Problem about normal subgroups
  • Thread starter vikas92
  • Tags
    Normal
In summary, If A,B and C are normal subgroups of G where B is a subset of A, then A intersection Bc is equal to B(A intersection C). The solution involves proving that for any element x in A intersection Bc, it can be written as a product of an element in B and an element in A intersection C. This can be done by using the fact that B is a subset of A and the normality of A and C. The final result is a2c1, which is in BC.
vikas92
If A,B and C are normal subgroups of G where B[itex]\subseteq[/itex]A show that
A[itex]\bigcap[/itex]BC=B(A[itex]\bigcap[/itex]C)
Let x[itex]\in[/itex]A[itex]\bigcap[/itex]BC.then x[itex]\in[/itex]A and x[itex]\in[/itex]BC
Now as B[itex]\subseteq[/itex]A thus BA=A.thus left side is BA[itex]\bigcap[/itex]BC
Dont know how to proceed.
So you know that [itex]x\in A[/itex] and [itex]x\in BC[/itex]. The last means that there are [itex]b\in B[/itex] and [itex]c\in C[/itex] such that [itex]x=bc[/itex].
You must prove that [itex]x\in B(A\cap C)[/itex]. So you must write x as a product of something in B and something in [itex]A\cap C[/itex].
x=bc [itex]\Rightarrow[/itex] a-1bac[itex]\in[/itex]BC
Also a-1bca[itex]\in[/itex]BC Now a-1b=a1 for some a1[itex]\in[/itex]A[itex]\Rightarrow[/itex]a1ca[itex]\in[/itex]BC
a1(aa-1)ca[itex]\in[/itex]BC
(a1a)c1[itex]\in[/itex]BC for some c1[itex]\in[/itex]C
a2c1[itex]\in[/itex]BC
Cant still figure out
FAQ: Problem about normal subgroups
What is a normal subgroup?
A normal subgroup is a subgroup of a group that is invariant under conjugation by elements of the larger group. In other words, if an element of the larger group is conjugated by an element of the normal subgroup, it remains in the normal subgroup.
Why is it important to study normal subgroups?
Normal subgroups have many important properties and applications in group theory and other areas of mathematics. They provide a way to break down a larger group into smaller, more manageable pieces and can help to understand the structure of a group.
How do you determine if a subgroup is normal?
One way to determine if a subgroup is normal is to check if every element in the subgroup commutes with every element in the larger group. If this is true, then the subgroup is normal. Another method is to use the definition of a normal subgroup and check if the subgroup is invariant under conjugation.
What is the relationship between normal subgroups and quotient groups?
If a subgroup is normal, then the quotient group formed by dividing the larger group by the normal subgroup is a well-defined group. This relationship is known as the Fundamental Theorem of Homomorphisms and is a fundamental concept in group theory.
Can a group have more than one normal subgroup?
Yes, a group can have multiple normal subgroups. In fact, every group has at least two normal subgroups, the trivial subgroup containing only the identity element and the entire group itself. However, there are also groups with a larger number of normal subgroups.
