Problem of the Week #79 - September 30th, 2013
  • MHB
  • Thread starter Chris L T521
In summary, the conversation discussed the importance of effective communication in relationships. The speakers emphasized the need for active listening, open and honest communication, and the use of "I" statements to express feelings and needs. They also touched on the impact of technology on communication and the value of being present and engaged in conversations. Overall, the conversation highlighted the crucial role of communication in building and maintaining healthy relationships.
Chris L T521
MHB
915
Thanks again to those who participated in last week's POTW! Here's this week's problem!
Problem: If the ellipse $x^2/a^2 + y^2/b^2 = 1$ is to enclose the circle $x^2+y^2=2y$, what values of $a$ and $b$ minimize the area of the ellipse?
This week's question was correctly answered by anemone (you just made it in at the last minute (Sun)) and MarkFL. I'm going to post both of their fine solutions below.
anemone's solution: [sp]Since the ellipse is to enclose the circle, we know the ellipse will intersect the circle for only one value of $x$(this means also for two different $y$ values since the ellipse is to enclose the circle), that is, if we substitute the equation of the ellipse into the equation of the circle, the discriminant of the quadratic equation that we got must be zero.
So, if we substitue \(\displaystyle x^2=\left( 1-\frac{y^2}{b^2} \right) \left(a^2 \right)\) into the equation \(\displaystyle x^2+y^2=2y\), we get
\(\displaystyle \left( 1-\frac{y^2}{b^2} \right) \left(a^2 \right)+y^2=2y\) \(\displaystyle (b^2-y^2)a^2 +b^2y^2=2b^2y\)
\(\displaystyle (b^2-a^2)y^2 -2b^2y+a^2b^2\)
Set the discriminant equals to zero we get
\(\displaystyle (-2b^2)^2-4(b^2-a^2)(a^2b^2)=0\)
\(\displaystyle 4b^2(b^2-a^2(b^2-a^2)=0\)
\(\displaystyle 4b^2(b^2-a^2b^2+a^4)=0\)
Since \(\displaystyle b^2 \ne 0\), it must be \(\displaystyle b^2-a^2b^2+a^4=0\) or \(\displaystyle b^2=\frac{a^4}{a^2-1}\)
Now, bear in mind that we're asked to find the values of [FONT=MathJax_Math]a[/FONT] and [FONT=MathJax_Math]b[/FONT] so that the area of the ellipse is at its minimum, this simply means we need to find an equation the defines the area of the ellipse(A) in terms of $a$ and the area of the ellipse could be found using calculus technique. Since the ellipse has 4 symmetric quarter, we can find the area of anyone quarter and multiply it by 4 in order to get the total area.
\(\displaystyle A=4\int_0^b \frac{a}{b}\sqrt{b^2-y^2} dy\) [SIZE=+0]
[/SIZE]
We now make the substitution \(\displaystyle y=b\sin \theta\) so that \(\displaystyle dy=b\cos \theta d \theta\)and the area is now given by
\(\displaystyle A=4\frac{a}{b}\int_0^{\frac{\pi}{2}}(\sqrt{b^2-b^2\sin^2 \theta}) b\cos \theta d \theta\) [SIZE=+0]
[/SIZE]
\(\displaystyle A=4\frac{a}{b}(b^2)\int_0^{\frac{\pi}{2}} \cos^2 \theta d \theta\) [SIZE=+0]
[/SIZE]
\(\displaystyle A=4ab\int_0^{\frac{\pi}{2}} \left( \frac{\cos 2\theta}{2}+\frac{1}{2} \right) d \theta\) [SIZE=+0]
[/SIZE]
\(\displaystyle A=4ab \left( \frac{\sin 2\theta}{4}+\frac{\theta}{2} \right)_0^{\frac{\pi}{2}} \) [SIZE=+0]
[/SIZE]
\(\displaystyle A=4ab \left( 0+\frac{\pi}{4}-0 \right) \) [SIZE=+0]
[/SIZE]
\(\displaystyle A=ab\pi \)[SIZE=+0]
[/SIZE]
or \(\displaystyle A^2=a^2b^2\pi^2=a^2(\frac{a^4}{1-a^2})\pi^2 =\left(\frac{a^6}{a^2-1} \right)\pi^2\)
To minimize A, we differentiate the equation of $A$ with respect to $a$ and obtain
\(\displaystyle 2A\frac{dA}{da}=\left(\frac{(1-a^2)(6a^5)-(a^6)(-2a)}{(1-a^2)^2} \right)\pi^2\)
\(\displaystyle 2A\frac{dA}{da}=\frac{a^5\pi^2(4a^2-6)}{(1-a^2)^2} \)
Since $A \ne 0$, \(\displaystyle \frac{dA}{da}=0\) is possible iff \(\displaystyle a^2=\frac{6}{4}=\frac{3}{2}\) and since $a>0$, we must have \(\displaystyle a=\sqrt{\frac{3}{2}}\) and when \(\displaystyle a=\sqrt{\frac{3}{2}}\), \(\displaystyle b^2=\frac{(\frac{3}{2})^2}{\frac{3}{2}-1}=\frac{9}{2}\) which gives \(\displaystyle b=\frac{3}{\sqrt{2}}\).
Now, to determine the nature of the inflexion point where $(a, b)=\left(\sqrt{\frac{3}{2}}, \frac{3}{\sqrt{2}} \right)$ gives the minimum/maximum area of the ellipse, we consider the gradient of the graph of $A$ versus $a$ from left to right and we see that
a1.1$\sqrt{\dfrac{3}{2}}\approx 1.2247$2
A9.12033.5
$\dfrac{dA}{da}$-17.205.23
sign of $\dfrac{dA}{da}$-0+
change of slope of tangent\_/
Therefore, we can conclude that the minimal area of the ellipse is attained at the point $(a, b)=\left(\sqrt{\frac{3}{2}}, \frac{3}{\sqrt{2}} \right)$.[/sp]MarkFL's solution: [sp]First, we want to define our objective function $A(a,b)$, the area of the ellipse, in terms of the parameters $a$ and $b$:
We know the ellipse is centered at the origin, and will pass through the points $(0,b),\,(a,0)$ and so by symmetry, we may state:
\(\displaystyle A(a,b)=4b\int_0^a \sqrt{1-\left(\frac{x}{a} \right)^2}\,dx\)
using the substitution:
\(\displaystyle \frac{x}{a}=\sin(\theta)\,\therefore\,dx=a\cos( \theta)\,d \theta\)
we now have:
\(\displaystyle A(a,b)=4ab\int_0^{\frac{\pi}{2}}\sqrt{1-\sin^2(\theta)}\cos(\theta)\,dx\)
\(\displaystyle A(a,b)=4ab\int_0^{\frac{\pi}{2}}\cos^2(\theta)\,dx\)
Using a double-angle identity for the cosine function, we obtain:
\(\displaystyle A(a,b)=2ab\int_0^{\frac{\pi}{2}}1+\cos(2\theta)\,dx\)
Applying the FTOC, there results:
\(\displaystyle A(a,b)=2ab\left[\theta+\frac{1}{2}\sin(2\theta) \right]_0^{\frac{\pi}{2}}=\pi ab\)
Thus, our objective function is:
\(\displaystyle A(a,b)=\pi ab\)
Now, for the constraint, let's begin with the equations of the circle and the ellipse:
\(\displaystyle \frac{x^2}{a^2}+\frac{y^2}{b^2}=1\)
Obviously there will have to be at least one point where the two curves are tangent. At these tangent points, the slope of the two curves will have to be the same as well.
If we multiply the second equation by $-a^2$ and then add the two equations, we eliminate $x$ to obtain:
\(\displaystyle y^2-\frac{a^2}{b^2}y^2=2y-a^2\)
Writing this equation in standard quadratic form in $y$, we have:
\(\displaystyle \left(b^2-a^2 \right)y^2-2b^2y+a^2b^2=0\)
Next, implicitly differentiating the equation of the circle, we find:
\(\displaystyle 2x+2y\frac{dy}{dx}=2\frac{dy}{dx}\)
\(\displaystyle \frac{dy}{dx}=\frac{x}{1-y}\)
And doing the same for the equation of the ellipse, we obtain:
\(\displaystyle \frac{2x}{a^2}+\frac{2y}{b^2}\frac{dy}{dx}=0\)
\(\displaystyle \frac{dy}{dx}=-\frac{b^2x}{a^2y}\)
Equating the two slopes, we then get:
\(\displaystyle \frac{x}{1-y}=-\frac{b^2x}{a^2y}\)
\(\displaystyle y=\frac{b^2}{b^2-a^2}\)
Substituting this into the quadratic we found in $y$, we now have:
\(\displaystyle \left(b^2-a^2 \right)\left(\frac{b^2}{b^2-a^2} \right)^2-2b^2\left(\frac{b^2}{b^2-a^2} \right)+a^2b^2=0\)
And this gives us our constraint function:
\(\displaystyle g(a,b)=b^2\left(a^2-1 \right)-a^4=0\)
Using Lagrange multipliers, we obtain the system:
\(\displaystyle \pi b=\lambda\left(2ab^2-4a^3 \right)\)
\(\displaystyle \pi a=\lambda\left(2a^2b-2b \right)\)
Solving both equations for $\lambda$ and equating, we obtain:
\(\displaystyle \lambda=\frac{\pi b}{2a\left(b^2-2a^2 \right)}=\frac{\pi a}{2b\left(a^2-1 \right)}\)
\(\displaystyle \frac{b}{a\left(b^2-2a^2 \right)}=\frac{a}{b\left(a^2-1 \right)}\)
\(\displaystyle b^2\left(a^2-1 \right)=a^2\left(b^2-2a^2 \right)\)
\(\displaystyle a^2b^2-b^2=a^2b^2-2a^4\)
\(\displaystyle b^2=2a^4\)
Substituting for $b^2$ into the constraint function, we find:
\(\displaystyle 2a^4\left(a^2-1 \right)-a^4=0\)
Taking $0<a$ and dividing through by $a^4$, we obtain:
\(\displaystyle 2\left(a^2-1 \right)-1=0\)
\(\displaystyle a^2=\frac{3}{2}\)
And thus:
\(\displaystyle b=\sqrt{2}a^2=\frac{3}{\sqrt{2}}\)
And so, we may conclude that the area of the ellipse is minimized for:
\(\displaystyle (a,b)=\left(\sqrt{\frac{3}{2}},\frac{3}{\sqrt{2}} \right)\)
Here is a plot of the circle and the ellipse:
[/sp]
FAQ: Problem of the Week #79 - September 30th, 2013
What is the problem of the week #79 for September 30th, 2013?
The problem of the week #79 for September 30th, 2013 is a scientific challenge or puzzle that is presented to the community to solve and discuss. It is a way to engage in critical thinking and problem-solving skills.
How often is the problem of the week posted?
The problem of the week is posted every week on a specific date, in this case, September 30th, 2013. However, the frequency of the problem of the week may vary depending on the source or organization hosting it.
Can anyone participate in the problem of the week?
Yes, the problem of the week is open to anyone who is interested in science and enjoys solving challenging problems. It is a great opportunity for students, scientists, and enthusiasts to engage in critical thinking and scientific discussions.
How can I submit my solution to the problem of the week?
The submission process may vary depending on the source or organization hosting the problem of the week. Usually, there will be a designated platform or email address where you can submit your solution. Make sure to follow the instructions provided by the host.
Are there any rewards for solving the problem of the week?
Again, this may vary depending on the host, but some organizations may offer rewards or recognition for solving the problem of the week. It is best to check with the host for any potential rewards or incentives.
