there is at least one hit, so it should have jumped out at you that an answer of 6/8 (using your method) could not be correct.
cpscdave: Thank you! It makes sense now.
phinds: It did jump out at me that my answer was not correct. That's why I posted for help on physicsforums. Intuitively, if the marksman can hit 3/4 of his shots, he should have way more than a 0.75 probability of hitting at least one out of three shots. This is why I knew I was traveling down the wrong road and why I asked for help.
There are two ways of computing ##P(A)## for an event ##A##: (i) directly; and (ii) indirectly, by using ##P(A) = 1 - P(A^c)##, where the event ##A^c## is the complement of ##A##. In your case, (ii) is a much faster and more efficient method than (i)---and you did it correctly---but if you have the luxury of time you can also try (i) (which was giving you trouble). On an exam, faster and easier is the way to go, unless you are specifically told otherwise.
Thanks Ray. According to my study materials and various study websites, the FE allows slightly less than three minutes per question so I will focus my efforts on time-saving advice like what you mentioned. I couldn't have done this in any less than 10 minutes without a shortcut (using the compliment of A).
Related to Probability of hitting a bull's eye
1. What is the definition of a "bull's eye" in this context?
In this context, a "bull's eye" refers to the center or desired target of an aim or shot.
2. How is the probability of hitting a bull's eye calculated?
The probability of hitting a bull's eye is calculated by dividing the number of successful outcomes (hitting the bull's eye) by the total number of possible outcomes (all possible shots).
3. What factors influence the probability of hitting a bull's eye?
The factors that influence the probability of hitting a bull's eye include the distance from the target, the precision of the aiming mechanism, the skill of the shooter, and any external factors such as wind or terrain.
4. Is it possible to have a probability of hitting a bull's eye greater than 1?
No, a probability cannot be greater than 1. A probability of 1 means that an event is certain to occur, while a probability of 0 means that an event is impossible to occur.
5. Can the probability of hitting a bull's eye be improved through practice?
Yes, with practice and improvement in shooting skills, the probability of hitting a bull's eye can be increased. However, other factors such as distance and external factors may also play a role in the probability of hitting a bull's eye.
