MHB Problem about equilateral triangles
  • Thread starter Thread starter Nich6ls
    Triangles
To solve the problem of finding the ratio of the perimeters of two equilateral triangles, one triangle's side equals the height of the other. The height of the first triangle, with side length "x," is calculated as \(x\frac{\sqrt{3}}{2}\). Using the similarity of the triangles, the ratio of their perimeters is derived from the ratio of their heights, resulting in \(\frac{2\sqrt{3}}{3}\). The initial interpretation of the ratio as \(2/3\sqrt{3}\) was clarified to ensure accuracy. The final answer confirms the correct ratio of the perimeters.
Nich6ls
Hi! I need help with this exercise: A side of one equilateral triangle equals the height of a second equilateral triangle. Find the ratio of the perimeter of the larger triangle to that of the smaller. A "detailed solution" to be analysed by me then.
Answer: \[ 2/3 sqrt3 \]
Thanks
Mathematics news on Phys.org
Use the fact that triangles are similar. If $x$ represents the side of first triangle, show that the triangle's height is $x\frac{\sqrt{3}}{2}$. The second triangle has height $x$, and since the triangles are similar, the ratio of their perimeters is equal to the ratio of their heights. Conclude.
If you drop a perpendicular from one vertex of an equilateral triangle to the opposite side, you divide the equilateral triangle into two right triangles that have hypotenuse equal to the length of a side of the equilateral triangle, one leg half that length, and the second leg, whose length you can get from the Pythagorean theorem, is the altitude of the equilateral triangle. If the length of a side of the original equilateral triangle is "s" then the altitude is $\sqrt{s^2- (s/2)^2}= \sqrt{s^2- s^2/4}= \sqrt{3s^2/4}= \frac{s\sqrt{3}}{2}$.
So the first equilateral triangle has perimeter 3s while the second has perimeter $\frac{3s\sqrt{3}}{2}$. The ratio of those is $\frac{3s}{\frac{3s\sqrt{3}}{2}}= 3s\frac{2}{3s\sqrt{3}}= \frac{2}{\sqrt{3}}= \frac{2\sqrt{3}}{3}$.
(What you wrote, "2/3sqrt(3)" would correctly be interpreted as $\frac{2}{3\sqrt{3}}$, which is wrong, but I suspect you meant "(2/3)sqrt(3)"or $\frac{2}{3}\sqrt{3}= \frac{2\sqrt{3}}{3}$, which is correct.)
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
