Probability problem(minmal paths sets and cuts sets
In summary, In my method, I use the inclusion/exclusion principle to combine the probabilities of X1 and X2. Because they are not mutually exclusive, this results in a incorrect joint probability.
Sadeq
107
The solution attempt in the attacment
thank you in advance
The same failure (e.g. of A) occurs at more than one place in your expression. Looks to me that your calculation treats these as independent, which would be wrong.
Try breaking it up as:
P[A fails] * P[circuit fails given that A fails] + P[A does not fail] * P[circuit fails given that A does not fail]
First of all many thanks
But there is something that i can't understand,which is my tutor told me we use minmal path sets for determine reliability and mimmal cut sets to determine failure
and he implement this in the class method and it works however here does not work,
So can i conclude that the method he gave me can't be use anywhere or there is something missing in my mind
I attached the class example to have alook on it and understand what I am saying
  • 1.pdf
The example in the PDF made it look easy because it was such a simple circuit.
There is nothing wrong with the principle of cutsets/minimal paths; the problem is with evaluating the probability expression.
In the OP, you have P[(Af & Bf) v (Af & Df) v (Cf & Df)]. This is awkward because you have the same event occurring in more than one place in the expression. In order to multiply probabilities, the events must be independent; in order to add them they must be disjoint (or you must correct for the double counting using the principle of inclusion/exclusion as is done in the PDF).
In this more complicated case you can write
P[(Af & Bf) v (Af & Df) v (Cf & Df)] = P[(Af & Bf) v (Af & Df) v (Cf & Df) | Af] * P[Af] + P[(Af & Bf) v (Af & Df) v (Cf & Df) | ~Af] *(1-P[Af])
= P[Bf v Df v (Cf & Df)] * P[Af] + P[Cf & Df] *(1-P[Af])
= P[Bf v Df] * P[Af] + P[Cf & Df] *(1-P[Af])
From there it's straightforward.
Please bare with me,if i understand you ,you said that i should use inclusion and exclusion principle,and i agree with this,the following attachment show that i use this method,but answers still different,
Please be patient,because i need to understand the problem in my understanding
The principle says you add up the probs of X1 and X2, for example, but because they're not mutually exclusive you have to subtract the probability of X1 & X2 (because you've counted that twice). If X1 and X2 are independent, the joint probability is the product of the two probabilities. But here, some of the terms you're treating that way are not independent (e.g.because they both refer to A). So it isn't simply X1 prob * X2 prob. That's why you get the wrong answer.
Great ,i UNDERSATND NOW,big thanks to you
So because they are independent i can't use this method , so what will be the solution for this problem?
Many thanks again
Many thanks again
You can still use the inclusion/exclusion principle, but you have to calculate the joint probabilities correctly. The problem is that they are NOT independent in this circuit.
To sum up:
Principle of inclusion/exclusion, quite general (two event case for simplicity):
P[X v Y] = P[X] + P[Y] - P[X & Y]
There are three special cases which make this simpler:
If X and Y are mutually exclusive, P[X & Y] = 0
If X and Y are independent, P[X & Y] = P[X]*P[Y]
If X implies Y, P[X & Y] = P[X]
For the circuit you have, none of these apply. Can you understand the method I used a couple of posts ago?
Exactly it works man,your are brilliant and thank you
May i ask you why you choose A and consider it as bridge(onetime works and other fails)
Why spesfically A
I think because A make the whole problem and it makes events non independent
I'm i right!
I chose A because it appeared frequently in the expression. Fixing its value was sure to simplify things quickly. Glad to have helped.
Brother i was reading in a book and i saw an example regarding to what we were speaking about
and here the events are not mutally exclusive , because you can see {A} event seveal times
So why this method works here
explain please
IM lost
He's doing the same thing a slightly different way.
First, he adds up the four probabilities for the OR conditions. But then he has to subtract out the probs of the pairwise combinations of these. This is the inclusion/exclusion principle at work. Look at one example of these pairs: (A&B) & (A&C&E). He reduces this (behind the scenes) to (A&B&C&E) before computing the probability: qA*qB*qC*qE.
In my method, I simplified the logic combination before applying inclusion/exclusion. It's a matter of whichever you're more comfortable with.
Thank you very much,
Unfortuantily now i am confused so please bar with me, i use exactly the book method to solve the problem i rise in the upper posts and the answer were differnent if u try to solve them usiing minmal bath sets and minmal cut sets as he did, i also inclusion and exclusion principle in my solution
Seems strange
PLEASE HELP ME i have a lot of coursework to be done and i have to understand this in order to be able to proceed
Please post your working for the two methods (or send it to me through the Forum's email service) and I'll see if I can spot what's going wrong.
this the solution brother and i use the same exclusion and inclusion principle
so please help me man and explain in details
please
OK, you're still making the mistake of calculating joint probability as though events are independent when they're not.
P((A&D)v(A&C)v(B&D)) = P(X1vX2vX3) = P(X1) + P(X2) + P(X3) - P(X1&X2) - P(X2&X3) - P(X3&X1) + P(X1&X2&X3)
So far so good. But then you turn P(X1&X2) into P(X1)*P(X2). You can't do that because X1 and X2 are not independent.
P(X1&X2) = P((A&D)&(A&C)), which simplifies to P(A&D&C). Do you see why?
So P(X1&X2) = P(A)*P(D)*P(C) = 0.729 (because A, C and D are independent).
So with p = 0.9, P((A&D)v(A&C)v(B&D)) = 3*p^2 - p^3 - p^3 - p^4 + p^4 = 0.972
FAQ: Probability problem(minmal paths sets and cuts sets
What is a probability problem involving minimal paths sets and cuts sets?
A probability problem involving minimal paths sets and cuts sets is a mathematical problem that requires finding the probability of a certain event occurring in a given system, where the system is represented by a graph with nodes and edges. The minimal paths sets refer to the collection of all possible paths between two designated nodes, while the cuts sets refer to the collection of all possible ways to divide the graph into two subsets of nodes.
How are minimal paths sets and cuts sets used in probability problems?
Minimal paths sets and cuts sets are used to calculate the probability of an event occurring in a given system. By finding all the possible paths and cuts in the system, we can determine the likelihood of the event happening based on the number of paths or cuts that include the event in their set.
What is the importance of finding minimal paths sets and cuts sets in probability problems?
Finding minimal paths sets and cuts sets is important in probability problems because it helps us understand the structure of a system and how different events may occur. By analyzing the paths and cuts, we can determine the probability of certain outcomes and make informed decisions.
Can minimal paths sets and cuts sets be used in real-life applications?
Yes, minimal paths sets and cuts sets can be used in various real-life applications such as network analysis, transportation planning, and supply chain management. In these situations, analyzing the paths and cuts can help determine the most efficient and cost-effective solutions.
Are there any limitations to using minimal paths sets and cuts sets in probability problems?
One limitation of using minimal paths sets and cuts sets in probability problems is that it assumes all paths and cuts have equal probabilities, which may not always be the case in real-world scenarios. Additionally, it may become computationally challenging to find all possible paths and cuts in large and complex systems.
