Problem of the Week #113 - May 26th, 2014
  • Thread starter Thread starter Chris L T521
The problem presented is to find three positive numbers that sum to 27 while minimizing the sum of their squares. Participants used different methods to arrive at the solution, with both calculus and algebraic approaches leading to the same conclusion. The optimal solution is found to be the numbers 9, 9, and 9, which minimizes the sum of squares to 243. This result is verified against other combinations, confirming its minimality. The discussion highlights effective problem-solving techniques in mathematical optimization.
Chris L T521
MHB
Thanks to those who participated in last week's POTW! Here's this week's problem!
Problem: Find three positive numbers whose sum is $27$ and such that the sum of their squares is as small as possible.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
This week's problem was correctly answered by kaliprasad, lfdahl, magneto, Opalg, and Pranav. I'm going to post two different solutions below.
magneto's solution: [sp]We want to minimize $S(x,y,z) = x^2 + y^2 + z^2$ subject to the constraint
$x + y + z = 27$. So consider the function:
$$ f(x,y,z,\lambda) = x^2 + y^2 + z^2 - \lambda(x + y + z - 27).$$
We can take the partial derivative with respect to each variable:
$f_x(x,y,z,\lambda) = 2x - \lambda$,
$f_y(x,y,z,\lambda) = 2y - \lambda$,
$f_z(x,y,z,\lambda) = 2z - \lambda$, and
$f_\lambda(x,y,z,\lambda) = 27 - x - y - z$.
We will solve using Lagrange's multiplier method --- set each equation to $0$,
and solve the system. From equation $f_x(x,y,z,\lambda) = 0$ implies $x = \frac \lambda 2$.
Analogously, we have $y = z = \frac \lambda 2$.
$f_\lambda(x,y,z,\lambda) = 27 - 3 \cdot \frac{\lambda}2 = 0$, or $\lambda = 18$. So,
we have $x = y = z = 9$. So, if an extrema exists, it is at $(9,9,9)$. We just need to verify this
is the minimum. We can do so by seeing $S(9,9,9) = 243 < 627 = S(1,1,25)$.[/sp]
Opalg's solution (which uses no calculus!): [sp]Here's a purely algebraic way to do it – no Lagrange multipliers, no calculus!
Given $a,b,c$, use the notation $$\textstyle \sum a = a+b+c,$$ $$\textstyle\sum a^2 = a^2+b^2+c^2,$$ $$\textstyle\sum bc = bc+ca+ab,$$ $$\textstyle\sum(b-c)^2 = (b-c)^2 + (c-a)^2 + (a-b)^2.$$
Suppose that $a+b+c = k$. Then $k^2 = \bigl(\sum a\bigr)^2 = \sum a^2 + 2\sum bc$. Also, $\sum(b-c)^2 = 2\sum a^2 - 2\sum bc.$ Add those equations to get $k^2 + \sum(b-c)^2 = 3 \sum a^2.$ So $\sum a^2 = \frac13\bigl(k^2 + \sum(b-c)^2\bigr)$, and this is clearly minimised by minimising $\sum(b-c)^2.$ But the minimum value of $\sum(b-c)^2$ is $0$, which occurs when $a=b=c = \frac13k$.
In the case where $k=27$ we should take $a=b=c=9$.[/sp]
