Problem calculating the atomic weight of an isotope.
In summary, to calculate the atomic weight of the lOB isotope, we can use the natural atomic weight given on the inside back cover and the fact that 80.22% of boron atoms are 11B. By setting up an equation using this data, we can solve for the unknown atomic weight of the lOB isotope, which is approximately 10.01 amu.
ihaveabutt
Boron has two naturally occurring isotopes, lOB and 11B. We know that 80.22% of its atoms are 11B, atomic weight 11.009 amu. From the natural atomic weight given on the inside back cover, calculate the atomic weight of the lOB isotope.
Solution
If 80.22% of all boron atoms are 11B, then 100.00 - 80.22, or 19.78%, are the unknown isotope. We can use W to represent the unknown atomic weight in our calculation:
(0.8022 x 11.009) + (0.1978 x W) = 10.81 amu (natural atomic weight)
W = (10.81-8.831)/0.1978 = 10.01 amu
On the part “(0.8022 x 11.009) + (0.1978 x W) = 10.81 amu (natural atomic weight),” how do I know what to multiply 0.1978 by if W is unknown? How did they arrive at 10.81?
Hi youhaveabuttandamazinglgysodoI
They didn't 'arrive' at 10.81, 10.81 is a given, it was measured, presumably.
W is the unknown and is multiplied by its known ratio so as to put the equation that is then solved
Cheers...
OK! This is done like this.
80.22% B atoms weight 11.009 amu and the other 19.78% weight let's say "m".
So we can construct a statement using all the data given and that is;
[itex]\frac{11.009\;amu\;×\;80.22\;+\;m\;amu\;×\;19.78}{100}[/itex] = 10.81 amu
11.009 × 80.22 = 883.1
[itex]\frac{(883.1\;amu\;+\;m19.78\;amu)\;×\;100}{100}[/itex] = 1081 amu
m19.78 amu = (1081 - 883.1) amu
∴m = [itex]\frac{(1081 - 883.1)\;amu}{19.78}[/itex]
So m comes as 10.005 ≈ 10.01 amu
Related to Problem calculating the atomic weight of an isotope.
1. What is the atomic weight of an isotope?
The atomic weight of an isotope is the average mass of all the naturally occurring isotopes of an element, taking into account their abundance.
2. Why is it important to accurately calculate the atomic weight of an isotope?
Accurate calculation of the atomic weight of an isotope is important for understanding the physical and chemical properties of elements, as well as for various scientific and industrial applications.
3. How is the atomic weight of an isotope calculated?
The atomic weight of an isotope is calculated by taking the sum of the mass of each naturally occurring isotope of an element, multiplied by its relative abundance, and dividing by the total abundance of all the isotopes.
4. What factors can affect the accuracy of the calculated atomic weight of an isotope?
The accuracy of the calculated atomic weight of an isotope can be affected by variations in the relative abundance of isotopes, experimental errors, and the presence of trace elements in the sample.
5. How does the atomic weight of an isotope differ from its atomic mass?
The atomic weight of an isotope takes into account the relative abundance of all the isotopes of an element, while the atomic mass is the mass of a single atom of a specific isotope. Therefore, the atomic weight of an isotope may be a decimal number, while the atomic mass is a whole number.
