Probably quite simple but i'm stuck
  • Thread starter .....
  • Tags
    Stuck
In summary, the conversation is about finding the minimum distance between a point and a line in R^3. The approach suggested involves finding a point on the line and a vector between that point and the given point, then using the scalar projection to find the distance. The main question is how to find the normal vector of the line, and different approaches are discussed. One approach involves finding two points in cartesian coordinates and using the distance formula along with calculus to minimize the distance function. Another approach involves finding the point on the line where the normal vector passing through the given point cuts it. In the end, it is suggested to use the fact that PQ, the vector between the two points, is normal to the given line to solve the problem.
I'm stuck on this question... if someone could give me a hand that'd be great..
What is the minimum distance between the point (3,-2,4) and the line defined by
x = 1 + t
y = 4 - 3t
z = -2 + 2t
My approach was to find a point on the line by letting t = 1
I got (2, 1, 0)
then I found a vector between this point and the one given:
v = i -3j + 4k
Here's a picture to clarify:
Then the distance would be the scalar projection of this vector onto the normal vecor of the line
But I'm not sure how to find the normal to the line.
Could someone show me how?
And if there's a simpler approach could you show me that too?
Thanks.
Mathematics news on Phys.org
Geometrically,can u see what is the minimum distance...?Come on,it's something i learned when i was 12...
Daniel.
A single line in R^3 doesn't have a single normal vector, since it lies on an infinite number of planes.
The way I would try this to find two points in cartesian coordinates and find the line equation in those coordinates. Then using the distance formula and some max/min calculus, minimize the distance function.
here is what i would try
[tex]L = \sqrt{(x_0-x_1)^2 +(y_0-y_1)^2 (z_0-z_1)^2 [/tex]
[tex]L = \sqrt{(1+t-3)^2 +(4-3t+2)^2 (-2+2t-4)^2} [/tex]
[tex] = \sqrt{(t-2)^2 +(-3t+6)^2 (2t-6)^2} [/tex]
[tex] = |t-2|\sqrt{36t^2-216t+325} [/tex]
Then take the derivative in respect to t. Find the critical points, and then pick the minimum one.
why not do something simpler? all you need to do is to find the point Q on the line where the normal vector passing through (3,-2,4) cuts it...that point looks like (1+t,4-3t,-2+2t) for some t. that is the t you need to find...and to do that use the fact that PQ is normal to the given line...
^^that works, i got it.
thanks a lot mansi.
FAQ: Probably quite simple but i'm stuck
What should I do if I'm stuck on a simple scientific problem?
If you're stuck on a simple scientific problem, it's important to take a step back and assess the situation. First, make sure you understand the problem and its components. Then, try breaking it down into smaller, more manageable parts. If you're still stuck, don't be afraid to ask for help or consult outside resources.
How can I prevent getting stuck on simple scientific problems?
Preventing getting stuck on simple scientific problems starts with good preparation. Make sure you have a solid understanding of the basic principles and concepts related to your field of study. Additionally, stay organized and take thorough notes to help you stay on track. Lastly, don't be afraid to ask questions and seek clarification when needed.
How do I know when a problem is actually simple or if I'm just stuck?
The line between a simple problem and being stuck can sometimes be blurred. One way to determine if a problem is actually simple is to check if it can be solved using basic principles or equations. If not, it may require more advanced techniques or outside help.
How can I improve my problem-solving skills?
Problem-solving skills can be improved through practice and persistence. The more problems you attempt to solve, the better you will become at identifying patterns and applying appropriate techniques. Additionally, don't be afraid to learn from your mistakes and seek feedback from others.
Is it okay to get stuck on a simple problem or does it reflect poorly on my abilities as a scientist?
It is completely normal to get stuck on a simple problem. In fact, it can be a valuable learning experience. It's important to not let it discourage you or reflect poorly on your abilities as a scientist. Instead, use it as an opportunity to learn and improve your problem-solving skills.
