Problem of the Week #95 - January 20th, 2014
  • MHB
  • Thread starter Chris L T521
In summary, the individuals in the conversation are discussing the benefits of exercising regularly. They mention that exercise can improve physical and mental health, as well as increase energy levels and boost self-confidence. They also touch on the importance of finding a form of exercise that one enjoys in order to make it a sustainable habit. Additionally, they note that exercise can have a positive impact on overall well-being and quality of life.
Chris L T521
MHB
915
Thanks again to those who participated in last week's POTW! Here's this week's problem!
Problem: Let $f(t)$ be a $\dfrac{2\pi}{k}$-periodic function, where
\[f(t)=\begin{cases}\sin(kt) & 0\leq t< \frac{\pi}{k}\\ 0 & \frac{\pi}{k}\leq t< \frac{2\pi}{k}\end{cases}\]
Find $\mathcal{L}\{f(t)\}$.
This week's problem was correctly answered by MarkFL. You can find his solution below.
[sp]We are given the function:
\(\displaystyle f(t)=\begin{cases}\sin(kt) & 0\leq t< \dfrac{\pi}{k}\\ 0 & \dfrac{\pi}{k}\leq t< \dfrac{2\pi}{k}\end{cases}\)
Which is \(\displaystyle p=\frac{2\pi}{k}\) periodic, and which we observe is continuous as well.
To find the Laplace transform, we begin with the definition:
\(\displaystyle \mathcal{L}\{f\}\equiv\int_0^{\infty} e^{-st}f(t)\,dt\)
Because $f(t)$ satisfies:
\(\displaystyle f(t)=f(t+p)\) for \(\displaystyle 0\le t\)
we may simplify our computations by partitioning the integral of the transform into integrals over subintervals of length $p$, and write:
\(\displaystyle ]\mathcal{L}\{f\}=\sum_{j=0}^{\infty}\left(\int_{jp}^{(j+1)p} e^{-st}f(t)\,dt \right)\)
Consider the following substitution:
\(\displaystyle \tau=t-jp\)
Then we find:
\(\displaystyle e^{-st}=e^{-s(\tau+jp)}\)
and so using this and by the periodicity of $f$, we find:
\(\displaystyle \int_{jp}^{(j+1)p} e^{-st}f(t)\,dt=e^{-jps}\int_{0}^{p} e^{-s\tau}f(\tau)\,d\tau\)
Since the integral does not depend on $j$, we may now write:
\(\displaystyle \mathcal{L}\{f\}=\left(\int_{0}^{p} e^{-s\tau}f(\tau)\,d\tau \right)\sum_{j=0}^{\infty}\left(e^{-jps} \right)\)
Now, if we observe that the sum is a geometric series, we may write:
\(\displaystyle \sum_{j=0}^{\infty}\left(e^{-jps} \right)=\sum_{j=0}^{\infty}\left(\left(e^{-ps} \right)^j \right)=\frac{1}{1-e^{-ps}}\)
Now, for the integral, we may write (using the definition of $f$):
\(\displaystyle \int_{0}^{p} e^{-s\tau}f(\tau)\,d\tau=\int_{0}^{\frac{p}{2}} e^{-s\tau}\sin(k\tau)\,d\tau+\int_{\frac{p}{2}}^{p} e^{-s\tau}0\,d\tau=\int_{0}^{\frac{p}{2}} e^{-s\tau}\sin(k\tau)\,d\tau\)
At this point, we may develop a formula for:
\(\displaystyle I=\int_0^a e^{bx}\sin(cx)\,dx\)
Using integration by parts, we may use:
\(\displaystyle u=\sin(cx)\,\therefore\,du=c\cos(cx)\,dx\)
\(\displaystyle dv=e^{bx}\,dx\,\therefore\,v=\frac{1}{b}e^{bx}\)
Hence:
\(\displaystyle I=\left[\frac{1}{b}e^{bx}\sin(cx) \right]_0^a-\frac{c}{b}\int_0^a e^{bx}\cos(cx)\,dx\)
\(\displaystyle I=\frac{1}{b}e^{ab}\sin(ac)-\frac{c}{b}\int_0^a e^{bx}\cos(cx)\,dx\)
On the remaining integral, use integration by parts again where:
\(\displaystyle u=\cos(cx)\,\therefore\,du=-c\sin(cx)\,dx\)
Hence:
\(\displaystyle I=\frac{1}{b}e^{ab}\sin(ac)-\frac{c}{b}\left(\left[\frac{1}{b}e^{bx}\cos(cx) \right]_0^a+\frac{c}{b}\int_0^a e^{bx}\sin(cx)\,dx \right)\)
\(\displaystyle I=\frac{1}{b}e^{ab}\sin(ac)-\frac{c}{b}\left(\frac{1}{b}e^{ab}\cos(ac)-\frac{1}{b}+\frac{c}{b}I \right)\)
\(\displaystyle I=\frac{1}{b}e^{ab}\sin(ac)-\frac{c}{b^2}e^{ab}\cos(ac)+\frac{c}{b^2}-\frac{c^2}{b^2}I\)
\(\displaystyle I\left(\frac{b^2+c^2}{b^2} \right)=\frac{\left(b\sin(ac)-c\cos(ac) \right)e^{ab}+c}{b^2}\)
\(\displaystyle I=\frac{\left(b\sin(ac)-c\cos(ac) \right)e^{ab}+c}{b^2+c^2}\)
Applying this formula, we may then write:
\(\displaystyle \int_{0}^{\frac{p}{2}} e^{-s\tau}\sin(k\tau)\,d\tau=\frac{\left(-s\sin\left(\dfrac{p}{2}k \right)-k\cos\left(\dfrac{p}{2}k \right) \right)e^{-\frac{p}{2}s}+k}{s^2+k^2}\)
And so we now have:
\(\displaystyle \mathcal{L}\{f\}=\frac{k-e^{-\frac{p}{2}s}\left(s\sin\left(\dfrac{p}{2}k \right)+k\cos\left(\dfrac{p}{2}k \right) \right)}{\left(s^2+k^2 \right)\left(1-e^{-ps} \right)}\)
Using \(\displaystyle p=\frac{2\pi}{k}\) we have:
\(\displaystyle \mathcal{L}\{f\}=\frac{k-e^{-\frac{\pi}{k}s}\left(s\sin\left(\pi \right)+k\cos\left(\pi \right) \right)}{\left(s^2+k^2 \right)\left(1-e^{-\frac{2\pi}{k}s} \right)}\)
\(\displaystyle \mathcal{L}\{f\}=\frac{k\left(1+e^{-\frac{\pi}{k}s} \right)}{\left(s^2+k^2 \right)\left(1-e^{-\frac{2\pi}{k}s} \right)}\)
Factoring the second factor in the denominator as the difference of squares and then dividing out the resulting factor common to the numerator, we obtain:
\(\displaystyle \mathcal{L}\{f\}=\frac{k}{\left(s^2+k^2 \right)\left(1-e^{-\frac{\pi}{k}s} \right)}\)[/sp]
Mark did a great job solving this problem from first principles. There is a formula, though, that allows you to compute $\mathcal{L}\{f(t)\}$ for $p$-periodic functions (which Mark, in essence, derived): If $f(t)$ is $p$-periodic and piecewise continuous for $t\geq 0$, then \[\mathcal{L}\{f(t)\} = \frac{1}{1-e^{-ps}}\int_0^p e^{-st}f(t)\,dt\tag{1}\]
Below, you'll find my solution using $(1)$.
[sp]Consider the $\dfrac{2\pi}{k}$-periodic function $f(t)$, where
\[f(t) = \begin{cases}\sin(kt) & 0\leq t\leq \pi/k\\ 0 & \pi/k \leq t < 2\pi/k\end{cases}\]
By formula $(1)$, we see that
\[\mathcal{L}\{f(t)\} = \frac{1}{1-e^{-2\pi s/k}}\int_0^{2\pi/k} e^{-st}f(t)\,dt = \frac{1}{1-e^{-2\pi s/k}}\int_0^{\pi/k}e^{-st}\sin(kt)\,dt.\]
To evaluate
\[\int_0^{\pi/k} e^{-st}\sin(kt)\,dt\]
we proceed using integration by parts twice: Let $u=e^{-st}\implies \,du=-se^{-st}\,dt$ and $\,dv=\sin(kt)\,dt \implies v= -\frac{1}{k}\cos (kt)$. Therefore,
\[\begin{aligned}\int_0^{\pi/k} e^{-st}\sin(kt)\,dt &= \left.\left[-\frac{e^{-st}}{k}\cos(kt)\right]\right|_0^{\pi/k} - \frac{s}{k}\int_0^{\pi/k}e^{-st}\cos(kt)\,dt\\ &= \frac{1+e^{-\pi s/k}}{k} -\frac{s}{k}\int_0^{\pi/k} e^{-st}\cos(kt)\,dt\end{aligned}\]
We apply parts again: $u=e^{-st}\implies \,du = -se^{-st}\,dt$ and $\,dv=\cos(kt) \implies v=\frac{1}{k}\sin(kt)$. Therefore,
\[\begin{aligned}\int_0^{\pi/k}e^{-st}\sin(kt) &= \frac{1+e^{-\pi s/k}}{k}-\frac{s}{k}\left(\left.\left[ \frac{e^{-st}}{k}\sin(kt)\right]\right|_0^{\pi/k} + \frac{s}{k}\int_0^{\pi/k} e^{-st}\sin(kt)\,dt\right)\\ &= \frac{1+e^{-\pi s/k}}{k}-\frac{s^2}{k^2} \int_0^{\pi/k} e^{-st}\sin(kt)\,dt\end{aligned}\]
Solving for the integral leaves us with
\[\left(1+\frac{s^2}{k^2}\right) \int_0^{\pi/k}e^{-st}\sin(kt)\,dt = \frac{1+e^{-\pi s/k}}{k} \implies \int_0^{\pi/k}e^{-st}\sin(kt)\,dt = \frac{k}{s^2+k^2}(1+e^{-\pi s/k})\]
Therefore
\[\begin{aligned}\mathcal{L}\{f(t)\} &= \frac{1}{1-e^{-2\pi s/k}}\cdot \frac{k}{s^2+k^2}(1+e^{-\pi s/k})\\ &= \frac{k(1+e^{-\pi s/k})}{(s^2+k^2)(1+e^{-\pi s/k}) (1-e^{-\pi s/k})}\\ &= \frac{k}{(s^2+k^2)(1-e^{-\pi s/k})}\end{aligned}\][/sp]
FAQ: Problem of the Week #95 - January 20th, 2014
What is the "Problem of the Week #95 - January 20th, 2014"?
The "Problem of the Week #95 - January 20th, 2014" is a weekly challenge that was posted on a scientific forum on January 20th, 2014. It presents a problem or question related to a specific topic and encourages scientists to think critically and creatively to find a solution.
Who posts the "Problem of the Week #95 - January 20th, 2014"?
The "Problem of the Week #95 - January 20th, 2014" was posted by the forum moderators or administrators. They are responsible for selecting the topic and creating the problem for the week.
What is the purpose of the "Problem of the Week #95 - January 20th, 2014"?
The purpose of the "Problem of the Week #95 - January 20th, 2014" is to stimulate critical thinking and problem-solving skills among scientists. It also encourages collaboration and discussion among members of the scientific community.
Are there any rewards for solving the "Problem of the Week #95 - January 20th, 2014"?
Some forums may offer rewards or recognition for those who successfully solve the "Problem of the Week #95 - January 20th, 2014". This could include virtual badges, points, or even tangible prizes. However, the main reward is the satisfaction of finding a solution and participating in a challenging and engaging scientific discussion.
Can anyone participate in the "Problem of the Week #95 - January 20th, 2014"?
Yes, anyone with a background or interest in science can participate in the "Problem of the Week #95 - January 20th, 2014". It is open to all members of the forum and sometimes even to non-members. However, some problems may require specific knowledge or skills, so it is important to read the guidelines and instructions carefully before participating.
