Problem on a moving wedge and acceleration
In summary, a moving wedge is a simple machine that can lift, separate, or change the direction of a force. Its acceleration can be calculated using the formula a = Fnet/m, where Fnet is the net force acting on the wedge and m is its mass. Several factors, such as weight, angle, and friction, can affect the acceleration of a moving wedge. The angle of the wedge can significantly impact its acceleration, with a steeper angle resulting in a greater acceleration, but too steep an angle can cause a decrease in acceleration. The acceleration of a moving wedge can also be negative, indicating a decrease in speed or movement in the opposite direction of the applied force.
chester20080
56
We have a wedge and at the top of it a block(consider it dimensionless)and the whole system initially is at rest.Given the gravitational acceleration g, the angle φ of the inclined plane,the mass m of the block,the mass M of the wedge,the coefficient of friction fs between the block and the ledge and that there is no friction between the wedge and the floor,find the acceleration needed for the block not to move with regards as the wedge.
For the friction we have:T<=fs*N,where N is the normal reaction force.
For the block:Wx=mgsinφ,Wy=mgcosφ
I considered an observer at rest somewhere out of the system and I thought that in respect to him the system will have a horizontal acceleration when we finally give the system the acceleration we need.I analyzed this acceleration vector to two vertical components,one vertical to the ledge and the other parallel to it.Then I made a free body diagram,drew the forces on the block (N,T,Wb) and analyzed the weight to two vertical components.Of course I considered X,Y axis.Then I wrote ΣFx=max and ΣFy=may (with vectors) and finally I got:ax=(mgsinφ-T)/m,ay=(N-mgcosφ)/m and given that ax=acosφ,ay=asinφ and T<=fs*N and solving for a:a>=(g(sinφ-fs*cosφ))/(fs*sinφ+cosφ) so the acceleration needed is aminimum=(g(sinφ-fs*cosφ))/(fs*sinφ+cosφ).
Furthermore,I want to ask if we must consider if the wedge could rotate due to the torque of the force we have to exert on it for the acceleration.In addition to that I'm confused why I didn't get M to the solution.I considered that as a system,whatever acceleration the block gets,the same the wedge gets and the same the whole system gets,although that bothers me for its physical meaning...What if we consider the wedge weightless?(M=0?)
I am not sure if any of those is correct,so please enlighten me!
There will be a range of accelerations for which the block will stay in place on the wedge. They may all be in the direction the wedge points, but 0 may be in the range, meaning there's a range of accelerations in each direction.
... which could be negative.
You are asked for an acceleration, not a force. You must therefore assume the acceleration is achieved in whatever way necessary.
Again, you're finding an acceleration, not a force. It follows that the masses of the wedge and block are irrelevant.
Thank you very much for your answers!Actually,our professor asked us to find the minimum acceleration needed for the problem and the acceleration to be horizontal.Also,he didn't seem to care for any torques,but the correct isn't that we should?And my answer you think is correct(for amin?)
chester20080 said:
Actually,our professor asked us to find the minimum acceleration needed for the problem and the acceleration to be horizontal.And my answer you think is correct(for amin?)
Your answer is correct except that I think you should discuss the case where the expression goes negative. What do you think 'minimum' means in this case? I would think it should be interpreted as minimum magnitude.
No. The question asks for an acceleration. How that acceleration is achieved is immaterial. If it asked for a force, and where that force should be applied, then you might worry about torque.
Your approach to the problem seems correct. It is important to consider the forces acting on the block and the wedge separately, as they have different masses and therefore different accelerations. It is also important to consider the possibility of the wedge rotating due to the applied force, as this would affect the overall acceleration of the system.
To address your questions, the wedge being weightless (M = 0) would not affect the solution, as it would still experience the same acceleration as the block due to the applied force. However, if the wedge were to have a significant mass, it could potentially affect the overall acceleration of the system and would need to be taken into account in the equations.
In addition, it is important to note that the solution you have obtained is for the minimum acceleration needed for the block not to move with regards to the wedge. If the applied acceleration is greater than this minimum value, the block will move with regards to the wedge. Therefore, it is important to consider the physical implications and limitations of the problem, such as the maximum possible acceleration that can be applied to the system.
Overall, your approach and solution seem valid. It may also be beneficial to double check your calculations and equations to ensure accuracy.
Related to Problem on a moving wedge and acceleration
1. What is a moving wedge?
A moving wedge is a simple machine consisting of a triangular-shaped object that is able to move or slide along a flat surface. It is often used to lift or separate objects and can also be used to change the direction of a force.
2. How is acceleration calculated in a moving wedge?
The acceleration of a moving wedge can be calculated using the formula a = Fnet/m, where a is the acceleration, Fnet is the net force acting on the wedge, and m is the mass of the wedge. The net force can be calculated by summing all the forces acting on the wedge.
3. What factors affect the acceleration of a moving wedge?
The acceleration of a moving wedge can be influenced by several factors, including the weight and angle of the wedge, the force applied to the wedge, and the friction between the wedge and the surface it is moving on. The shape and mass distribution of the wedge can also affect its acceleration.
4. How does the angle of a wedge affect its acceleration?
The angle of a wedge can significantly impact its acceleration. As the angle increases, the force applied to the wedge also increases, leading to a greater acceleration. However, if the angle is too steep, the wedge may lose contact with the surface it is moving on, resulting in a decrease in acceleration.
5. Can the acceleration of a moving wedge be negative?
Yes, the acceleration of a moving wedge can be negative. This indicates that the wedge is slowing down or moving in the opposite direction of the applied force. Negative acceleration can occur when there is a greater force acting against the direction of motion, such as friction or air resistance.
