Probability problem -- Number of throws of a pair of dice to get a 7
In summary, the minimum number of throws of a pair of dice to have a 95% chance of getting at least one sum of 7 is 17. This is found by calculating the probability of not getting a 7 on each throw and setting it to be less than 0.95. This ensures that there is a 95% chance of getting at least one 7 in the given number of throws.
erisedk
374
The minimum number of throws of a pair of dice so that the probability of getting the sum of the digits on the dice equal to 7 on atleast one throw is greater than 0.95, is n. Find n.
There are 6 possible ways of getting a sum of 7.
So, P(7) = 6/36 = 1/6 and P(not 7) = 5/6
For minimum number of throws, on the last throw the sum should be 7.
So,
(5/6)n-1 (1/6) > 0.95
(5/6)n-1 > 5.7
Solving for n gives an incorrect answer.
You are computing the probability of rolling 7 on the nth roll. Not the probability of obtaining at least one seven in n rolls.
But wouldn't the minimum number of throws correspond to a 7 on the last throw?
Doing what you said does give the right answer--
1- (5/6)n < 0.95
n= 17
But I don't understand
They are not asking for having a 7 on the last throw. They are asking how many throws you have to make to have a 95% chance of getting at least one seven, the seven can be in any of those throws (or several).
Okey got it! Thanks :)
FAQ: Probability problem -- Number of throws of a pair of dice to get a 7
1. How many times do I need to roll a pair of dice to get a total of 7?
The average number of rolls needed to get a total of 7 when rolling a pair of dice is 6. This is because there are 36 possible combinations when rolling two dice and only 6 of those combinations result in a total of 7.
2. What is the probability of getting a 7 when rolling a pair of dice?
The probability of getting a 7 when rolling a pair of dice is 1/6, or about 16.67%. This is because there are 6 possible outcomes that result in a total of 7 (1+6, 2+5, 3+4, 4+3, 5+2, 6+1) out of a total of 36 possible outcomes.
3. Can I influence the outcome of getting a 7 by changing the way I roll the dice?
No, the outcome of rolling a pair of dice is completely random. The way you roll the dice, such as how hard or how you hold them, does not affect the probability of getting a 7.
4. Is it possible to get a 7 on the first roll when rolling a pair of dice?
Yes, it is possible but the probability is low. The only way to get a total of 7 on the first roll is to roll a 6 and a 1, which has a probability of 1/36 or about 2.78%.
5. What is the likelihood of rolling a 7 multiple times in a row when using a pair of dice?
The likelihood of rolling a 7 multiple times in a row when using a pair of dice is the same as rolling a 7 on any single roll, which is 1/6 or about 16.67%. Each roll of the dice is independent from the previous one, so the previous outcome does not affect the probability of rolling a 7 on the next roll.
