mrz1982
- 10
Hi.
I am having problem loading large data files. The files consist of values defined as (with a extra space at the end of each line):
The problem is when the number of colomns in my data file becomes more than 99. It is not a memory issue as 99 colomns with 4001 rows works, but 100 colomns with 1001 rows does not work. I am loading the files for 99 colomns like (var2 needs to be larger for later use):
and for 100 colomns like:
I have looked at the IOSTAT value, it returns 100. I have found many values for IOSTAT but not for 100.
I am noticing that as the XXX value in WRITE(READFMT,'(1H(I2,5HE15.61H))')XXX becomes a three digit number the loading is failing i.e. the files can be any size, if the XXX value is larger than 99 the variables, var1 and var2, will be zero.
How can this be solved?
Kind regards!
/Z
I changed the
to
and the problem was solved! :)
Code:
+1.326000e-005 -1.159306e+000 -1.171263e+000
+1.327000e-005 -1.159202e+000 -1.173770e+000
+1.328000e-005 -1.159563e+000 -1.175345e+000
Code:
REAL var1(1001,99), var2(1001,194)
WRITE(READFMT,'(1H(I2,5HE15.61H))')99
open(1,file='folder/file1',FORM='FORMATTED',IOSTAT=IOS,RECL=1486)
open(2,file='folder/file2',FORM='FORMATTED',IOSTAT=IOS,RECL=1471)
DO t=1,1001
READ(1,FMT=READFMT,IOSTAT=IOS)(var1(t,x),x=1,99)
READ(2,FMT=READFMT,IOSTAT=IOS)(var2(t,x),x=1,98)
ENDDO
close(1)
close(2)
Code:
REAL var1(1001,100), var2(1001,195)
WRITE(READFMT,'(1H(I2,5HE15.61H))')100
open(1,file='folder/file1',FORM='FORMATTED',IOSTAT=IOS,RECL=1501)
open(2,file='folder/file2',FORM='FORMATTED',IOSTAT=IOS,RECL=1486)
DO t=1,1001
READ(1,FMT=READFMT,IOSTAT=IOS)(var1(t,x),x=1,100)
READ(2,FMT=READFMT,IOSTAT=IOS)(var2(t,x),x=1,99)
ENDDO
close(1)
close(2)
Kind regards!
/Z
I changed the
Code:
Code:
READ(1,FMT=*,IOSTAT=IOS)(var1(t,x),x=1,100)
READ(2,FMT=*,IOSTAT=IOS)(var2(t,x),x=1,99)
