Problem figuring out the surface of integration
In summary, the conversation is about finding the surface of integration for a paraboloid that crosses a disk on the xz plane. The solution involves parametrizing K in polar coordinates and integrating for a value of r from 0 to √3/3. It is noted that y is not constrained to be positive, but rather x^2 + z^2 \leq 9 which is equivalent to r \leq 3.
Amaelle
310
54
Consider the vector field F(x, y, z) = (2x, 2y, 2z) and the surface
Σ = n(x, y, z) ∈ R3 : y = 1 − 3x^2 − 3z^2 and x^2 + z^2 ≤ 9, x ≥ 0 ,
oriented so that its normal vector forms an acute angle with the fundamental versor of the y–axis.
Compute the flux of F through Σ.
K′ = [0, √3/3] × [-π2, π2 ]
Good day I have a problem figuring out the surface of integration
according to the exercice, we have a paraboloid that cross a disk on the xz plane, the parabloid cross the xz plane on a smaller disk r=√3/3
so for me after going to the final step of integration and using polar coordinate i will integer for a value of r going from 0 to √3/3
but the solution of the exercice said
If we parametrize K in polar coordinates, K is the image of K′ = [0, 3] × [-π2, π2 ]
Any help would be highly appreciated
thanks
Nowhere does it say that [itex]y[/itex] is constrained to be positive; it says instead that [itex]x^2 + z^2 \leq 9[/itex] which is indeed [itex]r \leq 3[/itex].
Likes Amaelle
Thanks a lot ! I got it now!
Related to Problem figuring out the surface of integration
1. What is the surface of integration?
The surface of integration refers to the area or region over which a mathematical function is being integrated. It is the boundary or limits within which the integration takes place.
2. How do you determine the surface of integration?
The surface of integration is determined by the variables and their limits in the given mathematical function. These limits can be represented as a range of values or equations that define the boundaries of the surface.
3. Why is it important to figure out the surface of integration?
Figuring out the surface of integration is important because it helps in accurately calculating the value of the integral. It also helps in visualizing the region over which the integration is taking place, which can aid in understanding the problem better.
4. What are some common methods for figuring out the surface of integration?
Some common methods for figuring out the surface of integration include using geometric shapes, converting the problem to polar or spherical coordinates, and using the method of substitution to simplify the limits of integration.
5. Are there any tips for effectively figuring out the surface of integration?
One tip for effectively figuring out the surface of integration is to carefully analyze the given function and its variables to determine the appropriate limits. It can also be helpful to draw a diagram or use visualization techniques to better understand the problem.
