Problem: How to prove the vector field identity $[v,fw]=(L_vf)w+f[v,w]$?
  • MHB
  • Thread starter Chris L T521
In summary, a vector field identity is a mathematical equation that relates different vector fields using operations like dot product, cross product, or differentiation. The notation [v,fw] represents the Lie bracket of two vector fields and measures how much they differ from each other. It can be proven using the definition of the Lie bracket and properties of vector fields and functions. This identity is significant in understanding the relationship between vector fields and has various real-world applications in fields like fluid mechanics, electromagnetism, and mechanics.
Chris L T521
MHB
915
Here's this week's problem!
Problem
: Let $v$ and $w$ be smooth vector fields on a smooth manifold $M$ and let $f$ be a smooth function. Prove that\[[v,fw]=(L_vf)w+f[v,w].\]
No one answered this week's problem. You can find my solution below.
[sp]For $v,w$ smooth vector fields on $M$ and $f$ a smooth function, we have
\[\begin{aligned}{[v,fw]} &= (v(fw)^i-fwv^i)\frac{\partial}{\partial x^i}\\ &= \left(\sum v_j\frac{\partial}{\partial x^j}(fw)^i-fwv^i\right)\frac{\partial}{\partial x^i}\\ &= \left(\sum v_j\left(\frac{\partial f}{\partial x^j}w^i + f\frac{\partial w^i}{\partial x^j}\right)-fwv^i\right)\frac{\partial}{\partial x^i}\\ &= \left(L_v fw^i +f\sum v_j\frac{\partial w^i}{\partial x^j}-fwv^i\right)\frac{\partial}{\partial x^i}\\ &=L_v f w^i\frac{\partial}{\partial x^i}+(fvw^i-fwv^i)\frac{\partial}{\partial x^i}\\ &= (L_v f)w+f[v,w].\end{aligned}\][/sp]
FAQ: Problem: How to prove the vector field identity $[v,fw]=(L_vf)w+f[v,w]$?
What is a vector field identity?
A vector field identity is a mathematical equation that relates different vector fields, typically using operations such as dot product, cross product, or differentiation. In this particular case, the identity relates a vector field v to the function f and another vector field w.
What does the notation [v,fw] mean?
The notation [v,fw] represents the Lie bracket of the vector field v and the vector field fw. This is a mathematical operation that is used to measure the "failure" of two vector fields to commute, or to measure how much they differ from each other.
How can this vector field identity be proven?
This identity can be proven using the definition of the Lie bracket, as well as the properties of vector fields and functions. It involves careful manipulation of the terms and using the fact that the Lie bracket is a bilinear operation.
What is the significance of this vector field identity?
This identity is significant because it helps us understand the relationship between vector fields and functions. It also has many applications in physics, engineering, and other fields where vector fields are commonly used. Additionally, it can also be used as a tool to simplify and solve more complex problems involving vector fields.
Are there any real-world examples of this vector field identity in use?
Yes, this identity is commonly used in fluid mechanics to understand the behavior of fluids in motion. It is also used in electromagnetism to study the behavior of electromagnetic fields. Other examples include applications in mechanics, such as studying the motion of objects in space.
