Probability that a Rectangle lies within a circle
In summary: ZXJuaW5nOgogICAgSW4gc3VtbWFyeSwgUyBpcyBub3QgcmVhbGx5IGEgaGFzaCB3YXZlLCBhIGxvYWRlciBvZiByZWFsbHkgYSBsaWtlIGV4ZWN1dGVkIGFuZCB3b3JrIHRyYWNrLCBidXQgYXQgcG9pbnQgSSBmaWxlIGEgbGl0dGxlIGV4ZWN1dGVkIGp1c3RpZXMgYSBsaWtlIG
guccimane
This is not really a homework problem, I'm just doing it as an exercise puzzle. I think I'm on the right track, but at this point I feel a little exhausted and would love a hint.
Let C be a unit circle: x^2+y^2=1 . Let "p" be a point on the circumference and "q" be a point anywhere inside C. Finally, let the line p-q be the diagonal of a rectangle R, the sides of which are parallel to the x and y axes. What's the probability that ALL points within R lie within C?
Presumed steps: 1,2,3, ?, ... n) integrate some density function, get answer.
Given answer: 4/(pi^2)
(t:="theta")
I'm pretty certain that 1) and 2) are right:
1) Find the Cartesian coordinate representation of the 4 vertices of R:
p= (cos(t), sin(t)); q= (a, b); p'= (cos(t), b); q'= (a, sin(t))2) We know that p and q are within the disk C, so we need the conditions under which p' and q' lie in C:
for p' : cos^2(t) + b^2 < 1 i.e |b|<|sin(t)|
for q' : a^2 + sin^2(t) < 1 i.e. |a|<|cos(t)|3) Next is my attempt to find the following probabilities:
Letting 0≤ t ≤ pi/2 -- trying to stay in the first quadrant;
P(|b|<|sin(t)|) = (∫[0..cos(t)] of √(1-x^2) dx) / (pi/4)
= (1/2*(cos(t)(sin(t)) + pi/2 - t)/ (pi/4)
P(|a|<|cos(t)|) = (∫[0..sin(t)] of √(1-y^2) dy) / (pi/4)
= (1/2*(cos(t)(sin(t)) + t) /(pi/4)4) One has to find the probability of the intersection of the two events in (3).
My initial though was to multiply the two probability function in (3) and then integrate from 0 to pi/2; Result: wrong answer.
In my second attempt, I tried first differentiating the two probability functions, then multiplying them together, then integrating from 0 to pi/2.
(Don't ask why - I guess I thought differentiating them would make them look like density functions ... or something). Result: Wrong answer.
My solution fell off the rails 4 - or perhaps at 3 in some ridiculously elementary way(s). This a somewhat basic problem that should conclude in the integration of a prob.-dens. function.
I'll be eternally grateful for any assistance on this!
(t:="theta")
Assume the "outer" corner is at angle t, counterclockwise from the x-axis, and assume that t is uniformly distributed on (0,2π). Assume also that the point q is uniformly distributed within the circle. If F={rectangle fits in circle} we have
[tex] P\{F\} = \frac{1}{2 \pi} \int_{0}^{2 \pi} P\{ F|t\}\, dt.[/tex]
It is clear that we can just integrate from 0 to π/2, then multiply by 4.
For 0 < t < π/2, how do we find the largest possible rectangle? Just draw a horizontal and vertical line through [itex]p = (\cos(t),\sin(t))[/itex] and see where these lines cut the circle again. That will give the largest rectangle Rt. If q lies inside Rt. the constructed rectangle with opposite corners p and q will lie completely inside the circle. The sides of Rt are of lengths 2*cos(t) and 2*sin(t), and so its area is easy to compute in terms of t. We have
[tex] P\{F|t\} = \frac{\text{Area of }R_t}{\text{Area of circle}}.[/tex]
RGV
FAQ: Probability that a Rectangle lies within a circle
What is the formula for calculating the probability that a rectangle lies within a circle?
The formula for calculating the probability that a rectangle lies within a circle is (Area of rectangle)/(Area of circle).
How can you determine if a rectangle lies within a circle?
To determine if a rectangle lies within a circle, you can compare the diagonal length of the rectangle to the diameter of the circle. If the diagonal length is smaller than the diameter, then the rectangle lies within the circle.
What factors can affect the probability of a rectangle lying within a circle?
The factors that can affect the probability of a rectangle lying within a circle include the size and shape of the rectangle and circle, the position of the rectangle within the circle, and any overlapping or intersecting edges.
Can the probability of a rectangle lying within a circle be greater than 1?
No, the probability of a rectangle lying within a circle cannot be greater than 1. Probability is a value between 0 and 1, where 0 indicates impossibility and 1 indicates certainty.
How can the concept of probability that a rectangle lies within a circle be applied in real life?
The concept of probability that a rectangle lies within a circle can be applied in various fields such as architecture, engineering, and surveying. It can be used to determine the likelihood of a structure fitting within a designated area, or to estimate the chances of a certain event occurring based on the dimensions of the objects involved.
