Problem identifying two spectra
  • I
  • Thread starter Frank Einstein
  • Tags
    Spectra
In summary, the conversation is about finding the spectral types of two stars by analyzing their spectra. The first star appears to be a class M, but the subtype is unknown. The second star is more difficult to determine, but it is thought to be a A or B star based on its spectra. The speaker also suggests using a resource on star spectra for further assistance. The question of whether the spectra were corrected for instrumental response is also raised.
Frank Einstein
170
Hi everibody.
I have been tasked with finding out the spectral tipe of two stars; for that, I have processed the spectres. You can find them in the links.
http://postimg.org/image/5a6w2pbf5/
http://postimg.org/image/71iehdz4h/
Now, I am a little lost, I am clueless about where to look for a database where I can compare these spectres with.
Can someone please tell me where I can find one?
Thanks for reading.
Astronomy news on Phys.org
Frank Einstein said:
Hi everibody.
Thanks for reading.
pl. clear the question/frame it according to your need- if you are only interested in knowing the type/variety of the spectra then;
what i observed in the two spectra quoted /given as attachment -
in one the flux peaks are rising at certain wavelengths -
those peaks must be designating the flux rising for those wavelengths- suppose some stars are emitting those wavelengths prominently - then such graphs will be observed.
whereas in the other one reverse features are being seen - common sense tells us that at some wavelengths the flux is dipping becoming smaller ,those characteristic wavelengths can not be emitted , but must be absorbed by some intervening media.
perhaps now you can tell what are the types(names) of these two spectra.
What I want to know is their position in the Hardvard classification, for example, I think the first star is a class M, because of the position of the maxim; but I don't know which is it's subtype (I, II, III...).
For the second star I am completely lost.
You could have a look at this http://www3.gettysburg.edu/~marschal/clea/speclab.html it seems to be about what you are trying to do.
You first "star" has strong emission lines which would make me look at unusual stars WR Stars, binaries etc, the second looks like a A or B star just from eye balling it.
If you use Google images you can see lots of star spectra.
Where these spectra corrected for instrumental response?
Also I doubt they have high enough resolution for anything but a an approximate assignment of spectral class.
Regards Andrew
Related to Problem identifying two spectra
1. What is a spectrum?
A spectrum is a range of electromagnetic radiation or light that is separated into different wavelengths or frequencies. It can also refer to a range of values or characteristics that can be measured or observed.
2. Why is it important to identify two spectra?
Identifying two spectra can provide valuable information about the composition and properties of a substance. It can also help scientists understand the behavior and interactions of different substances.
3. How is problem identifying two spectra approached?
Problem identifying two spectra is approached through various techniques such as spectroscopy, which involves analyzing the absorption and emission of light by a substance. Other methods may include chromatography, mass spectrometry, and nuclear magnetic resonance.
4. What are some common challenges in identifying two spectra?
Some common challenges in identifying two spectra include overlapping peaks, low signal-to-noise ratios, and difficulty in distinguishing between similar substances. Instrumental limitations and sample preparation issues can also contribute to challenges in identification.
5. What are the potential applications of identifying two spectra?
The identification of two spectra has many potential applications in fields such as chemistry, biology, environmental science, and materials science. It can help in drug discovery, quality control, forensic analysis, and understanding the composition of various natural and synthetic materials.
  • Astronomy and Astrophysics
  • Atomic and Condensed Matter
10K
