Problem about finding the work done by friction force
In summary, the problem involves finding the work done by friction when a block of mass 3.4 kg is dragged with a force of 20.0 N over a distance of 17.0 m, with a friction force of 3.3 N. The work done is calculated by taking the dot product of the friction force and the displacement, resulting in a negative value of -56.1 Joules. The general equation for calculating work is also mentioned for reference.
sample5
A block of mass M=3.4 kg is dragged over a horizontal surface by a force F=20.0 N. The block is displaced a distance d=17.0 m, the friction force Ff is 3.3 N. What is the work done by the friction force?
Ff=μkFn
I solved a problem before this one in finding the applied force but this one is very confusing to me. I have no idea where to even start. Thank you!
Work done by friction is always negative. The work done by a constant force is always the dot product of the force multiplied the displacement whether or not the force is the cause of the displacement. So the work done would be -3.3*17 = -56.1 Joules.
Why don't we start with recalling how to calculate the work done by any Force?
[itex] \Large W = \int \vec{F} \cdot d\vec{r} [/itex]
We can reduce this to simply:
[itex]
\vec{F}\cdot{\vec{x}}
[/itex]
Now the rest is pretty straightforward in your case.
Hope that takes care of the confusion,
Daniel
Thank you so much!
I would approach this problem by first understanding the concept of work done by a force. Work is defined as the product of force and displacement in the direction of the force. In this case, the friction force is acting in the opposite direction of the displacement, so the work done by friction will be negative.
To calculate the work done by friction, we can use the equation W = Ff * d, where W is the work done, Ff is the friction force, and d is the displacement. In this problem, we are given the values for Ff and d, so we can simply plug them in to find the work done by friction.
W = (3.3 N) * (17.0 m)
W = -56.1 J
Therefore, the work done by friction is -56.1 Joules. This negative sign indicates that the friction force is acting in the opposite direction of the displacement, and thus, is doing negative work.
FAQ: Problem about finding the work done by friction force
What is friction force?
Friction force is a resistive force that occurs when two surfaces come into contact and move against each other. It is caused by the microscopic roughness of the surfaces and the interlocking of the irregularities.
How does friction affect work done?
Friction force acts in the opposite direction of motion, thus it reduces the amount of work done by a system. This is because some of the energy is converted into heat due to the frictional force.
How do you calculate the work done by friction force?
The work done by friction force can be calculated using the formula W = F*d*cosθ, where W is the work done, F is the friction force, d is the displacement, and θ is the angle between the direction of the force and the direction of motion.
What factors affect the work done by friction force?
The work done by friction force is affected by the coefficient of friction, the normal force, and the distance over which the force is applied. Additionally, the type of surfaces and the presence of lubricants can also affect the amount of work done by friction force.
How can you reduce the work done by friction force?
The amount of work done by friction force can be reduced by using lubricants to decrease the coefficient of friction, using smoother surfaces, and reducing the normal force. Additionally, minimizing the distance over which the force is applied can also decrease the work done by friction force.
