MHB Probability of identifying both defective fuses in four or less tests
The discussion revolves around calculating the probability of identifying both defective fuses within four tests from a set of six fuses, two of which are defective. The original poster believes the probability is 2/5, while the textbook states it is 7/15. Participants suggest using the complement rule and consider additional cases, including the scenario where all four tested fuses are good, which was initially overlooked. By correctly accounting for all possible combinations, including the missed case, the probability is confirmed to be 7/15, aligning with the textbook answer. The collaborative effort highlights the importance of thoroughness in probability calculations.
boosewell
This question is driving me crazy.
According to the textbook, the answer is 7/15, but I get 2/5. If anyone can tell me where I am going wrong I would be much obliged
Here is the question
Six fuses, of which two are defective and four are good, are to be tested one after another in random order until both defective fuses are identified.
Find the probability that the number of fuses that will be tested is four or less.
And this is my answer
Assuming two fuses need to be tested, the combination should be
Bad – bad = 2/6 x 1/5 = 2/30 = 1/15
Assuming three fuses need to be tested, the combinations should be
Bad – good – bad = 2/6 x 4/5 x 1 /4 = 8/120 =2/30 = 1/15
Good - bad – bad = 4/6 x 2/5 x 1 /4 = 8/120 =2/30 = 1/15
Assuming four fuses need to be tested, the combinations should be
Bad – good -good – bad = 2/6 x 4/5 x 3 /4 x 1/3 =24/360 = 1/15
Good - bad -good – bad = 4/6 x2/5 x 3 /4 x 1/3 =24/360 = 1/15
Good - good -bad – bad = 4/6 x3/5 x2 /4 x 1/3 =24/360 = 1/15
1/15 + 1/15 + 1/15 + 1/15 + 1/15 + 1/15 = 6/15
And I know that it is wrong because the textbook says so, but I can't think why.
Any help would be greatly appreciated.
Mathematics news on Phys.org
Re: Discrete ramdom variables
Hi boosewell,
Welcome to MHB! Glad you found us! Please let me know if you have any questions.
Your calculations look good, but maybe incomplete. What about the case of testing 3 fuses? :)
We could take another approach, and use the complement's rule. This way we need only consider two case: that it takes 5 tests or it takes 6 tests.
In order for it to take 6 tests, we would need to have 2 groups of fuses...the first group would consist of 5 fuses with one bad among them, and the second group would contain 1 bad fuse. How many ways can we arrange the fuses like this? We'll call this $N_6$.
In order for it to take 5 tests, we would need to have 3 groups of fuses...the first group would have 3 good and 1 bad, the second group would have 1 bad, and the third group would have 1 good. How many ways can we arrange the fuses like this? We'll call this $N_5$.
Then we consider how many total ways there are to arrange the 6 fuses. We'll call this $N$.
Then we can use the complement's rule...we know it is certain it will either take 4 or fewer tests or it will take more than 4 tests...and so we may state:
$$P(X\le4)+\frac{N_5+N_6}{N}=1$$
Hence:
$$P(X\le4)=1-\frac{N_5+N_6}{N}$$
Correctly calculating $N_5,\,N_6,\,N$ will yield:
$$P(X\le4)=\frac{7}{15}$$
I wanted to leave calculating those values for you to try first. :)
Bingo !
Thanks MarkFL
and, because my earlier thank you post appears to have gone astray, thanks as well to Jameson.
I think that I am going to enjoy this site.
Doh. Well my reading comprehension could use some work because you wrote about the 3 fuse case in your post. I missed it in between the lines breaks. MarkFL's way definitely works but so should your way. Let me see where the error is. You definitely have the right idea, so it's something small...
Thanks to the help of I like Serena, here is what we missed.
There is also the 4 case of GGGG. If you identify all 4 good fuses, then the remaining 2 must be bad. The probability of this is $\frac{4}{6}\frac{3}{5}\frac{2}{4}\frac{1}{3}=\frac{1}{15}$. Now the answer adds up to 7/15 as the book indicates. :)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
