Problem about Proof A simply supported beam
  • Thread starter davidpotter
  • Tags
    Beam Proof
In summary, a beam with a UDL will have bending moments at each end, depending on the support type. A simply supported beam has zero bending moments at the supports, while a beam fixed at both ends will have bending moments equal to the cantilever or fully fixed beam.
davidpotter
Hello everyone!
I'm struggling with something here. I am rusty so have probably just misunderstood something simple mathematically. There are equations to create the Bending moment diagram for each different type of beam subject to a UDL; cantilever, simply supported, fully fixed ends etc.
However I just don't understand how they got them. A simply supported beam with a UDL of q and length L will have bending moments at each end of (qL^2)/2. That I get and can show proof yet its the centre moment I cannot reproduce, (qL^2)/8 Or cantilever at free end, (qL^4)/8EI {I do understand the EI bit btw} and fully fixed beams atall, (qL^2)/12 at ends and (qL^2)/24 in the centre. {Doesn't make sense to me as the reaction forces are still the same as a simply suppoted beam: qL/2} People write these on their beams when doing other structural analysis like its obvious yet I just can't see it. Clearly I've forgotten some basics about beams and I'm baffled, anyone care to help? thanks in advance :)
author: internet việt nam
have a nice day.
The different equations are the result of physics and probably some approximation.
You should consult the source for a reference.
davidpotter said:
Hello everyone!
This is not correct. If the beam is simply supported at both ends, the bending moment at the supports is zero. That's inherent in what a simple support is: it's just a resting point which cannot resist the rotation of the beam under load; hence, no moment can develop at these locations.
This is because you have not analyzed the statics of a simply supported beam properly.
Now, you've moved on from bending moments to talking about deflections.
Beams fixed at both ends are not statically determinate, like the cantilever or the simply supported beam. In order to determine the reactions and bending moments at the ends, a different kind of analysis must be performed.
have a nice day.
People do this because they understand the methods used to analyze these situations. They don't need to re-derive everything from first principles every time a new analysis is required. Many books on structural design carry tables for reference for determining reactions and bending moments for a handful of simple (and not so simple) cases. Saves time.
I don't know what books on strength of materials or mechanics you can refer to, but all of the above is basic stuff.
These links may provide you with an introduction to beam analysis:
http://www.learnengineering.org/2013/08/shear-force-bending-moment-diagram.html
http://www.mhhe.com/engcs/engmech/beerjohnston/mom/samplechap.pdf
There's many other examples on the web which can be uncovered by a simple search.
Related to Problem about Proof A simply supported beam
1. What is a simply supported beam?
A simply supported beam is a type of structural element commonly used in construction and engineering. It consists of a horizontal beam that is supported at each end by a fixed support, such as a wall or column, and is free to move vertically.
2. What is the problem about proof A simply supported beam?
The problem about proof A simply supported beam is a commonly used example in engineering to demonstrate the principles of statics and structural analysis. It involves finding the reactions at the supports and the internal forces within the beam in order to determine its stability and strength.
3. What are the key assumptions made in the proof of a simply supported beam?
The key assumptions made in the proof of a simply supported beam include: the beam is loaded only at the supports, the beam is perfectly straight and uniform, and the supports are rigid and can only resist forces in the vertical direction.
4. How is the proof of a simply supported beam useful in real-world applications?
The proof of a simply supported beam is useful in real-world applications as it allows engineers to design and analyze various structures, such as bridges, buildings, and cranes. By understanding the internal forces and reactions within a simply supported beam, engineers can ensure the safety and stability of these structures.
5. Are there any limitations to the proof of a simply supported beam?
Yes, there are some limitations to the proof of a simply supported beam. It assumes that the beam is loaded only at the supports and that the supports are perfectly rigid, which may not always be the case in real-world scenarios. Additionally, the proof does not take into account factors such as bending, shear, and deflection, which can affect the overall stability and strength of a beam. Therefore, it should be used as a simplified model and not as a precise representation of real-world structures.
  • General Engineering
14K
