Probability: Prior Distribution for a Continuous Variable
In summary, the prior distribution represents Jon's initial belief about θ and the posterior distribution is the updated belief after observing the actual value of x.
Master1022
611
117
When Jane started class, she warned Jon that she tends to run late. Not just late, but uniformly late. That is, Jane will be late to a random class by ##X## hours, uniformly distributed over the interval ##[0, \theta]##. Since the class is one hour long (fractions be banished!), Jon decides to model his initial belief about the unknown parameter ##\theta## by a uniform density from zero to one hour. (a) Jane was ##x## hours late to the first class. How should Jon update his belief about ##\theta##? In other words, find the posterior ##f(\theta|x)##. Roughly sketch the result for ##x = .2## and for ##x = .5##.
Probability
Hi,
I was attempting this problem from the MIT OCW website probability and statistics course.
Context: When Jane started class, she warned Jon that she tends to run late. Not just late, but uniformly late. That is, Jane will be late to a random class by ##X## hours, uniformly distributed over the interval ##[0, \theta]##. Since the class is one hour long (fractions be banished!), Jon decides to model his initial belief about the unknown parameter ##\theta## by a uniform density from zero to one hour. (a) Jane was ##x## hours late to the first class. How should Jon update his belief about ##\theta##? In other words, find the posterior ##f(\theta|x)##. Roughly sketch the result for ##x = .2## and for ##x = .5##.
Quick Question:
Why is the prior distribution ##d\theta##? I cannot seem to understand that.
Picture from the solution:
Thanks
!The prior distribution ##d\theta## is the probability density function (PDF) of the uniform distribution over the interval [0, θ]. It represents Jon's initial belief about the unknown parameter θ. The posterior ##f(\theta|x)## is the PDF of the updated belief about θ after observing that Jane was x hours late to the first class. The posterior can be calculated as:##f(\theta|x) = \frac{f(x|\theta)f(\theta)}{f(x)}##where ##f(x|\theta)## is the PDF of the uniform distribution from 0 to θ and ##f(\theta)## is the prior distribution. For example, if Jane was 0.2 hours late to the first class, then the posterior would be:##f(\theta|0.2) = \frac{\frac{1}{\theta} \frac{1}{1}}{\frac{1}{0.2}} = \frac{5}{\theta}##which has a peak at 0.2 and decreases monotonically as θ increases. If Jane was 0.5 hours late to the first class, then the posterior would be:##f(\theta|0.5) = \frac{\frac{1}{\theta} \frac{1}{1}}{\frac{1}{0.5}} = \frac{2}{\theta}##which has a peak at 0.5 and decreases monotonically as θ increases.
