Problem involving interference and medium with index n
The discussion centers on calculating the angular separation between the 400 nm and 600 nm lines in a first-order spectrum using a diffraction grating with a refractive index medium. The equation for maximum localization is presented as d sin(θ)/n = m λ, with a focus on how refraction affects the incident angle. There is disagreement over whether the incident angle or the refracted angle should be used for measuring angular separation, leading to confusion about the validity of the solutions proposed. The participants express uncertainty about the role of refraction in the problem, suggesting that it complicates the application of the equations. Ultimately, the discussion highlights a fundamental disagreement on the interpretation of angles in the context of diffraction and refraction.
LCSphysicist
> A diffraction grating, ruled with 300 lines per mm, is illuminated with a white light source at normal incidence. (ii) Water (of refractive index 1.33) now fills the whole space between the grating and the screen? What is the angular separation, in the first-order spectrum, between the 400 nm and 600 nm lines? [5]Second the solution of the question, the equation of máximum localization is now ##d sin(\theta)/n = m \lambda##. The argument given to achieve this equation was that "the indicent plane light will suffers refraction between the two medium, such that ##sin(\theta i) = n sin (\theta w)##.
Even so i can see a logic behind this argument, i am not totally convinced with the solution of it. I mean, i am not sure of that. Honestly, i think the author is using the incident angle to measure the angular separation, and i desagree. The wave will propagate parallel to the refracted angle ##\theta w##, so the incident angle does not matter anymore. In this case, i would say that
**We could argue that the wavelength now is ##\lambda/n##. Now since the angle that matters is, in fact, the angle after the slits, already in the medium, the equation should be ##d sin(\theta w) = m \lambda /n##**.
THe problem with this solutions is that, if we substitute (Since i think both equations are essentially true, just differing the meaning of angular separation) ##\theta w## (my solution) and ##\theta i## (authors solution) in ##sin(\theta i) = n sin (\theta w)##, we did'nt got ##1=1##.
So one of the solutios is wrong. Probably mine, but i am not sure why.
That looks good to me.
Herculi said:
THe problem with this solutions is that, if we substitute (Since i think both equations are essentially true, just differing the meaning of angular separation) θw (my solution) and θi (authors solution) in sin(θi)=nsin(θw), we did'nt got 1=1.
I fail to see what refraction has to do with this problem.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
