Probability that energy level is occupied
In summary, there are two distributions related to fermi-dirac statistics: FD and BE. FD is used when the energy difference between the electron and the fermi level is positive, while BE is used when the energy difference is negative. At high temperatures, both distributions approach the classical limit, MB. The difference between FD and BE can be neglected in the classical regime, which occurs at high temperatures or low concentrations. This can be seen by setting some rough values for semiconductors, such as an energy gap of 1eV and a fermi level of 0.5eV. At these values, the probability can be simplified to 1/exp(20) due to the large difference between exp(20) and
unscientific
1,734
The probability that an electron is in an excited state is given:
P = e^-(energy difference)/kt
and the probability that an energy level is occupied in semi conductors is:
p = 1/ (e^(E-Ef)kt + 1)
I know both are related to fermi-dirac statistics, which one is the appropraite one to use?
Both distributions,
FD: p = 1 / (exp[(e - u)/kT] + 1)
and
BE: p = 1 / (exp[(e - u)/kT] - 1)
approach
MB: p = exp[(u - e)/kT]
at high temperatures (i.e. in classical limit).
So it depends on the temperature.
Does it answer your question? :)
uhh, I am afraid i don't get you =x
FD and BE differ by (+/-)1 factor.
This can be neglected if
exp(e - u) >> 1
which happens in classical regime,
that is at high temperatures
or at low concentrations.
You can try some rough values for semiconductors,
Setting zero at the top of valence band,
Eg ~ 1eV (energy gap)
Ef ~ 0.5eV (midway between val. and cond. band)
so E in cond. band is about 1eV
also kT ~ 0.025eV
so one gets
1/[exp(20) + 1] ~ 1/exp(20) = exp(-20)
since exp(20) is huge.
FAQ: Probability that energy level is occupied
What is the probability that a specific energy level is occupied?
The probability that a specific energy level is occupied depends on the system and the conditions under which it is observed. In quantum mechanics, the probability of finding a particle in a specific energy level is given by the square of the wave function at that energy level.
How is the probability of an energy level being occupied calculated?
The calculation of the probability of an energy level being occupied depends on the specific system and the information available. In quantum mechanics, the probability is calculated by taking the square of the wave function at that energy level.
Can the probability of an energy level being occupied change over time?
Yes, the probability of an energy level being occupied can change over time. This is because the wave function, which determines the probability, can change over time as the system evolves.
What factors influence the probability of an energy level being occupied?
The probability of an energy level being occupied can be influenced by various factors such as temperature, pressure, and the presence of other particles. In quantum mechanics, it can also be affected by the shape of the potential well and the energy of the particle.
How does the probability of an energy level being occupied relate to the energy of a particle?
The probability of an energy level being occupied is directly related to the energy of a particle. In quantum mechanics, the higher the energy of a particle, the higher the probability of it being found in a specific energy level. This is because the wave function at higher energies has a larger amplitude, resulting in a higher probability.
