Probability random vector, transformation
In summary, the problem involves finding the pdf of Z, where Z = X + Y, given that the pdfs of X and Y are e^(-x) and e^(-y), respectively. The probability of Z being less than or equal to 0 is not necessarily 0, and the probability of Z being less than or equal to 6 can be found by splitting the integral into two parts. The general formula for finding the pdf of Z is f(z) = ∫f(x,z-x)dx or f(z) = ∫f(z-y,y)dy.
Laura1321412
24
Let f(x,y) = e^(-x-y), 0<x< infinity, 0<y<infinity, zero elsewhere, be the pdf of X and Y. Then if Z = X + Y, compute P(Z<=0), P(Z,<=6), and, more generally P(Z<=z), for 0<z<infinity. What is the pdf of Z?
P(x,y) = ∫∫(f(x,y) dxdy
so, P(Z<= 0 ) is pretty obviously 0
P(Z<=6) = P(X+Y <= 6)
=P(X<=6-Y)
into equation
∫from (0 to infinty) ∫ from (0 to 6-Y ) e^(-x-y) dx dy
-e^(-x-y) eval from 0 to 6-Y
= (-e^-6 ) + e^-y
∫from (0 to infinity) (-e^-6 ) + e^-y dy
= -ye^(-6) -e^-y eval from (0 to infinity)
= -infinity -0 - ( 0 - 1)
= - infinity
so, I am definately going wrong somewhere because a probability of negative infinity makes no sense... I know this could be done using a different method of tranformations, but i think I am supposed to do something along these lines because that's what is taught in the preceeding chapter.
Hello, thank you for your post. Your attempt at solving this problem is on the right track, but there are a few errors that I would like to point out.
First, P(Z<=0) is not necessarily zero. Remember that Z = X + Y, so in order for Z to be less than or equal to 0, both X and Y would have to be 0. This means that P(Z<=0) would be equal to f(0,0), which is not necessarily zero.
Second, when calculating P(Z<=6), you are correct in setting up the integral as P(X<=6-Y). However, when evaluating the integral, you need to take into account the range of values for Y. Since Y can range from 0 to infinity, you need to split the integral into two parts: one from 0 to 6, and one from 6 to infinity. This is because when Y is greater than 6, the integral will evaluate to 0.
Lastly, when calculating the integral for P(Z<=z), you need to take into account the range of values for both X and Y. This means that the integral should be set up as ∫∫(f(x,y) dxdy, with the limits of integration being 0 to z for both x and y.
In general, the pdf of Z can be found by convolving the pdfs of X and Y. This means that the pdf of Z would be f(z) = ∫f(x,z-x)dx, with the limits of integration being 0 to z. This can also be written as f(z) = ∫f(z-y,y)dy, with the limits of integration being 0 to z.
I hope this helps clarify any confusion you may have had. Keep up the good work!
