Problem concerning about thermal physics
In summary, the metal rod bends into a circular arc as the temperature is increased, due to thermal expansion. The radius of curvature is found to be R=L/2RA, assuming that the ends of the rod are constrained to remain the same distance apart before and after heating.
Richardbryant
24
A metal rod of length length L, linear coefficient of expansion a, is fixed at both ends to the walls. When the temperature is increased byΔT, the rod bends into a circular arc due to thermal expansion.
2 Relevant equations
a)Find the radius of curvature R of the rod by considering the taylor expansion of sine function.
b) Find the value of R if L=4m, a=1.2x10^-6 k^-1 and ΔT=20k
Sorry that i don't really have much idea about this question, here is some of my guessing work.
As the temperature increased, the metal rod increased from L to L+ΔL[/B]
sinθ for small angle, the taylor expansion should expand to the 1st order, which is θ=L/2R
Are you familiar with the phenomenon of column buckling under compressional load?
I am sorry i don't familiar with this phenomenon
If you have a long slender rod and apply a force acting axially along it's length then one of two things can happen as the force is made larger and larger .
The rod could be simply crushed or the rod could bend sideways into a curve . When it bends sideways into a curve it is said to have 'buckled'
Buckling is a fascinating subject to study . Fortunately though you do not actually need to know much about the details of buckling to be able to solve the given problem .
The problem statement is incomplete so we are left to infer or assume some information that we need :
The metal rod buckles into an arc . That tells us that the ends of the rod are hinged rather than fully fixed to the walls .
No material properties are given for the rod so changes of rod length due to compression can be neglected .
I'll give you two hints now about how to start solving this problem :
Work out what the new length of the rod would be after heating if it was free to expand axially .
Use the information that the ends of the rod are in actual fact constrained to be the same distance apart before and after heating .
OK ?
Related to Problem concerning about thermal physics
1. What is thermal physics?
Thermal physics is a branch of physics that studies the behavior of matter at the microscopic level, focusing on the relationship between temperature, heat, and energy. It also explores the properties of different materials and their response to changes in temperature.
2. What is the difference between heat and temperature?
Heat is a form of energy that can be transferred from one object to another due to a difference in temperature. Temperature, on the other hand, is a measure of the average kinetic energy of the particles in a substance.
3. How does thermal expansion occur?
Thermal expansion occurs when the temperature of a substance increases, causing the particles to vibrate faster and take up more space. This results in an increase in the size of the substance, which can be observed in objects such as thermometers and metal bridges.
4. What is the relationship between heat transfer and energy?
Heat transfer is the movement of thermal energy from a warmer object to a cooler object. This transfer of energy can occur through three main mechanisms: conduction, convection, and radiation. The amount of heat transferred is directly proportional to the temperature difference between the objects.
5. How does thermal equilibrium occur?
Thermal equilibrium is the state in which two objects at different temperatures come into contact and reach a common temperature. This occurs because heat energy is transferred between the two objects until they reach the same temperature, and there is no longer a temperature difference between them.
9K
14K
