Problem of manometry. Is it resolved correctly?
In summary, the conversation involves determining the manometer reading and the height of the mercury manometer in a tank with given dimensions and atmospheric pressure. The solution involves equating the pressure at point A to the vapor pressure of the alcohol and solving for the unknowns using equations for fluid pressure and density. The final values for the manometer reading and height are 0.124 m and -76.97 kPa, respectively. The variables "S" and "γ" represent the cross-sectional area and density of the alcohol, respectively.
Queren Suriano
50
The tank shown in the figure is located in a place with a
atmospheric pressure (90 kPa abs).
If X = 3.50 m, Y = 1.80 m and the vapor pressure of the alcohol is
13 kPa (abs), determine:
1) manometer reading "A" in KPa.
2) The height "h" of mercury manometer.
[PLAIN]http://upload.wikimedia.org/math/3/3/4/334de1ea38b615839e4ee6b65ee1b103.png= S(fluid)*[PLAIN]http://upload.wikimedia.org/math/3/3/4/334de1ea38b615839e4ee6b65ee1b103.pngwater
[/B]
I have did this:
Equating P(A) = P (alcohol) + 0.035 (Salcohol) ([PLAIN]http://upload.wikimedia.org/math/3/3/4/334de1ea38b615839e4ee6b65ee1b103.pngwater )
P(A) = -76.97 kPa. (Using P(alcohol)= Palchol abs -Patm = -77 kPa)
Equating
P(A) +[PLAIN]http://upload.wikimedia.org/math/3/3/4/334de1ea38b615839e4ee6b65ee1b103.pngalc (h) +1.8 http://upload.wikimedia.org/math/3/3/4/334de1ea38b615839e4ee6b65ee1b103.png (alc) = [PLAIN]http://upload.wikimedia.org/math/3/3/4/334de1ea38b615839e4ee6b65ee1b103.png(Hg) (h)
Solving for "h"
h=0.124 m
The combination of showing work in numerical form instead of symbolic, yet not showing what values you areusing for constants, makes it very hard to follow. Please post your working in purely symbolic form, until the final step, and state what values you are using for g, atm, alcohol's SVP, and the densities.
Related to Problem of manometry. Is it resolved correctly?
1. What is the problem of manometry?
The problem of manometry is the measurement of pressure in different parts of the body, such as the stomach or intestines. It is often used to diagnose disorders of the digestive system or to monitor the effectiveness of treatments.
2. How is manometry performed?
During a manometry test, a thin, flexible tube called a catheter is inserted through the nose or mouth and into the digestive tract. The catheter contains sensors that measure pressure and send data to a computer. The patient is then asked to swallow or perform other movements while the data is recorded.
3. Is the problem of manometry accurately resolved?
Yes, manometry is a highly accurate and reliable diagnostic tool. However, the results may vary depending on the skill of the technician performing the test and the patient's ability to follow instructions during the test.
4. What disorders can be diagnosed with manometry?
Manometry is commonly used to diagnose disorders such as gastroesophageal reflux disease (GERD), achalasia, and esophageal spasms. It can also be used to evaluate disorders of the lower esophageal sphincter, stomach, and intestines.
5. Are there any risks or side effects associated with manometry?
Manometry is a safe procedure with minimal risks. Some patients may experience minor discomfort or gagging during the insertion of the catheter, and there is a very small risk of nosebleeds or infection. However, these risks are rare and can be minimized by following the technician's instructions carefully.
9K
9K
10K
