I Probability of White Ball in Box of 120 Balls: Solved!
In a box of 120 balls, where the expected number of white balls is 30, the probability of drawing a white ball first is calculated as 1/4. The discussion highlights confusion around the random variable X and attempts to use various statistical distributions without success. Participants suggest using the properties of expected values and indicator random variables to clarify the solution. Ultimately, the consensus is that the additional information about sampling multiple balls is unnecessary for determining the probability of the first ball being white. The question's wording is criticized for being misleading.
CGandC
Problem:
In a box there are ##120## balls with ## X ## of them being white and ## 120 - X ## being red for random variable ##X##.
We know that ## E[ X] = 30 ##. We are taking out ## k ## balls randomly and with returning ( we return each ball we take out, so there is equal probability for each ball every time we take out a ball ), for ## k \geq 2 ##.
Let ## Y ## be the number of white balls in the sample that was taken out.
What is the probability of the first ball being white?
Note: This was the first question of an old exam and there were more questions that were based on it in the exam later on ( so it might be the case that we don't need to use ## k ## here. ), none of them helped in inferring the reasoning for the answer to this problem.
The official answer was:
## E[ \frac{X}{120}] = \frac{1}{4} ##, hence the probability of the first ball being white is ## \frac{1}{4} ##
Question:
I tried different things, among them being attempting to use binomial ,negative-binomial, hyper-geometric distributions in the problem, but I kept getting stuck because I don't know what ## X ## is since it is a random variable.
Then I tried getting ahead with the following equations:
## E[ X] = \sum_{i=1}^{120} x P(X = x) ## , ## E[ X] = \sum_{i=1}^{120} P(X \geq i) ## , but I was unable to proceed.
Do you have any explanation for the answer? I'm unable to retrace the steps necessary to arrive to it so I can't figure out how to arrive at the answer.
Thanks in advance for any help!
You should review the basic properties of expected values. What is the expected value of ##aX##, where ##a## is a constant real number?
## E[ aX] = aE[ X] ##, I'm familiar with the basic properties of expected value butthese don't give a clue to why the answer is as is. All I can understand from this is that ## E[X] = 120 \cdot p ## where p is the wanted probability, but there I don't understand the reasoning for why the sum on the right-hand side of the equation is as is.
Edit: I've asked this question on mathexchange and I was told to define an indicator random variable ## X_i ## which says " the value of ## X ## is ## i ## " and then to use linearity of expectation ## E[ X]=\sum E[X_i] ##. Now I understand the solution, though the question itself was misleading and confusing.
Thanks for the help!
First think about finding P(First ball is white | X = x] : this will be an expression that involves x, call it [for my illustration] f(x)
Then P(First ball is white) = E[First ball is white | [X = x]] = E(f(x))
This should lead you through it and see where the information about E(X) is useful.
finally: this is [in my opinion] a crappily worded question: You're told that k >=2 balls will be selected and Y is the number of white balls in the sample, but nothing about that is needed for solving the problem about P(First ball is white). I see no reason the business about Y and the sample needs to be in this question
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
