Problem involving recursion theorem
  • Thread starter issacnewton
In summary, the problem involving the recursion theorem addresses the existence of self-replicating functions or algorithms within formal systems. It establishes that for any computable function, there exists a program that can produce its own description. This theorem has significant implications in theoretical computer science, particularly in areas like self-reference, fixed points in computation, and the foundations of mathematics, revealing limitations in formal systems and the concept of computability.
issacnewton
1,041
37
Suppose that the set ##\mathbb{N}## together with the element ##1 \in \mathbb{N}## and the function ##s: \mathbb{N} \rightarrow \mathbb{N}##, and that the set ##\mathbb{N}'## together with the element ##1' \in \mathbb{N}'## and the function ##s' :\mathbb{N}' \rightarrow \mathbb{N}' ##, both satisfy the Peano Postulates. Prove that there is a bijective function ##f :\mathbb{N} \rightarrow \mathbb{N}' ## such that ##f(1) = 1'## and ## f\circ s = s' \circ f##. The existence of such a bijective function proves that the natural numbers are essentially unique.
Theorem (definition by recursion)--> Let ##H## be a set, let ##e \in H## and let ##k : H \rightarrow H## be a function. Then there is a unique function ## f: \mathbb{N} \rightarrow H## such that ##f(1) = e## and that ## f \circ s = k \circ f ##.
Following is a set of Peano postulates I am using.
There exists a set ##\mathbb{N}## with an element ##1 \in \mathbb{N}## and a function ##s: \mathbb{N} \rightarrow \mathbb{N} ## that satisfy the following three properties.
1) There is no ##n \in \mathbb{N}## such that ##s(n) = 1##
2) The function ##s## is injective.
3) Let ##G \subseteq \mathbb{N}## be a set. Suppose that ##1 \in G##, and that if ##g \in G## then ##s(g) \in G##. Then ## G = \mathbb{N} ##
Now, we are given that ##\mathbb{N}'## is a set and ##1' \in \mathbb{N}'## and ##s' :\mathbb{N}' \rightarrow \mathbb{N}' ## is a function. So, using the recursion theorem, there is a unique function ##f : \mathbb{N} \rightarrow \mathbb{N}'## such that ##f(1) = 1'## and ## f\circ s = s' \circ f##. This part is easy. But I am stuck on how to prove that ##f## is a bijection. Should I start with ##f(a) = f(b)## and then try to prove that ##a = b## for ##f## to be one to one ? But I don't get anywhere with this. Any hints will be helpful.
Thanks
The standard proofs in algebra and about natural numbers use indirect methods. This theorem has a logical aspect, so I'm not sure whether an indirect proof is allowed in your specific setup.
If so assume ##f## is not injective (subjective) and find a contradiction. Or, use the fact that ##\mathbb{N}## and ##\mathbb{N}'## are totally ordered: assume the smallest element that breaks the assumption and construct a smaller one that also breaks the assumption.
Ok, fresh_42, taking hints from you, following is my proof. Assume to the contrary that ##f## is not one to one. Then ##\exists a,b \in \mathbb{N}## such that ##f(a) = f(b) ## and ## a \ne b ##. I am going to use a Lemma here, which I have already proven.
Lemma: Let ##x \in \mathbb{N}##. Suppose that ## x \ne 1##. Then there is a unique ## y \in \mathbb{N}## such that ## x = s(y) ##.
Now, we will consider three cases here
Case 1) ## a = 1## and ##b \ne 1##
Using Lemma above, there is some ##m \in \mathbb{N}## such that ##b = s(m)##. Since ##f(a) = f(b) ##, this means that ##f(1) = f(s(m)) ##. But, we have, ## f \circ s = s' \circ f##. So, ##f(s(m)) = s'(f(m))##. Since ##f(1) = 1'##, we have ##s'(f(m)) = 1'##. But, according to the Peano postulates, there is no ##n' \in \mathbb{N'}## such that ## s'(n') = 1'##. So, we have reached a contradiction.
Case 2) ## a \ne 1## and ##b = 1##
This case is similar to the case above and reasoning is along the same line.
Case 3) ##a \ne b## and ##a \ne 1## and ##b \ne 1##
Again using the Lemma, there are some ##p, q \in \mathbb{N}## such that ##a = s(p)## and ##b = s(q)##. Since ##f(a) = f(b) ##, it follows that ##f(s(p)) = f(s(q)) ##. But, ## f \circ s = s' \circ f##, so,
$$ s'(f(p)) = s'(f(q)) \cdots\cdots (1)$$
Since ##s'## is one to one function, it follows that ##f(p) = f(q)##. But I am stuck here and no idea what to do. Also, I forgot to write part of the problem where author gives some hints. He says that find an inverse for ##f## by using existence part of the recursion theorem again and then prove that the function you found is an inverse of ##f## by using the uniqueness part of the same theorem.
So, let ##\mathbb{N}## be a set and ##1 \in \mathbb{N}## and ## s: \mathbb{N} \rightarrow \mathbb{N}## is a function. Then according to the theorem, there is a unique function ##f' : \mathbb{N'} \rightarrow \mathbb{N}## such that ##f'(1') = 1 ## and ## f' \circ s' = s \circ f'##. Now, how do I prove that this is indeed the inverse of the function ## f## ?
Before you start proving details about ##f##, you have to prove the existence of such a function! The lemma you quoted is the key to doing so. We set ##f(1)=1'.## Now for ##n>1## there is - according to the lemma - an ##m\in \mathbb{N}## such that ##s(m)=n## and we can define recursively
f(n)= f(s(m)):= s'(f(m)) =s'(m').
Now we have defined the function ##f## so that it automatically fulfills the requirements ##f(1)=1'## and ##f\circ s= s'\circ f.## (Note that ##s## and ##s'## could be any ordering of natural numbers, and ##f## any permutation. We do not know that ##s(1)=2## or ##s(1')=2'.## We only know that ##s^{-1}(1)=\emptyset ## and ##s'^{-1}(1')=\emptyset .## However, we may assume that ##>## and ##<## in ##\mathbb{N}## are given by the ordering ##s## and ##>## and ##<## in ##\mathbb{N}'## are given by the ordering ##s'.##)
Now we can use your arguments with the lemma. I think they can be shortened a bit ...
Assume ##f(a)=f(b)## with ##a\neq b.## If ##a=1## then there is an ##m\in \mathbb{N}## such that ##s(m)=b## because ##b\neq a=1## according to the lemma. Hence ##f(b)=f(a)=f(1)=1'## and ##f(b)=f(s(m))=s'(f(m))=s'(m')## by definition of ##f.## Hence, ##s'(m')=1',## but there is no such number in the system ##(1',s',\mathbb{N}').## So ##a>1.## We also have ##b>1## for the same argument with ##b.##
... but the idea is correct.
Now let ##a## be the smallest (according to ##s##) number such there exists a ##b\in \mathbb{N}-\{a\}## such that ##f(a)=f(b).## This implies that ##1<a<b## by the previous argument and that there are ##\bar a,\bar b\in \mathbb{N}## such that ##s(\bar a)=a## and ##s(\bar b)=b## according to the lemma.
I further assume that we already know that ##\mathbf s## and ##\mathbf s'## are injective. If not, prove it here.
f(a)=f(s(\bar a))=s'(f(\bar a))=f(b)=f(s(\bar b))=s'(f(\bar b)) \Longrightarrow f(\bar a)=f(\bar b)
contradicting the minimality of ##a.##
This shows that ##f## is injective since there is no minimal counterexample.
Assume that ##n'\in \mathbb{N}'## is the smallest number with no preimage under ##f.## Then ##n'>1'## since ##f(1)=1'## has a preimage. Chose ##s'(m')=n'.## Then ##n'=s'(m') =s'(f(m))=f(s(m))## and ##s(m)## would be a preimage. Since there is no such preimage per assumption, we conclude that ##m=1## as the only element without a number ##s(m).## But this means ##n'=s'(m')=s'(f(1))=s'(1')## contradicting the fact that ##1'\in \mathbb{N}'## has no predecessor.
Likes issacnewton
Another idea for surjectivity is the following. Set ##G':=f(\mathbb{N})\subseteq \mathbb{N}'.## Then ##1'=f(1)\in \mathbb{N}'.## Let ##g'\in G'-\{1\}, ## i.e. ##g'=f(n)## for some ##n\in \mathbb{N}-\{1\}.## We rule out ##g'=1'## since we want to show ##s'(g')\in G'.## Since ##f## is injective, ##n## cannot be ##1## and ##s(n)## exists. Then
s'(g')=s'(f(n))=f(s(n)) \in f(\mathbb{N})=G'.
Therefore ##G'=\mathbb{N}'## by property 3 in post ##1## for the system ##(1',s',\mathbb{N}').##
Likes issacnewton
Thanks for the input. ##s## and ##s'## both satisfy Peano postulates as stated in the problem. So, they are injective.
By letting ##a = s(p)## and ##b = s(q)##, I proved in post #3 that ##f(p) = f(q)##, which is where I was struck. Do we have to make assumption that ##a## is the least member such that ##f(a) = f(b)## ?
Probably not necessarily. I was a bit dizzy toward the end because I tried various ways and dead-end roads before I ended up with what I had posted. So it isn't ruled out that there might be a more elegant way. The idea with the minimal ##a## is that it uses the fact that ##\mathbb{N}## is bounded from below. It is shorter than saying "Repeat the argument until ##a=1##" and then deal with this special case. The minimality argument occurs quite often in statements about natural numbers so I'm kind of used to it. It is like stretching a net at the beginning of the proof in order to have it in place if necessary.
The whole idea of the proof is to define ##f## with the two properties, the "induction base" ##f(1)=1'## and the recursion identity ##f\circ s= s'\circ f## meaning ##f(n+1)=f(n)+1'.## This is all we have and it explicitly defines ##f(n+1)## by means of its predecessor ##f(n).## That invites literally to assume the smallest ##n## that does not satisfy a property, in our case injectivity and surjectivity.
The other possibility would be an induction proof along ##s## and ##s'##. Try it! It's likely more elegant.
Likes issacnewton
Since you are using minimality arguments here, I have a question. Is this the use of well ordering principle ?
No. Well-ordering is equivalent to the axiom of choice. We do not select an element by the axiom of choice, we assume the existence of a counterexample and use an indirect proof. If there is a counterexample, then there is a minimal one because the natural numbers are totally ordered by ##s## and bounded from below so that minimality does not lead to minus infinity. It is a typical argument when natural numbers are involved. We have a total ordering and all non-empty sets always have a minimal element.
Abstract algebra often uses the axiom of choice and sometimes without mentioning it, but not in this case.
Likes issacnewton
I have studied proof techniques from Daniel Velleman's book "How to prove it". He didn't mention this technique there. So, this is new to me. But it does make sense. So, we can use minimality argument when we have any set ##A##, such that there is a bijection ##f: A \rightarrow \mathbb{N}## and ##A## has a lower bound. Would that be right way to say it ? Can you give me other examples of proofs where this argument is made ? I am self learning analysis, so that would be helpful.
Almost. We only need ##A\neq \emptyset .## Sure, if ##A## is infinite then there is a bijection ##f,## but this is an artificial view on ##A## and if ##A## is finite, then there are automatically a lowest and a largest element since ##s## is a total ordering.
However, we do not need to consider the size of ##A##. Of course, we need that ##A## is not empty. If ##1\in A## then ##1## is the minimal element of ##A## and we are done. Otherwise, we define recursively
A_0:=A \quad \text{ and } \quad A_k:=\{y\in \mathbb{N}\,|\,s^{-1}(y)\in A_{k-1}\} \;\text{ for } \;k \ge1
As soon as ##1\in A_k## for some ##k\in \mathbb{N},## we have found the minimal element of ##A## which is the unique one with ##s^{-k}(x)=1.## The existence of such a chain is provided by your lemma. It remains to show that there always exists a ##k\in \mathbb{N}## such that ##1\in A_k.##
If this wasn't the case, then we can select any element of ##x\in A## and define the sequence ##(s^{-k}(x))_{k\in \mathbb{N}}## that does not contain ##1.## But ##s^{-k}(x) < s^{-k+1}(x)## and we cannot decent infinitely within ##\mathbb{N}## as it is bounded from below by ##1.##
Edit: I corrected the power of ##s##. We need the unique predecessor, not the successor, so the powers are negative (sorry). Uniqueness in the statement of the lemma guarantees that there is only one (or none in case we arrive at ##1##).
Likes issacnewton
You can find it in Richard Hammack's "Book of Proof" in chapter 10 (Mathematical Induction) as 10.3. Proof by Smallest Counterexample.
Likes issacnewton
FAQ: Problem involving recursion theorem
What is the recursion theorem in computability theory?
The recursion theorem is a fundamental result in computability theory that states that for any computable function, there exists a program that can produce its own code. In simpler terms, it asserts that there are self-replicating programs, which can generate their own description or definition as output.
How does the recursion theorem relate to fixed points in functions?
The recursion theorem is closely related to the concept of fixed points in functions. Specifically, it guarantees the existence of a fixed point for any computable function, meaning that there exists an input such that when the function is applied to that input, it returns the same input. This is crucial for understanding self-replicating programs and their behavior in computation.
Can you give an example of the recursion theorem in action?
An example of the recursion theorem in action is the creation of a quine, which is a program that outputs its own source code. The existence of such programs demonstrates the recursion theorem, as the quine can be seen as a fixed point of the function that maps programs to their outputs.
What are the implications of the recursion theorem for programming languages?
The implications of the recursion theorem for programming languages are significant, as it suggests that any sufficiently powerful programming language can express self-replicating programs. This leads to discussions about the limits of computation, self-reference, and the ability to create programs that can introspect and manipulate their own code.
How does the recursion theorem relate to Gödel's incompleteness theorems?
The recursion theorem has a conceptual connection to Gödel's incompleteness theorems, as both involve self-reference and the limitations of formal systems. Just as Gödel's theorems demonstrate that certain truths cannot be proven within a formal system, the recursion theorem shows that certain computations can be self-referential, leading to implications about the boundaries of what can be computed or proven in mathematics and logic.
