MHB Probability of same results for 2 pools
  • Thread starter Thread starter FrankP
    Probability
The probability of one person buying a single ticket for two different football pools and ending up with the same numbers is calculated by considering the random assignment of numbers in a 10x10 grid. Each pool has 100 distinct cells, and the chance of matching a specific number on both tickets is 1/100. The arrangement of numbers does not affect the probability since the values are randomly assigned. The discussion suggests that the complexity of the problem may be overstated, as the core probability remains straightforward. Ultimately, the chance of matching numbers across two different pools is simply 1% if the values are identical.
FrankP
The question is “What is the probability of one person buying a single ticket for two different football pools and ending up with the same numbers”?
The football pool used is a 10 by 10 array with the numbers 0 through 9 randomly assigned along the x and y axis. One axis is team A, the other team B. There are 100 cells to be purchased individually and assigned randomly. You win if, at the end of a quarter, the last digit of the scores correspond to your purchased cell(s). Example: if you are assigned the cell corresponding to 3 for team A and 7 for team B, you will win if, at the end of a quarter, the score is team A is 23 and team B is 17.
You purchase one cell for one pool and one cell for a separate pool and are randomly assigned the same exact results (team A 7 and team B 3) for each even though the axis numbers were random and different for both and the cell randomly assigned was different for both.
What are the chances of this happening?
I'm thinking the possible number of ways these two pools can be created is 100! squared but that's as far as I can get.
Mathematics news on Phys.org
Hi FrankP,
Hmm, I might be missing something about the problem but this could be a lot simpler than it seems. So each card is a 10x10 grid with 100 distinct values. You get 1/100 on one card and 1/100 on the other. So assuming you know you have 1 value, the chance of getting the matching value on the other card is 1/100.
This is if the cards have the exact same values of course, but as I understand it that is true. The layout doesn't matter if it's completely random. The last digit of the score also doesn't matter since the grid is pre-defined as 0-9 and A,B.
Am I missing something about the question? Sometimes we like to do analysis on the last digit of a number and how probability works with that, but I don't see that here.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
