Probability that bulb is defective questions
Sorry.The probability is 9 / 100I think that the easiest way to think about it is 1. We see that there are 20 of 40 watt bulbs and 80 of 60 watt bulbs. Then, we pick 10 bulbs. 2. Now, there are 10 different positions for exactly 2 40 watt bulbs. We can choose 2 positions from 10 positions. So, the number of ways to pick 2 40 watt bulbs from 10 bulbs is 10C23. After choosing 2 positions for 40 watt bulbs, we have 8 positions left. So, we need to pick 8 bulbs from 80 bulbs. So, the number of ways
schapman22
74
There are 100 light bulbs in a box. 20 are 40 watt, the rest are 60 watt.
If we randomly choose 10 bulbs, what is the probability that there will be exactly 2 40-watt bulbs?
What is the probability that in a random sample of 10 bulbs there will be at least 1 40-watt bulb?
and then i am also having trouble with this one
75% of a certain part is supplied by vendor A and 25% by vendor B. Vendor A's defect rate is 0.01 and vendor B's defect rate is 0.03.
If a part is from vendor A, what is the probability it is defective?
What is the probability that a randomly chosen part will be defective and from vendor A?
What is the probability that a randomly chosen part will be non-defective and from Vendor B?
I think that these are nCr problems but I am very confused by these problems, if someone could explain them to me that would be amazing, thank you so much.
The probability that the first is 40 watt is, of course, 20/100= .2. That would leave 99 bulbs with 19 of them 40 watt. The probability that the second bulb is also 40 watt is 19/99 so that both first and second will be 40 watt is (20/100)(19/99). That leaves 98 bulbs of which 80 are NOT 40 watt so the probability the third is NOT 40 watt is 80/98, the probabiility the fourth is not 40 watt is 79/97, the probability the fifth is not 40 watt is 78/96, etc. That is the probability of the first two being 40 Watt and the other 8 not is (20/100)(19/99)(80/98)(79/97)...(73/91).
If you apply the same analysis to, say, "4th and 6th bulbs 40 watt all others not" or "3rd and 9th bulbs 40 watt others not", etc. you should soon realize that you are just moving numbers in the numerator around and, in fact, get the same number repeatedly so you really just have to multiply that first number by the number of ways to put 2 40 watt bulbs and 8 non- 40 watt bulbs which is the "binomial coefficent" 2C10.
This is actually easier. "At least one 40-wtt bulb" is the opposite of "all 60 watt" and so is 1 minus the probability that all 10 are 60 watt.
and then i am also having trouble with this one75% of a certain part is supplied by vendor A and 25% by vendor B. Vendor A's defect rate is 0.01 and vendor B's defect rate is 0.03.
This doesn't require any calculation- it is just given: "Vendor A's defect rte is 0.01"
I would imagine 10000 parts. We are told that 75% or 7500 are from vendor A and 1% of those, or 75 are defective. So the probability is 75/1000= .075.
Same idea. If there were 1000 parts, 25% or 250 are from vendor B. 3% of those, 7.5 are defective so the probability is 7.5/1000.
Thank you so much, that was very helpful and cleared up some things.
My only question is for the first one you said to multiply .2* 2C10, however when i try to do 2C10 i get 0, or an error
Halls meant 10C2, the number of ways of choosing 2 items from 10.
... and he didn't say the answer was .2 * 10C2.
In terms of combinations, you have to choose 2 from the 10 and 8 from the 80. How many ways does that make?
That is compared with all the possible choices, namely, 10 from 100.
for 10C2 I'm geting 45, if i multiply 45*.2 I get 9, doesn't my answer have to be between 0 and 1?
My edit wasn't quite fast enough. See what I added in the previous post.
Related to Probability that bulb is defective questions
1. What is the probability of a bulb being defective?
The probability of a bulb being defective depends on various factors such as manufacturing quality, age of the bulb, and usage conditions. It is difficult to provide a precise answer without knowing these details. However, we can calculate the probability by dividing the number of defective bulbs by the total number of bulbs produced.
2. How can we determine the probability of a bulb being defective?
To determine the probability of a bulb being defective, we need to collect data on the number of defective bulbs and the total number of bulbs produced. We can then use this data to calculate the probability by dividing the number of defective bulbs by the total number of bulbs.
3. What is a confidence interval for the probability of a bulb being defective?
A confidence interval for the probability of a bulb being defective is a range of values within which we can be confident that the true probability falls. This range is based on the sample data and provides an estimate of the true probability with a certain level of confidence, typically 95%.
4. Can the probability of a bulb being defective change over time?
Yes, the probability of a bulb being defective can change over time. This can be due to factors such as changes in manufacturing processes, changes in materials used, or changes in usage conditions. It is important to regularly monitor and update the probability as needed.
5. How can we reduce the probability of a bulb being defective?
To reduce the probability of a bulb being defective, we can implement quality control measures during the manufacturing process, use high-quality materials, and regularly test and monitor the bulbs. It is also important to follow proper usage and maintenance guidelines to prolong the lifespan of the bulbs.
