Problem involving mercury thermometer
In summary, a mercury thermometer is a type of thermometer that uses mercury as the liquid inside the glass tube to measure temperature. It works based on the principle of thermal expansion, where the mercury expands or contracts based on the temperature and indicates it on a scale. However, due to safety concerns, it is no longer considered safe to use and should be properly disposed of at a hazardous waste facility. There are several alternatives to mercury thermometers, including digital, alcohol-based, and bi-metallic strip thermometers, which are considered safer and more accurate.
xnitexlitex
23
A mercury thermometer contains 7.5 mL of mercury. If the tube of the thermometer has a cross-sectional area of 1.2 mm2, what should the spacing between the °C marks be? (The volume expansion coefficient for mercury is 1.81 x 10-4 °C−1.)
ΔV=βV0ΔT
I set ΔT = 1, converted the mL into mm3.
I got ΔV = [5.43*(10-4)](7500)(1) = 4.0725 mm3.
However, I don't know what to do with the area!
What do you get if multiply the cross sectional area by the change in height?
Related to Problem involving mercury thermometer
1. What is a mercury thermometer?
A mercury thermometer is a type of thermometer that uses mercury as the liquid inside the glass tube to measure temperature. The mercury expands or contracts based on the temperature, indicating the temperature on a scale. It was widely used in the past but has been largely replaced by digital thermometers due to safety concerns.
2. How does a mercury thermometer work?
A mercury thermometer works based on the principle of thermal expansion. As the temperature increases, the mercury inside the glass tube expands and rises up the tube, indicating a higher temperature. As the temperature decreases, the mercury contracts and moves down the tube, indicating a lower temperature.
3. Are mercury thermometers safe to use?
No, mercury thermometers are not considered safe to use. Mercury is a toxic substance, and exposure to it can be harmful to human health and the environment. In case of breakage, the mercury can vaporize and be inhaled, leading to health issues. Therefore, it is recommended to use alternative, safer thermometers.
4. How do I dispose of a mercury thermometer?
It is essential to properly dispose of a mercury thermometer to prevent any harm to the environment. Do not throw it in the regular trash. Contact your local hazardous waste disposal facility to find out the proper way to dispose of it. They will likely have specific guidelines for handling and containing the mercury before disposal.
5. What are the alternatives to mercury thermometers?
There are several alternatives to mercury thermometers, including digital thermometers, alcohol-based thermometers, and bi-metallic strip thermometers. These alternatives are considered safer, more accurate, and easier to read. Some also have the advantage of being able to measure temperature in both Celsius and Fahrenheit.
12K
20K
