Problem about the usage of Gauss' law involving the curl of a B field
In summary: I'll tell you... Eq.(5.33)).In summary, From the given conversation, we can see that the derivation of the equation $$\nabla \times B=\mu_0 J$$ starts with the electric field. Using the divergence theorem, it can be shown that the divergence of the B field is equal to the divergence of the magnetic vector potential. By using the identity for the curl of a curl, it can be shown that the curl of the B field is equal to the curl of the magnetic vector potential. Therefore, the equation $$\nabla \times B=\mu_0 J$$ can be derived from the electric field and the magnetic vector potential.
georg gill
153
I am trying to derive that
First the derivation starts with the electric field
$$dS=rsin\varphi d\theta r d\varphi $$
$$ \iint\limits_S E \cdot dS = \frac{q}{4 \pi \varepsilon_0} \iint\limits_S \frac{r}{|r|^3} \cdot dS $$
$$\textbf{r}=x\textbf{i}+y\textbf{j}+z\textbf{k}=\textbf{r}=rcos\theta sin \varphi\textbf{i}+rsin\theta sin \varphi\textbf{j}+rcos\varphi\textbf{k}$$$$\frac{\frac{\partial \textbf{r}}{\partial r}} {|\frac{\partial \textbf{r}}{\partial r}|}=cos\theta sin \varphi\textbf{i}+sin\theta sin \varphi\textbf{j}+cos\varphi\textbf{k}$$$$ \iint\limits_S E \cdot dS = \frac{q}{4 \pi \varepsilon_0 |r|^3} \iint\limits_S rcos\theta sin \varphi\textbf{i}+rsin\theta sin \varphi\textbf{j}+rcos\varphi\textbf{k} \cdot dS$$
$$ =\frac{q}{4 \pi \varepsilon_0 |r|^2}\iint\limits_S cos\theta sin \varphi\textbf{i}+sin\theta sin \varphi\textbf{j}+cos\varphi\textbf{k} \cdot dS $$$$= \frac{q}{4 \pi \varepsilon_0 |r|^2}\iint\limits_S (cos\theta sin \varphi\textbf{i}+sin\theta sin \varphi\textbf{j}+cos\varphi\textbf{k}) \cdot (cos\theta sin \varphi\textbf{i}+sin\theta sin \varphi\textbf{j}+cos\varphi\textbf{k}) rsin\varphi d\theta d\varphi $$
$$ \iint\limits_S E \cdot dS = \frac{q}{4 \pi \varepsilon_0 }\iint\limits_S (cos^2\theta sin^2 \varphi+sin^2\theta sin^2 \varphi+cos^2\varphi) sin\varphi d\theta d\varphi $$
$$ \iint\limits_S E \cdot dS = \frac{q}{4 \pi \varepsilon_0 }\int_0^\pi \int_0^{2\pi} sin\varphi d\theta r d\varphi=\frac{q}{\varepsilon_0} $$
$$\iiint_V \nabla \cdot E dxdydz=\iint\limits_S E \cdot dS = \frac{q}{\varepsilon_0}$$
As for divergence of E:
$$E=\frac{q}{4 \pi \varepsilon_0 r^2 }[\frac{x}{r}\textbf{i}+\frac{y}{r}\textbf{j}+\frac{z}{r}\textbf{k}]$$
after some calculations:
$$\nabla \cdot E=\frac{q}{4 \pi \varepsilon_0}\frac{3r^2-3r^2}{r^5}$$
Which is 0 except in origo
From problem 2.7 and problem 2.8 in Griffiths introduction to electrodynamics we obtain that the E field inside a charged sphere is pointing radially outwards and is given as
$$E=\frac{Q\textbf{r}}{4\pi\varepsilon_0 R^3}$$
by using unit vector and obtaining the divergence inside the charged sphere one obtains:
$$\nabla \cdot E=\nabla \cdot \frac{Qr}{4\pi\varepsilon_0 R^3}[\frac{x}{r}\textbf{i}+\frac{y}{r}\textbf{j}+\frac{z}{r}\textbf{k}]=3\frac{Q}{4\pi\varepsilon_0 R^3}=\frac{\rho}{\varepsilon_0}$$
Introducing the electric potential
$$E=\frac{q}{4 \pi \varepsilon_0 r^2 }[\frac{x}{r}\textbf{i}+\frac{y}{r}\textbf{j}+\frac{z}{r}\textbf{k}]=-\frac{q}{4 \pi \varepsilon_0} \nabla \frac{1}{r}=-\nabla V$$
It can easily be obtained that
$$\frac{\textbf{r}}{r^3}=-\nabla \frac{1}{r}$$
From that we obtain
$$\nabla \cdot E=-\frac{q}{4 \pi \varepsilon_0} \nabla^2 \frac{1}{r} $$
From results above we obtain that for a point charge in origo we have that
$$\nabla^2 \frac{1}{r}=-4 \pi $$
And inside our charged sphere
$$\nabla^2 \frac{1}{r}=-\frac{4 \pi}{V} $$
Above V is the volume of the charged sphere.
from example 5.11 of Griffiths introduction to electrodynamics 4th edition. And problem 5.29 of Griffiths introduction to electrodynamics third edition one obtains the B field inside a rotating charged sphere. By taking the curl of that one obtains that the curl of the B field inside a rotating charged sphere is ##\nabla \times B=\mu_0 J##
If we instead view the charge as a point charge
The magnetic vector potential gives that B field is the curl of the magnetic vector potential so that:
$$B(r)=\frac{\mu _0}{4\pi}\nabla \times \int \frac{ J(r')}{|r-r'|} dV'$$
$$\nabla \times B(r)=\frac{\mu _0}{4\pi}\nabla \times \nabla \times \int \frac{ J(r')}{|r-r'|} dV'$$
We use the identity:
$$\nabla \times (\nabla \times B)=\nabla(\nabla \cdot B)- \nabla^2 B$$
$$\nabla \times B(r)=\frac{\mu _0}{4\pi}\nabla \nabla \cdot \int \frac{ J(r')}{|r-r'|} dV' - \frac{\mu _0}{4\pi} \nabla^2 \int \frac{ J(r')}{|r-r'|} dV'$$
Since it is the current that is the vector we can rewrite the first part when we also use Leibniz integral rule to get the divergence inside the integral:
$$\nabla \times B(r)=\frac{\mu _0}{4\pi}\nabla \int J(r') \cdot \nabla \frac{ 1}{|r-r'|} dV' - \frac{\mu _0}{4\pi} \nabla^2 \int \frac{ J(r')}{|r-r'|} dV'$$
Since we assume that the current density is constant
$$\nabla \times B(r)=-\frac{\mu _0}{4\pi}\nabla \int \nabla' \cdot (J(r') \frac{ 1}{|r-r'|}) dV' - \frac{\mu _0}{4\pi} \nabla^2 \int \frac{ J(r')}{|r-r'|} dV'$$
Divergence theorem gives that the first part is 0 since we are integrating over the current density volume and it is steady so that no current density goes out of the volume:
$$\nabla \times B(r)= - \frac{\mu _0}{4\pi} \nabla^2 \int \frac{ J(r')}{|r-r'|} dV'$$
I have added all these derivations so that if someone would want to answer they could use the derivation that made me approach my problem which is:
Now they use that in the point charge:
$$\nabla^2 \frac{1}{|r-r'|}=-4 \pi $$
$$\nabla \times B(r)= \mu _0 \int J(r') dV'$$
How can they do that since ##\nabla^2 \frac{1}{|r-r'|}=-4 \pi ## is taken from electric forces from the E field and we are looking at the magnetic field?
Note that what you call $$\nabla^2 \frac{1}{|r-r'|}=-4 \pi $$
comes from a mathematical calculation...
it's not the result of a law of physics... but can be applied to (say) the electric field of a point charge.
Look at Griffiths, 4th edition, p. 50, Eq.(1.99)--(1.102), reproduced here:
We are now in a position to resolve the paradox introduced in Sect. 1.5.1.
As you will recall, we found that the divergence of [itex] \hat r/r^2 [/itex] is zero everywhere except at the origin, and yet its integral over any volume containing the origin is a
constant (to wit: [itex] 4\pi [/itex]). These are precisely the defining conditions for the Dirac delta function; evidently
$$\vec\nabla \cdot \left( \frac{\hat r}{r^2}\right) = 4\pi \delta^3(\vec r)\qquad(1.99)$$
More generally,
[itex] \def\rvar{\large\mathscr{ r}}
\def\vrvar{\ \ \vec{\!\!\!\!\large\mathscr{ r}}}
\def\hrvar{\ \ \hat{\!\!\!\!\large\mathscr{ r}}} [/itex]
$$\vec\nabla \cdot \left( \frac{\hrvar}{\rvar^2}\right) = 4\pi \delta^3(\vrvar)\qquad(1.100)$$
where, as always, [itex]\vrvar [/itex] is the separation vector:[itex]\ \vrvar \equiv \vec r -\vec r'[/itex]. Note that differentiation here is with respect to [itex] r [/itex], while [itex] r' [/itex] is held constant. Incidentally, since
$$\vec\nabla \left( \frac{1}{\rvar}\right) =-\frac{\hrvar}{\rvar^2}\qquad (1.101)$$
(Prob. 1.13b), it follows that
$$\nabla^2 \left( \frac{1}{\rvar}\right) =- 4\pi \delta^3 (\vrvar) \qquad (1.102)$$
...all without using the Electric Field.
This (Eq. (1.100)) is applied
on p. 71 to compute the divergence of E (see Eq.(2.16)),
and on p.232 to compute the curl of B (see Eq.(5.53)).
Likes BvU and georg gill
That equation is obviously wrong (already dimensionally). Correct is
$$\Delta \frac{1}{|\vec{x}-\vec{x}'|}=-\vec{\nabla} \cdot \frac{\vec{x}-\vec{x}'}{|\vec{x}-\vec{x}'|^3} = -4 \pi \delta^{(3)}(\vec{x}-\vec{x}'),$$
where ##\delta^{(3)}## is the Dirac-##\delta## distribution.
It's also clear that you cannot derive Ampere's circuital law of magnetostatics from electrostatics. It's one of the fundamental Maxwell equations for the static case. What you can however derive from the above Green's function of the Laplace operator is Biot-Savart's Law, using Ampere's law.
The most simple way is to introduce the vector potential, which must exist because beside Ampere's Law also Gauss's Law ##\vec{\nabla} \cdot \vec{B}=0## must hold:
$$\vec{B}=\vec{\nabla} \times \vec{A}.$$
Since ##\vec{A}## is defined only up to a gradient field, you can impose the Coulomb-gauge condition, ##\vec{\nabla} \cdot \vec{A}=0## and then use
$$\vec{\nabla} \times \vec{B} = \vec{\nabla} \times (\vec{\nabla} \times \vec{A}) = \vec{\nabla} (\vec{\nabla} \cdot \vec{A}) - \Delta \vec{A}=-\Delta \vec{A}=\mu_0 \vec{J}.$$
Using the above give Green's function of the Laplacian then indeed yields
$$\vec{A}(\vec{x})=\frac{\mu_0}{4 \pi} \int_{\mathbb{R}^3} \mathrm{d^3} x' \frac{\vec{J}(\vec{x}')}{|\vec{x}-\vec{x}'|}.$$
For ##\vec{B}## you get
$$\vec{B}(\vec{x}) = \vec{\nabla} \times \vec{A}(\vec{x}) = -\frac{\mu_0}{4 \pi} \int_{\mathbb{R}^3} \mathrm{d^3} x' \vec{J}(\vec{x}') \times \vec{\nabla}\frac{1}{|\vec{x}-\vec{x}'|}$$
and thus finally
$$\vec{B}(\vec{x})=+\frac{\mu_0}{4 \pi} \int_{\mathbb{R}^3} \mathrm{d}^3 x' \frac{\vec{J}(\vec{x}') \times (\vec{x}-\vec{x}')}{|\vec{x}-\vec{x}'|^3}.$$
Likes BvU, georg gill and etotheipi
I have tried to go through a proof for this:
$$\nabla \cdot \vec{A}=\frac{\mu _0}{4\pi}\nabla \cdot \int \frac{ J(r')}{|r-r'|} dV'$$
again we use
$$ \nabla \cdot \frac{ 1}{|r-r'|}=-\nabla' \cdot \frac{ 1}{|r-r'|}$$
And by similar reasoning as in my first post in the 5th last equation
$$\nabla \cdot \vec{A}=-\frac{\mu _0}{4\pi} \int J(r') \cdot \nabla' \frac{ 1}{|r-r'|} dV'$$
Then they look at the integration as from integration by parts
$$\int_{-\infty}^\infty g \frac{\partial f}{\partial x} dx = [gf]_{-\infty}^\infty - \int_{-\infty}^\infty f \frac{\partial g}{\partial x} dx$$
initially the integral is over the current which does not go from ##-\infty## to ##\infty##. I could perhaps reason and say that integrating from ##-\infty## to ##\infty## would get the same result. But if we extend the reasoning I did get to
For the ##-\infty## to ##\infty## we did get:
$$\nabla \cdot \vec{A}=-\frac{\mu _0}{4\pi} \int_{-\infty}^\infty J(r') \cdot \nabla' \frac{1 }{|r-r'|} dV'$$$$ J(r') \cdot \nabla' \frac{1 }{|r-r'|}=J(r') \cdot[\frac{\partial}{\partial x'}\textbf{i}+\frac{\partial}{\partial y'}\textbf{j}+\frac{\partial}{\partial z'}\textbf{k}] \frac{1}{[(x-x')^2+(y-y')^2+(z-z')^2]^{0.5}}$$
for the first component:
$$ g=J_x(r')$$ $$f=\frac{1}{[(x-x')^2+(y-y')^2+(z-z')^2]^{0.5}}$$
If we would have kept the integration limits from dV' it would be apparent that
$$ [gf] \neq0$$
If we increase to from ##-\infty## to ##\infty## it would be apparent that
$$\int_{-\infty}^\infty g \frac{\partial f}{\partial x} dx $$
and
$$- \int_{-\infty}^\infty f \frac{\partial g}{\partial x} dx$$
would not change after the increase in integration limits to ##-\infty## to ##\infty##
but with from ##-\infty## to ##\infty## we would get
$$ [gf]_{-\infty}^\infty =0$$
which is a change? How is this possible?
Likes vanhees71
You can of course also use
$$\vec{\nabla}' \left (\frac{\vec{J}(\vec{x}')}{|\vec{x}-\vec{x}'|} \right) = \frac{1}{|\vec{x}-\vec{x}'|} \vec{\nabla}' \cdot \vec{J}(\vec{x}') + \vec{J}(\vec{x}') \vec{\nabla}' \frac{1}{|\vec{x}-\vec{x}'|}.$$
Since now necessarily
$$\vec{\nabla} \cdot \vec{J}=0$$
you have
$$\vec{\nabla}' \left (\frac{\vec{J}(\vec{x}')}{|\vec{x}-\vec{x}'|} \right) = \vec{J}(\vec{x}') \vec{\nabla}' \frac{1}{|\vec{x}-\vec{x}'|}.$$
and you can use Gauss's theorem to get the final result that ##\vec{\nabla} \cdot \vec{A}=0##, i.e., the integral indeed gives the solution in the Coulomb gauge.
Sorry I have updated my last post it was not what I wanted to ask that was in the initial post. Please look at my last post above if interested.
The magnetic vector potential is 0 when ##r'=r## in the denumerator. Is not that the same issue as in:
$$ \frac{\mu _0}{4\pi} \nabla^2 \int \frac{ J(r')}{|r-r'|} dV'$$
So how can you use divergence theorem on the first part
$$\frac{\mu _0}{4\pi}\nabla \int \nabla' \cdot (J(r') \frac{ 1}{|r-r'|}) dV' $$
when it is not defined when ##r'=r##?
Of course there's a singularity at ##\vec{r}=\vec{r}'##, and this singularity must be there, because it's the Green's function of the Laplacian in the sense that
$$-\Delta \frac{1}{|\vec{r}-\vec{r}'|}=-\Delta' \frac{1}{|\vec{r}-\vec{r}'|} = 4 \pi \delta^{(3)}(\vec{r}-\vec{r}').$$
To get the "singularity" of the ##\delta## distribution there must be a singularity in the Green's function too.
Likes georg gill
Related to Problem about the usage of Gauss' law involving the curl of a B field
1. What is Gauss' law and how does it relate to the curl of a B field?
Gauss' law is a fundamental law in electromagnetism that relates the flux of an electric field through a closed surface to the total charge enclosed within that surface. It is also closely related to the divergence of a vector field. The curl of a B field, on the other hand, describes the rotation or circulation of the B field at a given point. Gauss' law involving the curl of a B field is a mathematical expression that shows the relationship between these two concepts.
2. Why is Gauss' law involving the curl of a B field important?
Gauss' law involving the curl of a B field is important because it helps us understand the behavior of magnetic fields and their interactions with electric fields. It also allows us to make predictions and calculations about the behavior of electromagnetic waves, which are essential in many technological applications.
3. What are some common problems encountered when applying Gauss' law involving the curl of a B field?
One common problem is determining the appropriate closed surface to use in the calculation. Another issue is understanding the direction and magnitude of the B field, as well as the orientation of the surface and its boundaries. Additionally, the presence of non-uniform or changing magnetic fields can complicate the application of Gauss' law involving the curl of a B field.
4. Can Gauss' law involving the curl of a B field be applied to all situations?
No, Gauss' law involving the curl of a B field has limitations and can only be applied in certain situations. It is most useful for calculating the magnetic field in situations with high symmetry, such as a long straight wire or a cylindrical magnet. In more complex situations, other mathematical methods may be needed to accurately calculate the B field.
5. How is Gauss' law involving the curl of a B field related to other laws in electromagnetism?
Gauss' law involving the curl of a B field is closely related to other fundamental laws in electromagnetism, such as Faraday's law and Ampere's law. Together, these laws form the basis of Maxwell's equations, which describe the behavior of electric and magnetic fields. Gauss' law involving the curl of a B field is also related to the principle of conservation of energy, as it shows the relationship between electric and magnetic fields in terms of energy transfer.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
