Probability problem, 10 ball are in an earn.
XZlIG9ubHkgb25lIHdoZXJlIHRoaXMgd29ya3MgaGVyZSBpbiB0aGUgY2FtZSBjb25maWd1cmF0aW9uLiBBbHNvIGFzIHRoZSBjYW1lIGlzIGFubm91bmNlZCB0byB0aGUgZGVtYW5kcy4gQWxzbywgbm90IGFsc28sIHNlZWluZyBvbiB0aGUgY29pbiBmbGlwcGVkIG9wdGlvbiBvZi
Whitebunny
Ten balls are in an urn; five red and five blue. When a red ball is removed, it is always
replaced. When a blue ball is removed a coin is flipped. If heads appears the ball is not
replaced. If tails appears, then two blue ones are placed into the urn. What is the
probability that the first three balls drawn are the same color?
I honestly have no idea. Very sorry.
Draw 1
Red 50% chance, Blue 50% (heads 50%, tails 50%)
Draw 2 (this is where I get confused)
if first draw red then, Red 50% chance, Blue 50% (heads 50%, tails 50%)
if first draw blue and tails then, Red 5/11, blue 6/11 (heads 50%, tails 50%)
If first draw blue and heads then, Red 5/9, blue 4/9 (heads 50%, tails 50%)
Draw 3
if first draw red, if second draw red then, Red 50% chance, Blue 50%
if first draw red then, and second draw is blue and tails then, Red 5/11, Blue 6/11
If first draw red, and second draw is blue and heads then, Red 5/9, Blue 4/9
If first draw is blue and tails, and second draw is red, then Red 5/11, Blue 6/11
If first draw is blue and tails, and second draw is blue and tails, then Red 5/12, Blue 7/12
If first draw is blue and tails, and second draw is blue and heads, the Red 50% chance, Blue 50%
If first draw is blue and heads, and second draw is red, then Red 5/9, Blue 4/9
If first draw is blue and heads, and second draw is blue and tails then, the Red 50% chance, Blue 50%
If the first draw is blue and heads, and the second draw is blue and heads, then Red 5/8 chance, Blue 3/8
Then I multiply everything together (?)
.5*.5*.5*.5*5/11*6/11*5/9*4/9*.5*.5*5/11*6/11*5/9*4/9*5/12*7/12*.5*.5*5/9*4/9*.5*.5*5/8*3/8
=itty bitty number that can’t possible be the answer.
Set up a tree:
R B
R B R B
R B R B R B R B
Calculate the probability, step by step, of each of those 8 outcomes.
HallsofIvy said:
Set up a tree:
R B
R B R B
R B R B R B R B
Are you sure this works here? Because of the coin flipping and removal, shouldn't there be more possible outcomes? Could you please elaborate a bit more? I really don't understand...:confused:
Draw 1
Draw 3
Try to do it systematically. Let's look at the contents of the urn *after* the first event.
[tex]
\begin{array}{ccc}
\text{first event}&\text{probability} & \text{new contents}\\ \hline
\text{red} & 1/2 & \text{5 red, 5 blue}\\
\text{blue,heads} & 1/4 &\text{5 red, 4 blue}\\
\text{blue,tails}& 1/4 & \text{5 red, 6 blue}
\end{array} [/tex]
So, before drawing the second ball the urn has either 5 red and 5 blue, or 5 red and 4 blue, or 5 red and 6 blue, and you have probabilities of each. Now you can look at what happens after drawing the second ball, etc., etc. Essentially, there will always be 5 red balls, so you can just look at the number of blue balls at each stage. If you have studied Markov chains, this would be an obvious example; if not, you can just do it manually. It really is not too bad: you are asked to find the probability that all three balls drawn are the came color. So the drawings are either RRR or BBB. Getting P{RRR} should be easy. Getting P{BBB} needs a bit more work, along the lines of what I showed above. In getting P{BBB} the color is always blue, so the only factors you need worry about are the first two coin-toss results; you should ask yourself whether HT and TH would each give the same answer.
RGV
FAQ: Probability problem, 10 ball are in an earn.
1. What is the probability of selecting a red ball from the urn?
The probability of selecting a red ball from the urn depends on the total number of red balls and the total number of balls in the urn. If there are 10 balls in the urn and 2 of them are red, the probability would be 2/10 or 1/5.
2. What is the probability of selecting a blue ball after selecting a red ball?
The probability of selecting a blue ball after selecting a red ball depends on the number of red and blue balls in the urn. If there are 2 red balls and 3 blue balls in the urn, the probability would be 3/9 or 1/3.
3. What is the probability of selecting a green ball if 3 balls are removed from the urn?
The probability of selecting a green ball after removing 3 balls from the urn depends on the remaining number of green balls and the total number of remaining balls. If there are 5 green balls and 7 balls remaining in the urn, the probability would be 5/7.
4. If 2 balls are randomly selected from the urn, what is the probability that they are both yellow?
The probability of selecting two yellow balls from the urn depends on the total number of yellow balls and the total number of balls in the urn. If there are 10 balls in the urn and 4 of them are yellow, the probability would be (4/10) * (3/9) or 2/15.
5. How many different combinations of balls can be selected from the urn?
The number of different combinations of balls that can be selected from the urn depends on the number of balls in the urn and the number of balls that are being selected. In this case, with 10 balls and selecting 2 at a time, there would be 10 choose 2 or 45 possible combinations.
