Probability of Vacation Employment During Christmas Holidays
In summary, during the Christmas holidays, 42 out of 85 students found vacation employment while the remaining 73 students went away on holiday. Assuming that every student had at least a job or went on a holiday, the probability of a randomly selected student working through the holidays (not going away on holiday) given that he/she had a job is 30/85 or approximately 35.29%. This is calculated by subtracting the number of students who both had a job and went on holiday (30) from the total number of students who had a job (73), and then dividing by the total number of students (85).
Saracen Rue
150
During the Christmas holidays, 42 students from a group of 85 students found vacation employment while 73 students went away for holidays. Assuming that every student had at least a job or went on a holiday, what is the probability that a randomly selected student worked through the holidays (that is, did not go away on holidays), given that he/she had a job.
I'm not sure if all of these are needed for this specific question, but I'm going to post every equation I was given just in case:
  • Pr(A) = Pr(A|B)Pr(B) + Pr(A|B')Pr(B')
  • Pr(A) = Pr(A∩B) + Pr(A∩B')
  • Pr(A|B) = Pr(A∩B)/Pr(B)
  • Pr(A∪B) = Pr(A) + Pr(B) - Pr(A∩B)
  • Pr(A∪B) = n(A∪B)/n(http://www.cimt.plymouth.ac.uk/projects/mepres/book7/bk7i1/s4univ.gif)
First, I wrote out the information I knew;
n(http://www.cimt.plymouth.ac.uk/projects/mepres/book7/bk7i1/s4univ.gif) = 85
A = students who worked = 42
B = students who went away = 73
Pr(A) = 42/85
Pr(B) = 73/85
Next, I solved for Pr(A∪B):
Pr(A
Pr(A∪B) = 115/85
I then attempted to plug 115/85 into the equation Pr(A∪B) = Pr(A) + Pr(B) - Pr(A∩B) and solve for Pr(A∩B), but I encountered a problem...
115/85 = 42/85 + 73/85 - Pr(A∩B)
115/85 = 115/85 - Pr(A∩B)
0 = Pr(A∩B)
As you can see, using the equation results in Pr(A∩B) = 0. However, I know this cannon be true as A+B > n(http://www.cimt.plymouth.ac.uk/projects/mepres/book7/bk7i1/s4univ.gif).
So, I tried to just use common sense to determine Pr(A∩B); I added A and B together and took away n(http://www.cimt.plymouth.ac.uk/projects/mepres/book7/bk7i1/s4univ.gif). This left me with Pr(A∩B) = 30/85. I then used this to determine that Pr(A∩B') = 12/85 (by taking 30 away from A) and Pr(A'∩B) = 43/85. From here, I decided to attempt to solve the actual equation, which I believed would use the equation Pr((A∩B')|A).
Pr((A∩B')|A) = Pr((A∩B')∩A)/Pr(A)
Now, I needed to find Pr((A∩B')∩A), but to do that I needed to know Pr((A∩B')A).
Pr((A∩B')∪A) = n((A∩B')∪A)/n(http://www.cimt.plymouth.ac.uk/projects/mepres/book7/bk7i1/s4univ.gif)
Pr((A∩B')∪A) = 12+42/85
Pr((A∩B')∪A) = 54/85
Next, I tried to use the equation Pr(A∪B) = Pr(A) + Pr(B) - Pr(A∩B) again, but the same thing happened...
Pr((A∩B')∪A) = Pr(A∩B') + Pr (A) - Pr((A∩B')∩A)
54/85 = 12/85 + 42/85 - Pr((A∩B')∩A)
54/85 = 54/85 - Pr((A∩B')∩A)
0 = Pr((A∩B')∩A)
As you can see, this formula once again resulted giving me an answer of 0. I also just can't solve this with common sense as it's getting too complicated for me to actually understand what's going on. I think that there's something wrong with this formula, so if anyone could fix it or give me a correct one it would be much appreciated.
Also, I'm sorry if this is really obvious and I'm just being an idiot. I'm good at most areas of maths but for some reason I always struggle immensely with probability... anyway, thank you all for taking the time to read this.
Hi!
Whenever you face problems with probability questions of this sort, try to build a venn diagram (like the one I have attached).
Use the venn diagram to calculate n(A∩B) and then Pr(A∩B). Then, you will have to use your third formula because here a condition is given ---> he/she has a job. So, that means you have to calculate conditional probability.
Hope this helps
Another idea is to work out some scenarios to see what's happening:
85 students: 42 worked (43 didn't work); 73 went on holiday (12 didn't go on holiday).
Scenario 1: All 42 who worked went on holiday. So, nobody who worked didn't go on holiday. In this case, your probability would be 0.
Scenario 2: All 43 who didn't work went on holiday. So, only 30 of those who did work went on holiday. So, p = 12/42.
Scenario 3: Something in between. Of those who worked somewhere between 0 and 12 didn't go on holiday.
So, it's not the sort of problem that you thought it was. It's not a conditional probablity problem.
Can you see how to solve it? You need to make a key assumption.
The first thing I note is that 42+ 73= 115 which is larger than 85 so some students must be counted twice. In fact, 115- 85= 30 students both had a job and went away on a holiday. Of the 73 students who had a job, 73- 30= 43 also went away on a holiday.
Pr(A) = 42/85
Pr(B) = 73/85
Pr(A
Pr(A∪B) = 115/85
0 = Pr(A∩B)
0 = Pr((A∩B')∩A)
I generally find that it make everything so much easier if you use a more informative notation. In this case, say ##V =##{students who went on vacation} and ##E =##{students who were employed}. Also, let ##H =##{students who stayed home (did not go on a vacation)}. You want to know ##P(H|E)##. You are given ##P(V) = 73/85## and ##P(V \cap E) = 42/85##. Of course, ##P(H) = 1 - P(V)##.
From inclusion-exclusion we have ##1 = P(V \cup E) = P(V) + P(E) - P(V \cap E)##, so you can find ##P(E)##. Now apply the definition of ##P(V|E)## and recall that ##P(V|E) + P(H|E) = 1##.
Related to Probability of Vacation Employment During Christmas Holidays
1. What is the probability of getting a vacation employment during the Christmas holidays?
The probability of getting a vacation employment during the Christmas holidays depends on various factors such as the job market, your qualifications and experience, and the availability of job openings. It is difficult to provide an exact probability as it can vary greatly.
2. What are the factors that affect the probability of getting a vacation employment during the Christmas holidays?
Some of the factors that can affect the probability of getting a vacation employment during the Christmas holidays include your skills and experience, the demand for workers in your field, the location you are applying for jobs, and the competition from other job seekers.
3. Are there any specific industries or companies that offer vacation employment during the Christmas holidays?
Yes, there are certain industries and companies that are more likely to offer vacation employment during the Christmas holidays. These may include retail, hospitality, and event planning industries, as well as companies that experience a peak in business during the holiday season.
4. Is it better to start looking for vacation employment during the Christmas holidays in advance?
Yes, it is always best to start looking for vacation employment during the Christmas holidays in advance. This will give you a better chance of finding a suitable job and allow you to apply to multiple positions.
5. What can I do to increase my chances of getting a vacation employment during the Christmas holidays?
To increase your chances of getting a vacation employment during the Christmas holidays, you can start by updating your resume and highlighting any relevant skills or experience. Networking, applying to multiple positions, and being flexible with your availability can also help in securing a job during this time.
  • Materials and Chemical Engineering
  • Math Proof Training and Practice
11K
  • Linear and Abstract Algebra
  • STEM Academic Advising
