Problem Determine the energy of an electron. Bohrs model fun
In summary, the energy of an electron in the given level of each of the following ions, Li2+ and F8+, can be determined using the Bohr model. By using the equation E_n = -13.6Z^2/n^2, where Z is the atomic number and n is the orbit number, the energy can be calculated in Joules. For Li2+, with Z = 3 and n = 2, the energy is -4.902e-18J. For F8+, with Z = 9 and n = 2, the energy is -1.656e-16J. These values can also be converted to electronvolts by multiplying by 1.602 x 10
mr_coffee
1,629
Determine the energy of an electron in the given level of each of the following ions. Use 'e' notation with two decimal places. For example, -2.34e-22.
Hint: Each of the ions has a different number of protons, but each has one electron, so the Bohr model applies to each.
Ions:
Li2+
F8+
Level:
Li^(2+) = 2
F^(8+) = 6
Find Enegery of
Li^(2+) and F^(8+);
Our professor doesn't know how to get it for some reason, he said he might just take it off the hw, but it doesn't seem that hard but maybe we are using hte wrong formula.
In his notes this is the only thing close to what i think it would be:
Oscillating molecules that emit the radiation only have discrete energies
E_n = nhf
f = frequencey
h = planks constant;
n = quantum number
E_n = energy of quantum state n of molecule
for Li^(2+), I'm trying:
Li (Z = 3)
E_n = (3)(6.62E-35Js)(f)
problem is, we don't know the frequency!
any ideas on what other formulas i could use? thanks!
He told us, take Z multiply it by planks constant for ur answer, when we told him it didn't work he said it should have worked hah. SO i don't know what's going on!
Sorry for the late responce. I'm confused, Z is the atomic number right? The atomic number of Li is 3 right? So using this equation:
I let Z = 3, n = 2;
E =-30.6 J;
this isn't right though,is it becuase the atomic number of Li2+ is not 3?
The number i should be getting should be pretty small if it says:
If i have to apply the more complicated form of the formula, I'm confused on what the value of Eo is and what e stands for, could you explain it alittle more? I know h is planks constant, Z is the atomic number, would it still be 3 in this case? m is the mass (6amu), n is the orbit number (n =2), is e the charge of an electron? Thanks for the responce!
I let Z = 3, n = 2;
E =-30.6 J;
This is the way to go, except that your answer is in electronvolts not in Joules!
The unit "electron-volt" is very confusing because of the symbol "eV". But in the end it is just a unit of energy, [itex] 1 eV = 1.602 \times 10^{-19} J [/itex].
If they expect a small answer, it's probably because they want it in Joules, so you will have to multiply your -30.6 by 1.602 x 10^(-19).
They seem to use small "e" for what people usually call "E" (that is, 1e-3 for example = [itex] 1 \times 10^{-3} [/itex]). This "e" has nothing to do with the electric charge or the "e" in eV.
You did it ok (except for confusing eV with Joules). E_0 is simply -13.6 eV. What does "e" stand for? In the formula it is the elementary charge, in "eV", it is just part of the symbol of this unit of energy. In 3e-22 it seems to be a symbol used for scientific notation.
Ahh thank you for the clarification! I got both of them correct! they are both the same answer as well, interesting! thanks again guys!
-4.902e-18J
FAQ: Problem Determine the energy of an electron. Bohrs model fun
1. What is the Bohr model of an electron?
The Bohr model is a simplified representation of an atom, in which electrons orbit the nucleus in specific energy levels or shells. This model was proposed by Niels Bohr in 1913 and helped to explain the stability and behavior of atoms.
2. How do you determine the energy of an electron using the Bohr model?
The energy of an electron in the Bohr model is determined by the formula E = -13.6/n^2, where n is the principal quantum number. This number represents the energy level in which the electron is located, with higher values of n indicating higher energy levels.
3. Is the Bohr model still used today?
Although the Bohr model is a simplified representation of an atom, it is still used in introductory chemistry and physics courses to explain the basic structure of an atom. However, it has been superseded by more complex models, such as the quantum mechanical model, which provide a more accurate description of atomic structure.
4. How does the Bohr model explain the emission and absorption of light by atoms?
The Bohr model explains that electrons can only exist in certain energy levels, and when they absorb energy, they jump to a higher energy level. When they return to their original energy level, they emit the excess energy as light. This explains the emission and absorption lines observed in the atomic spectra.
5. Can the Bohr model be applied to all atoms?
No, the Bohr model is only applicable to atoms with one electron, such as hydrogen. It cannot accurately describe the behavior of atoms with more than one electron. However, it laid the foundation for the development of more complex models that can describe the behavior of all atoms.
