MHB Problem of making change for n cents
  • Thread starter Thread starter evinda
    Change
The discussion centers on developing a greedy algorithm to make change for n cents using the fewest coins possible, specifically quarters, dimes, nickels, and pennies. The algorithm operates by selecting the highest value coin available, subtracting its value from the total, and repeating this process until no amount remains. To demonstrate that this approach yields an optimal solution, two properties are established: optimal substructure and the greedy choice property. The optimal substructure shows that removing the highest value coin from an optimal solution still allows for an optimal solution for the remaining amount, while the greedy choice property ensures that each choice leads to fewer coins overall. This confirms that the greedy algorithm is effective for making change optimally.
evinda
MHB
Hello! (Wave)
I am looking at the following exercise.
Consider the problem of making change for $n$ cents using the fewest number of
coins. Assume that each coin’s value is an integer.
Describe a greedy algorithm to make change consisting of quarters, dimes,
nickels, and pennies. Prove that your algorithm yields an optimal solution.Could you give me a hint what we could do? (Thinking)
Technology news on Phys.org
evinda said:
Hello! (Wave)
The algorithm works by choosing the coin with the highest value, subtract that value from the amount to change, and repeat until the amount to change is 0. To prove this greedy algorithm yields an optimal solution, we must show optimal substructure and the greedy choice property. Optimal substructure:
Assume to make changes for n cents, the first coin chosen by the greedy algorithm is a c1 coin with value of n1. Let C be the optimal solution to change n cents. Then C – {c1} is an optimal solution to change n-n1 cents. Otherwise, let the optimal solution be B. Then B U{c1} contains fewer coins than C and yet both makes up n cents, so C cannot be the optimal solution making change for n cents, which is a contradiction. Greedy choice property:
If our first choice is a penny, then the amount to change is at most 4 cents. Optimal choice cannot make the change without using a penny, since any other coin makes too much change. If our first choice is a nickel, then the amount to change is between 5 cents and 9 cents. If the optimal choice uses at least 5 pennies, we can turn it to a nickel and use fewer coins, contracting that it is an optimal solution. Otherwise, the optimal choice can only change 4 cents, not enough to make the change. If our first choice is a dime, then the amount to change is between 10 cents and 24 cents. If the optimal choice uses at least 5 pennies, we can turn it to a nickel and use fewer coins. Otherwise, if it uses 2 nickels, we can turn it to a dime. Otherwise, it can only make change for at most 9 cents, not enough to make the change. If our first choice is a quarter, then the amount to change is at least 25 cents. If the optimal choice uses at least 5 pennies, we can turn it to a nickel and use fewer coins. Otherwise, if the optimal solution uses at most 2 dimes, it must use enough pennies to make up at least 25 cents, and we can turn it to a quarter and use fewer coins. Otherwise, the optimal solution uses at least 3 dimes, we can turn it to a quarter and a nickel and use fewer coins.
Therefore the greedy choice property is satisfied.
I see... (Nod)
Could you explain to me what we are supposed to show? :confused:
Why do we say how high the amount to change is, based on out first choise? :confused:
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
