Problem on a liquid drop free fall
In summary: So if we could answer that question, we would have found the velocity of the drop.In summary, the water drop continually evaporates. The velocity of the drop as a function of time is determined by gravity and the rate of evaporation.
Abhisek Roy
A freely falling water drop continually evaporates. Assuming that the net momentum carried away by the vapor vanishes, calculate the velocity of the drop as a function of time. (Assume that the rate of evaporation varies as the surface area)[/B]
dA/dr = rate of evaporation, where A is surface area of water droplet...and radius of spherical water droplet.
dA/dr= d(πr^2)/dr=2πr
Cant understand what "net momentum carried away by the vapor vanishes" means...cud it be that there r no drag forces the the vapor drop...
. Then how do I find the vel. Of the drop?
Possibly you are overthinking this.
My understanding matches yours -- that there are no drag forces on the vapor drop. The momentum carried away by the vapor simply vanishes and can be ignored. With that understanding, the only thing affecting the velocity of the drop is gravity. There is a simple formula for the velocity of a body acted upon only by gravity.
The more difficult part, if you want to tackle it, would be determining the time required (if finite) before the droplet evaporates completely.
Likes Abhisek Roy
Yes the expression for velocity is fairly simple... If no drag forces are involved... If that's what's to be deduced from that statement... Thanks... N yea I'll try to find an expression fr total e CV aporation fr vapor too... But don't know whr to start.
I think the rate of evaporation = variation of area of drop is the main eqn. Then
Your expression for the rate of evaporation is incorrect. It should be that the rate of change of mass of the drop with respect to time is proportional to the surface area.
Chet
Arguably, that is all part of answering the question about velocity as a function of time. The domain of that function will be the time for which the drop exists.
Related to Problem on a liquid drop free fall
1. What is the problem on a liquid drop free fall?
The problem on a liquid drop free fall is a classic physics problem that involves the motion of a drop of liquid falling through the air. It is used to study the effects of gravity and air resistance on the motion of objects.
2. How is the problem on a liquid drop free fall solved?
The problem on a liquid drop free fall is typically solved using mathematical equations and principles of physics. This includes considering the force of gravity, the mass and density of the liquid drop, and the effects of air resistance.
3. What factors affect the motion of a liquid drop during free fall?
The motion of a liquid drop during free fall is affected by several factors, including the force of gravity, the mass and density of the drop, the viscosity of the liquid, and the shape and size of the drop.
4. What real-life applications does the problem on a liquid drop free fall have?
The problem on a liquid drop free fall has various real-life applications, such as in studying the motion of raindrops, the behavior of liquids in space, and the design of parachutes and other air resistance devices.
5. Why is the problem on a liquid drop free fall important in the field of physics?
The problem on a liquid drop free fall is important in the field of physics because it helps us understand the fundamental principles of motion, gravity, and air resistance. It also serves as a basis for more complex problems and experiments in fluid dynamics.
